Old 12-11-2017, 08:10 AM   #1
2013 Interstate Coach
Poland , Ohio
No propane to coach
Started up my 2013 interstate ext for day trip. Attempted to start generator but would not turn over. Felt like it was getting no propane. Checked tank have propane, outside switch on. Decided to check inside stove, no propane. What do I need to check. Is there a fuse to the outside switch?
Docevil87 is offline   Reply With Quote
Old 12-11-2017, 08:21 AM   #2
toskeysam's Avatar
Townsend , Tennessee
On my 2013 Lounge Ext, the outside propane switch is fused on the same circuit as the refrigerator, and propane detector. My refrigerator was on a jag of blowing fuses and that’s how I found what was on that fuse.
Flip the outside switch on and off to see if it is cycling the solenoid.
FMCA # 436814
toskeysam is online now   Reply With Quote
Old 12-11-2017, 08:24 AM   #3
toskeysam's Avatar
Should’ve also said....”You will hear the solenoid cycle”
FMCA # 436814
Old 12-11-2017, 08:34 AM   #4
Poland , Ohio
Fridge and propane alarm powered on. When I hit outside switch I hear a click is that what you mean by hearing the solenoid cycle?
Old 12-11-2017, 08:38 AM   #5
toskeysam's Avatar
Yes. The solenoid has a definite, loud click when it cycles. You could, carefully, open the quick connect valve in the box near solenoid switch to see if anything comes out.....quickly, briefly. It is fed through the regulator as well.
FMCA # 436814
Old 12-11-2017, 08:39 AM   #6
toskeysam's Avatar
I say carefully, because I think there is a high flow shutoff in the line that could close if flow is too high.
FMCA # 436814
Old 12-11-2017, 09:27 AM   #7
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Can't help, but forum member posted this not too long ago:
http://www.airforums.com/forums/f240...ed-175705.html
In his case the problem was the regulator... but again, not sure if it is the same issue you are encountering. Just wanted to make sure you had seen that thread.
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 12-11-2017, 09:29 AM   #8
Raymond , Iowa
My propane level gauge is highly inaccurate. You may be out of propane even if the tank level gauge says you are not. Try pouring a few cups of warm water down the side of the propane tank (easier said than done). The tank wall will be warm above the level of the propane and cool below it.
Titus is offline   Reply With Quote
Old 12-11-2017, 10:39 AM   #9
Originally Posted by Titus View Post
My propane level gauge is highly inaccurate. You may be out of propane even if the tank level gauge says you are not. ....
+1. Our gauge is a P.O.S. even though it's only 2 years old.
One of your next steps will be to try to fill your tank, assuming there are no indications of a safety issue. That'll tell you a lot.
Old 12-11-2017, 10:59 AM   #10
Poland , Ohio
Thanks for all the replies. I opened up the overfill valve and propane came out, i assume that means there is propane in the tank. The guage has 2 lights on but I understand that is not accurate. Maybe the easiest thing to do is fill the tank and see what happens.
Old 12-11-2017, 11:50 AM   #11
iaqstuff's Avatar
Yarnell , Arizona
Needs 12+ volts via house batteries
If you haven't, check your house batteries as the propane solenoid needs a reasonable voltage to open propane line.
iaqstuff is online now   Reply With Quote
Old 12-11-2017, 11:56 AM   #12
toskeysam's Avatar
Possible regulator failure is why I suggested cracking the valve on the quick connect fitting. It is fed by the regulator too.
FMCA # 436814
Old 12-11-2017, 12:06 PM   #13
Poland , Ohio
Thanks was hooked up to shore power so that should not be the issue. Will look at cracking the quick disconnect valve when I get home. Are talking about the valve when you fill up with propane?
Old 12-11-2017, 12:12 PM   #14
toskeysam's Avatar
The “propane box” on my 2013 AI contains: the bleed valve for fill confirmation, the fill connection, the solenoid switch, and a quick connect fitting for hooking up a grill. The quick connect fitting has a ball valve above it. Wish I could find a photo......
FMCA # 436814
Propane Cooktop Stove, Propane Oven from 1971 Sovereign colleenkay Airstream Classifieds 0 09-14-2016 03:06 PM
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 08:56 AM
Newbie Advice on Propane and Propane Accessories Socal1 LP Gas, Piping, Tanks & Regulators 1 07-15-2013 12:36 PM
Fan Motor Coach parts? starbellie Vintage Kin 1 06-01-2006 06:03 AM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
