Old 05-20-2015, 04:24 PM   #1
Rockwell , North Carolina
No power to thermostat
We are camped in Mansfield, MA in our 2013 EXT. After hooking up, I tried to turn on the AC but there is no power to the thermostat. It has been working perfectly the past six days during our trip. I checked all of the fuses both under the rear seat and under the driver's seat and did not find any that were blown. I also checked all of the circuit breakers and all is well there.
I did a search and found that one person had had an issue with the circuit breaker on the furnace. That circuit breaker is as it should be too.
The only thing different that happened today was my taking the motorhome to a place that washed RV's first thing this morning. He did a great job but was using a high pressure sprayer. Until now I did not think about covering the exhaust outlet for the furnace. Could water have entered the furnace and be causing the problem. He was not able to reach the roof very well so no high pressure water was applied to the AC unit. We drove here from just outside Philadelphia.
Everything else in the motor home appears to be working. The fuse for the thermostat also supplies voltage for the exhaust fan and it is working.
Any help would be appreciated.
jerhofer is offline   Reply With Quote
Old 05-20-2015, 06:25 PM   #2
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
Jerry,
start by testing the 110 VAC supply that you're hooking up to for proper ground, hot and neutral,
and then flipping the 110 VAC breaker(s) (though they may all look OK) off and then back on,
we have no firsthand knowledge of the equipment you're talking about, so,
my suggestion might be that you check in with Airstream of New England, tomorrow. they are located in Stoughton, MA, only about a dozen or so miles away from Mansfield, MA.
best of luck with the problem!
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 05-20-2015, 06:31 PM   #3
1994 34' Limited
Round Rock , Texas
Might be on the wrong track here. Assume this is the thermostat in the RV to control temp? I know this sounds super simple, but did your batteries die that power the actual thermostat? Should be 2 AA batteries, and the front just clips off.
Hope its that simple...
txtwin is offline   Reply With Quote
Old 05-20-2015, 06:57 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Weird. My Interstate's thermostat is hardwired and runs off the house batteries. If it ran off AA cells there wouldn't be any reason for there to be a fuse for it on the fuse panel; it would be self-contained.
I'm curious how jerhofer decided that the reason the AC didn't work was that the thermostat lost power. It might be advantageous to pull the fuse and bridge across the fuse contacts with a voltmeter to see if the thermostat is in fact drawing power; if it is, it's not dead and there is some other reason for the AC to not work.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-20-2015, 07:31 PM   #5
When I discovered the problem I was trying to check on the inside temperature. Actually, because it is cool here this evening, I would need the furnace more than the AC. But the thermostat does not light up up at all. It is dead to the world. When you push any button it should light up and then you can hit the power button to turn it on and select the mode. I don't know if the AC or furnace work but I suspect they do if only the thermostat would power up.
Old 05-20-2015, 07:32 PM   #6
No batteries. As Protag says, it is hardwired.
Old 05-20-2015, 07:41 PM   #7
Originally Posted by jm2 View Post
Jerry,
I flipped all the breakers on and off to no avail. I have a Progressive Industries PT30C 30 Amp Portable Electrical Management System that I use. It will detect voltage issues and it says all is well with the inline voltage. Plus everything else works in the motor home.
Amazon.com: Progressive Industries PT30C 30 Amp Portable Electrical Management System: Automotive
I found Airstream of New England on Airstream's website but it appears they only sell travel trailers. I will give them a call but I may call the factory first to see if they have any suggestions. They have been very helpful in the past.
Old 05-20-2015, 08:27 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
You're looking under the wrong rock!!
Your Dometic CCC II thermostat is powered by 12VDC derived from the upper control board located curb side under the shroud of your roof unit. You're CCC II isn't getting any!! If you remove the inner air distribution box (watch for hidden screws ), you will see a telephone-type cable leading into a small beige (or white) plastic RJ-11 union box.
Chances are that it got overly moist and possibly shorted. Dometic conveniently provided a spare union on a different cable (probably black) leading from the roof unit (this is actually used for serial connections for up to 4 zones from a single t/stat, but you can use either one). Use a hair dryer to dry the connections, and then plug in to the other union.
If you still get nothing, you should check the 3 amp fuse located on the relay control board that is under the upper unit's shroud. If that fuse is good, locate the black and red cabled coming from the upper unit and test with a VOM for DC voltage. If none there, look at your DC fuse block for the fuse marked 'A/C'.
Have fun!
Old 05-21-2015, 06:29 AM   #9
Have fun!
I was hoping you would respond. I will check it out.
Old 05-21-2015, 01:11 PM   #10
Seattle , Washington
no power to thermostat
I had a similar problem with my new 20 ft. No power to entire trailer. Had power coming in all the way to circuit brakers and out from there. It turned out to be the gfi protector in the bathroom tripped and shut down everything!
David O is offline   Reply With Quote
Old 05-21-2015, 03:47 PM   #11
90% of solving any problem is knowing where to look. Thanks to Lewster, I now had that knowledge. And thanks to the AC installation manual, I knew where to look for the screws. There were two on each side at the air intake. Remove the air filters prior to removing the cover. The other two screws were on each end at the horizontal vents.
As Lewster said there were a clump of wires on the curb side. Upon pulling those out I immediately discovered the problem. The phone cable that runs to the thermostat had unhooked from the receptacle. I plugged the wire into one of the receptacles and the thermostat worked. I would guess the primary reason was that someone at the factory did not properly seat them. And the very rough roads we traveled on yesterday from Philadelphia to Boston probably didn't help.
I had previously removed the thermostat from the wall mount in case it was the problem.
Many thanks to Lewster for giving me the information I needed. And now I know how that part of my AI works!!!
Old 05-21-2015, 04:39 PM   #12
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Thanks for the pics. Could come in handy.
Ron_CA is offline   Reply With Quote
Old 05-21-2015, 07:10 PM   #13
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
You should send these pictures to the Airstream folks in Jackson Center.
Old 05-21-2015, 08:57 PM   #14
lewster's Avatar
:c lap:
GOOD JOB!!!
Now I have someone I can send all of my A/C work to!!!
Power Converter & Power Supply Land Shark Batteries, Univolts, Converters & Inverters 8 05-11-2010 09:51 AM
No Power to Thermostat? Bearstream1 Furnaces, Heaters, Fireplaces & Air Conditioning 1 12-20-2009 08:53 PM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 08:07 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
