Old 08-15-2016, 06:00 PM   #1
2015 Interstate Coach
MEDFORD , New Jersey
Noise from Water Pump on RV pump
When I turn on the RV water pump I'm getting a hammering on metal noise, when pump is priming the water system. Sounds like its coming from behind 2nd row seats on curb side.. Its look like their is an access panel behind the seat. is that where the water pump is located, any suggestionsi what is causing the noise. ?? Is it air in the system??
RICKBETTY is offline   Reply With Quote
Old 08-15-2016, 06:04 PM   #2
You may need to clean the filter. The negative head pressure can cause some banging type sounds.
LB_3 is offline   Reply With Quote
Old 08-15-2016, 06:07 PM   #3
2013 Interstate Coach
Raymond , Iowa
pump is under the sink (pull out the lower drawer to get to it) on my 2013 Lounge EXT. On mine the area that you describe is where my toilet is and the access panel behind the 2nd row curbside is to access drain plumbing - I think.
Titus is offline   Reply With Quote
Old 08-15-2016, 06:52 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
OP must have a Grand Tour. Those have a mirror-image floor plan.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-15-2016, 09:00 PM   #5
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
If our Interstate hasn't been used in a while, air gets into the water lines and the pump rattles very badly. Only way to fix it is to open all faucets moving the lever from hot to cold and back a few times. Eventually it goes quieter.
Old 08-15-2016, 11:21 PM   #6
I just open the faucets halfway between hot and cold and leave them that way until they quit spitting.
WBCCI #1105
TAC LA-4
Old 08-15-2016, 11:55 PM   #7
2011 Interstate Coach
Muskogee , Oklahoma
What model Interstate do you own?
The pump tends to pulse. In fact, that's exactly how it works, with a rubber membrane that moves back and forth. If the pex pipe is laid to close and next to the sheet metal, it can vibrate against it, and that likely is the cause. Since I don't know your model, I can't say how to access it, but mine, like Progtag's, is on the other side and can be access by removing a lower drawer. I replaced mine with a variable flow pump, that is much quieter, but it still can cause a banging sound occasionally.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 08-16-2016, 12:39 PM   #8
Houston , Texas
If you have a late model GT, the pump is under the freezer and accessible by removing two thumb screws holding the black vent cover. I have had to clean the screen filter twice in 10 months. It has been clogged with plastic shavings left in the freshwater tank from assembly. Not a big deal, but a nuisance. The signals were difficulty in priming, low pressure at the galley sink and frequent cycling.
Mcrider is offline   Reply With Quote
Old 08-16-2016, 01:27 PM   #9
Aircruiser's Avatar
Westerville , Ohio
I found that the water lines coming off the pump were vibrating against each other and other parts beneath the sink. I stuck pieces of stiff foam between the lines to isolate them. Helped quite a bit, but still wish it was quieter.
Aircruiser is online now   Reply With Quote
Old 08-16-2016, 03:19 PM   #10
2012 30' International
Livingston , Texas
I had the same problem. The problem was air in the line. I purged all the water lines... except I had forgotten about the outside shower. That fixed it.
glenrms is offline   Reply With Quote
Old 08-17-2016, 10:43 PM   #11
2009 19' International
DURANGO , Colorado
Hi! I grew up in Lake Pine. My Dad still lives on the lake! My brother is retired from the Medford Police Dept. I really miss the pizza there!
Well anyway, I had the same problem. It turned out it needed tightening. I believe over time the vibration of the pump loosens the screws. After tightening the banging went away. Good luck
SiverD is offline   Reply With Quote
Motor noise vs fan noise vs overdrive question SebasSF Mechanics Corner - Engines, Transmission & More... 25 12-15-2013 12:18 PM
water pump noise Josie28 General Repair Forum 7 10-23-2012 11:52 PM
Interstate 3500 2012 water pump noise TY PECK Plumbing - Systems & Fixtures 4 03-09-2012 11:05 AM
Water Pump Noise dkekrksk 2002 - 2005 International 11 01-04-2008 09:41 PM
Water Pump Noise pmclemore Water Heaters, Filters & Pumps 14 05-09-2006 03:06 PM
