Old 09-15-2013, 01:45 PM   #1
Interstate1's Avatar
2014 Interstate Ext. Coach
Rochester , Michigan
Newbie question on TV
Can't seem to get any power to play DVDs on both TVs in my new interstate? Everything is plugged in and the battery is good. I read the manual and it doesn't mention anything about this... What am I doing wrong, Any thoughts? Thank you
On a side note I can power everything else in the Interstate, just NOT the TVs... It's driving me crazy because I'm sure it's a simple thing to fix...lol
Interstate1 is offline   Reply With Quote
Old 09-15-2013, 01:56 PM   #2
To be more descriptive, I want to play DVDs while I'm driving for my passengers to watch... But i can't seem to get any power. Thanks for any support I get from the Airstream Interstate community
Old 09-15-2013, 02:55 PM   #3
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
It is a safety feature to prevent distracted driving.
When you shift from park the dvd will not play.
A car audio store can install an adapter which allows the dvd to play in drive.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-15-2013, 02:58 PM   #4
Ok, I understand that...however I can't power the TV in park too
Old 09-15-2013, 03:31 PM   #5
Jeff64's Avatar
Springfield , Missouri
I believe the last post is referring to the in dash unit, the TV's will play DVD's anytime. One possibility is to check the 110 receptacle on the wall behind the drivers seat, you may have a tripped GFI and just need to reset it.
Jeff
Jeff64 is offline   Reply With Quote
Old 09-15-2013, 03:53 PM   #6
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
The GFI tripped on me too and it took me a while to figure it out. As soon as I reset it the TV's would work again.
Hope it is that easy for you too. Good luck.
PSchw is offline   Reply With Quote
Old 09-15-2013, 05:57 PM   #7
AtlantaCpl's Avatar
2013 Interstate Coach
Atlanta , Georgia
Interstate1, you must have your inverter set to ON for the TV's to work when you are not plugged into shore power or running the generator.
Brian
AtlantaCpl is offline   Reply With Quote
Old 09-16-2013, 07:06 PM   #8
Thank you...
Old 09-16-2013, 07:09 PM   #9
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Originally Posted by Interstate1 View Post
Thank you...
Did any of the suggestions work? If so which one for future reference.
Old 09-16-2013, 08:22 PM   #10
My inverter needed to be set to ON for the TV's to work when I am not plugged into shore power or running the generator.
Thanks!
