Old 12-23-2015, 05:22 AM   #1
2011 Interstate Coach
ISTANBUL , USKUDAR
No electric on aircondition, tv and coffee machine when connected to 110 V shorline?
Hi,
I am using an Interstate 3500.
When I connect the electric system to 110 V Shorline, I have no power coming to ceiling aircondition , tv and coffee machine , even inner lights. Only the electric outlets are working.
But all these devices are working ok with the built in generator , but nothing except electric outlets are powering with shorline.
What may be the problem please?
arifarda is offline   Reply With Quote
Old 12-23-2015, 05:45 AM   #2
Lily&Me's Avatar
Normal , Illinois
Have you checked your fuses, and is your invertor on?
Maggie
Lily&Me is online now   Reply With Quote
Old 12-23-2015, 06:02 AM   #3
ISTANBUL , USKUDAR
Dear Maggie,
Thank you for your reply.
Yes, I've checked the fuses, they're ok and the inverter is on.
But still have no power.
Old 12-23-2015, 06:30 AM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by arifarda View Post
Hi,
arifarda,
You have a device called a transfer switch that selects power from either the shore line or generator. It is a silver box usually located at the rear of the coach against the wall, inside the rear door on the driver's side. Probably behind the black fabric.
I would think that it is defective as it is only allowing the generator to pass thru power.
If you have knowledge of electrical circuits, PM me and I'll walk you thru testing this device.
Good Luck!!
Old 12-23-2015, 06:32 AM   #5
Mjgman's Avatar
2013 Interstate Coach
Bradenton , Florida
Are you sure that you have power? What is your power source?
Did you plug into a receptacle at home? Or a camp ground?
Is it a GFI?
If so it might have tripped or the fuse in your home panel might have tripped when you plugged it in..
Your power cord might be bad..
Mjgman is offline   Reply With Quote
Old 12-23-2015, 06:45 AM   #6
ISTANBUL , USKUDAR
I am using the motorhome in a country where using 220 V shorline.
So I bought an 220 V to 110 V adaptor, regulator and using the shorline with this adaptor.
Old 12-23-2015, 07:02 AM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If you're in a different country, that brings up another possibility. Your appliances require electricity at 60Hz, so if the country you're in provides electricity at some other frequency such as 50Hz, those appliances will not work properly, or possibly not at all.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-23-2015, 07:39 AM   #8
Mjgman's Avatar
Bradenton , Florida
I think that's your problem...
http://www.covingtoninnovations.com/overseas/
Old 12-23-2015, 08:42 AM   #9
Gainesville , Florida
Will My Electronics Work Overseas?
Even if that doesn't help the op, I appreciate the info, very interesting.
Old 12-23-2015, 12:57 PM   #10
73shark's Avatar
Overland Park , Kansas
Does this adapter reduce the 220 To 110? I'd start at the 220 VAC pedestal and start checking voltage at each step along the way.
Old 12-24-2015, 01:42 AM   #11
Cape Coral , Florida
Lew...regarding my 2015 AS Interstate GranTour...I received a factory recall notice about a bonding wire that must be relocated or else it
Could create a fire hazard.
We live 40 miles north of you and at this moment are on a Christmas trip to North Carolina. The local dealer in Florida performed the recall and we were going to leave the next day but
The auxiliary battery wasn't charging properly and we were getting strange battery readings.
I advised the dealership and they said to keep charging the battery and proceed with our trip.
By the time we arrived NC we had lost ALL of our 12 volt system unless we had main engine running. Could not operate heater at night and outside temp dropped to 35 degrees and we froze in Asheville.
Only after begging big time was I able
To get the NC dealer to examine the problem. They spent over SEVEN hours and exclaimed it was putting out 24 volts rather than 12 volts! We ended up with a hotel and rentacar.
It seems to be fixed but I was NOT given an invoice description for the work and I am wondering if damage can occur to the batteries and other systems due to running 1000 miles on
24 volts rather than 12.
You are the guru. What thinkest you?
Jeff
jeffbec51 is offline   Reply With Quote
Old 12-24-2015, 05:49 AM   #12
lewster's Avatar
Jeff
WOW!!!! Incompetence at it's best!!!
The only way you would be getting 24VDC into your coach is if someone rewired your house batteries in series rather than parallel. You should have 2 -12VDC Lifeline Group 24's. One wire at the batteries would do it, unless you have the aux. battery under the hood and they series connected that to your start battery, but that would have taken out your engine's 12VDC systems.
If indeed they did this, I would suspect that most of your 12VDC appliances are toast, but can't be certain. Things like your inverter/charger, furnace motor, A/C control board and t/stat, fridge compressors, etc. Possibly the control on the BIM. Most of these are not dual voltage units and would fry with that much DC being sent into them.
PM me for more info.
THANKS!
How much stuff isn't working????
Old 12-24-2015, 08:17 AM   #13
HowieE's Avatar
Princeton , New Jersey
Images: 12
Lew
If they did in fact have 24 volts on the 12 volt system I would have assumed that any interior light would have blown the second they turned it on.
Like wise if there is no isolation between the coach and TV systems what would 24 volts have done to the TV computer and associated electrical systems?
2004 Excursion 4x4
Old 12-24-2015, 09:21 AM   #14
lewster's Avatar
Since the new Interstate coaches use LED lighting, they usually have an operational range of 9-30 VDC, do I didn't include them in the potential carnage. They also use 120 VAC TVs so they wouldn't get blown out either.
But in reality, ya just never know!!!!
Lew Farber
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
Airstreams body shocks me plugged into shorline power shadeemry Electrical - Systems, Generators, Batteries & Solar 21 06-03-2015 02:41 PM
Convert aircondition Pump to serpintine belt John H. Mechanics Corner - Engines, Transmission & More... 4 07-10-2011 03:49 PM
Electric working with battery not with 110 TX_DB Electrical - Systems, Generators, Batteries & Solar 11 04-24-2011 07:19 PM
No 110 power connected to shore bonginator Electrical - Systems, Generators, Batteries & Solar 3 06-25-2010 07:53 PM
Leaving trailer connected to 110 ac? jglabrown Electrical - Systems, Generators, Batteries & Solar 1 09-28-2006 09:36 AM
