Old 07-16-2015, 08:37 PM   #1
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
No 120 VAC w/ generator or inverter
In addition to the generator dying periodically, sometimes with no load, towards the end of the day the 120 dropped out. When we stopped, I checked all the breakers and reset but no joy. Out of ideas. Grandkids not happy campers with no TVs.
Old 07-16-2015, 09:17 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Sounds like a bad transfer switch if you're not getting any 120VAC into your breaker box from either shore or generator. IIRC, they are located on the driver's side against the exterior wall.
Old 07-16-2015, 09:41 PM   #3
73shark's Avatar
Can't try shore power right now but the transfer switch shouldn't affect the inverter output should it? When I got to our stop in Mobile, I found that manual says the. inverter has a GFI breaker and/or two circuit breakers. Not real clear which. Will look for them in the morning.
Also would the A/C still run if the transfer switch was FUBAR?
Old 07-16-2015, 10:24 PM   #4
lewster's Avatar
In the AI, the inverter has a dedicated circuit for the output, which, if you have the Magnum, has an output breaker on the inverter along with an input breaker. There should also be a dedicated breaker for the inverter on the 120 VAC breaker panel.
Not sure if the Trippite has AC breakers on it.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 07-17-2015, 08:15 AM   #5
73shark's Avatar
I checked both the breakers on the TrippLite and they were fine. I guess I'll have to check when I get home the transfer switch. Thanks
Old 07-17-2015, 08:33 AM   #6
lewster's Avatar
You might have had a power surge that took out your transfer switch AND the inverter fuse. That should be checked also, although they are for the DC side input from the batteries to the positive inverter terminal.
Old 07-17-2015, 11:16 AM   #7
73shark's Avatar
I'll check that also when I get home Saturday. Thanks again. Maybe it is telling me that it's time to get a Magnum inverter.
Just hooked up my little 150W inverter in the 12V outlet by the front TV. That should pacify them for a bit.
Old 07-17-2015, 03:37 PM   #8
73shark's Avatar
Thanks to jpairstream who pointed out the GFI outlet located under the street side passenger seat,I am now powered up fully again.
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
3000W inverter enough for a shop vac? ericpeltier Electrical - Systems, Generators, Batteries & Solar 7 06-16-2015 12:50 PM
120 VAC Outlet for Dometic Refrigerator 50KIP Electronics & Connectivity 14 10-25-2013 10:10 AM
Power outlets - 120 VAC switz 2011 - 2015 Classic (all lengths) 2 10-06-2013 06:42 PM
Electrical changes 120 volt ac FrankR Electrical - Systems, Generators, Batteries & Solar 5 03-13-2005 06:20 PM
