Old 05-21-2015, 09:13 PM   #15
Kwils25's Avatar
2014 Interstate Ext. Coach
Taylor Ridge , Illinois
This thread is a great example of how awesome this forum is!
Kwils25 is offline   Reply With Quote
Old 05-22-2015, 05:12 AM   #16
Rockwell , North Carolina
Agreed! It was a relief that we didn't have to take the AI somewhere to get it worked on and interrupt our vacation. We have a beautiful lot in this campground and did not want to tear down.Click image for larger version
Name:	ImageUploadedByAirstream Forums1432293120.057531.jpg
jerhofer is offline   Reply With Quote
Old 08-03-2015, 04:09 PM   #17
2018 30' Classic
Rock Hall , Maryland
A slight variation. My thermostat first said E1. I reset the wall unit. It now shows Zone 1(blinking) and Zone 4. Also does not recognize the furnace at all. Fan or A/C does not turn on. I checked the fuses and they all look good. Any advice would be greatly appreciated.
GloryBound is offline   Reply With Quote
Old 08-03-2015, 04:50 PM   #18
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Does the owner's manual for the t-stat say what E1 means?
I seem to recall a discussion of t-stat error messages and what they meant in another thread.
Old 08-03-2015, 05:02 PM   #19
lewster's Avatar
Naples, FL , Hood River, OR
Remove the T/stat from the wall ( pulls out from the bottom) and remove the RJ-11 plug. Wait a few minutes and reconnect.
If that doesn't work, I would next remove the inner A/C air box and look for the RJ-11 union piece. There should be another one close by.
Change the cable coming from the T/stat (provably grey) to the other union and see if works now.
Either you are not getting 12VDC to the stat from the upper relay board, or the board is bad.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 08-03-2015, 06:55 PM   #20
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
No power to thermostat
I had this same problem last week and I have had it several times before, only under extremely hot and humid conditions where the AC is working too hard. That is, I have it set too low. The fix: it's not really a fix but I blundered along and the AC eventually worked, but I do not know what causes the recurring problem. Disconnect the thermostat connections as shown in the preceding photos. Ensure the connections are dry. Reassemble. Perform a system reset. ( press zone and mode at the same time) Reprogram the thermostat. The AC will most likely not work but the fan will. Wait 24 hours and then try the AC. In my case, the AC would now work. I have no idea why but I am guessing that there is some kind of electrical gizmo that resets itself when left alone or the whole contraption has dried out. This works for me until next time I really need AC but is a pain. I am getting a little smarter by not working the AC so hard. Lewster has a real fix by adding a better seal on the AC unit. Jim
Jim Flower is offline   Reply With Quote
Old 08-03-2015, 07:02 PM   #21
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
E1 Loss of communication between the CCC 2 thermostat and all system power
module boards. System will shut down.
E1 LossofcommunicationbetweentheCCC2thermostatandanin dividualsystem
power module board. The LED will display error code EI and the zone num- ber that lost communication. Any additional zones that loose communication will blink in addition to the current zone.
The manual is now on my IPad. Easy to get to. I will have it memorized soon. Jim
Old 08-03-2015, 07:21 PM   #22
2015 30' Flying Cloud
2016 30' Classic
Covington , Louisiana
[QUOTE=Jim Flower;1663188]I had this same problem last week and I have had it several times before, only under extremely hot and humid conditions where the AC is working too hard. That is, I have it set too low. The fix: it's not really a fix but I blundered along and the AC eventually worked, but I do not know what causes the recurring problem. Disconnect the thermostat connections as shown in the preceding photos. Ensure the connections are dry. Reassemble. Perform a system reset. ( press zone and mode at the same time) Reprogram the thermostat. The AC will most likely not work but the fan will. Wait 24 hours and then try the AC. In my case, the AC would now work. I have no idea why but I am guessing that there is some kind of electrical gizmo that resets itself when left alone or the whole contraption has dried out. This works for me until next time I really need AC but is a pain. I am getting a little smarter by not working the AC so hard. Lewster has a real fix by adding a better seal on the AC
Sent from my iPad using Airstream Forums[/unit. Jim
I would add disconnect shore power And place battery disconnect in the store position in order to kill ALL power sources. then wait an hour or so and perform the reset process.
Sjcjr is offline   Reply With Quote
Old 08-03-2015, 07:30 PM   #23
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Sjcgr,
Yes. That was also part of what I did. In my case, it did not seem to work initially, but after leaving it off for a few days between trips, it worked on the next trip out. Jim
Old 08-04-2015, 10:03 AM   #24
2018 30' Classic
Thanks for the info. I disconnected/reconnected and did the reset. I open the top up and change the connectors tonight. Hope it does it as we are on the road and the mobile parts truck is far behind. thanks again.
Power Converter & Power Supply Land Shark Batteries, Univolts, Converters & Inverters 8 05-11-2010 09:51 AM
No Power to Thermostat? Bearstream1 Furnaces, Heaters, Fireplaces & Air Conditioning 1 12-20-2009 08:53 PM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 08:07 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
