09-23-2013, 05:41 PM
2013 Interstate Coach
Virginia Beach
, Virginia
Newbie
On our first trip the carbon monoxide detector started beeping, we put a fresh battery and still beeping. I finally disconnected it. We have a late model 2012.
Any suggestions would greatly be appreciated.
Thanks in advance.
09-23-2013, 05:55 PM
2014 Interstate Ext. Coach
Sedona
Thanks in advance.
A carbon monoxide warning should be taken seriously since this gas can kill you - silently.
Now, don't panic about it since it''s most likely something you've overlooked.....
It can be caused by anything that's burning fossil fuels such as: the generator - if the exhaust is getting inside for some reason; burning the stove without adequate ventilation - you may need a couple of windows or the fan for a good air flow; or the furnace or the water heater (when using the log gas) may have developed a fault causing the gas to enter the cabin.
Try to remember what was running at the time the detector went off.
Let us know your thoughts.
09-23-2013, 06:08 PM
1984 34' International
Toronto
, Ontario
Carbon monoxide alarms can be set off by the following:
- Solvents, including harsh cleaning products - if it makes your nose wrinkle, it can set off the alarm
- Charging lead batteries, releasing hydrogen - this often happens on boats
- Engine fumes, not necessarily CO
- Ammonia, from pet urine
- Certain cooking smells
- Dog flatulence or skunk smell
You should never ignore a carbon monoxide alarm. If you're concerned that your alarm is faulty, get known good unit to double check. If both alarms sound, look for and eliminate the source.
CO kills.
09-23-2013, 06:34 PM
Newbie
Fort Worth
According to my Airstream Dealer CO detectors should never be ignored but they are touchy and one of the items they end up replacing frequently because of false alarms. I have read elsewhere that CO detectors in the home and elsewhere have limited lifespan and should be replaced every couple of years for safety reasons.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
09-24-2013, 05:17 AM
Virginia Beach
, Virginia
thanks for input,
i think it may be a faulty alarm. the propane has been off, generator has been off, no strong fumes from pets or cleaning products. i just ordered a replacement. thanks again.
09-24-2013, 05:21 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
It's a combination smoke and CO detector. Anything that could be mistaken for smoke can also set it off. Including hairspray, Lysol disinfectant spray, fumes from Easy Off oven cleaner, steam from a hot shower, anything that makes the air less transparent.
09-24-2013, 06:52 AM
2005 39' Skydeck 390 SD
Hillsboro
I had the same on my early 2013. The dealer told me that there is a problem with some of them and replaced it.
09-24-2013, 07:01 AM
2006 Safari SE
Los Alamitos
Nancy: There is a reset button, which if I recall, you hold it for several seconds and it resets. Thus, you don't have to disconnect (cut) the wires. If it resets and operates properly, then the problem is something else. In my case it was a low propane tank, which the sensor picked up. When I switched to a full tank, and reset the sensor, all was good.
Be safe. Robert
09-24-2013, 07:11 AM
2011 28' International
Chatham
, Ontario
I had a similar issue on our 2011 model. The pattern of beeps, single and spaced every 10 seconds or so, wasn't listed by the manufacturer as being any of the set alarms. Replacing the battery didn't change it so I replaced the whole alarm; problem solved.
09-24-2013, 07:31 AM
2008 27' International FB
Petaluma
I still had the manual for my CO2 alarm in my 2008 and the manual says that alarm has a limited lifespan and will chirp when it's usefulness is exhausted. Replace the detector.
Looking for adventure in whatever comes our way.
- Brad
09-24-2013, 01:51 PM
2024 Interstate 19
Fulton
, Maryland
Agree -- just replace the unit. I've had to replace the one in my 2013 Interstate and one in my 3-year old townhome. Nice thing about the residential unit it was guaranteed for 5 year. Not so for the RV units.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
09-24-2013, 07:42 PM
Sebastopol
Agreed, just replace it. I had my old brochure and it said mine only had a 5 year life expectancy, it made it but just barely.
09-25-2013, 09:12 AM
Newbie
Fort Worth
In my experience the inexpensive CO detectors sold at big box stores do well to last two years.
— Navajo saying
09-26-2013, 05:59 PM
Virginia Beach
, Virginia
Thanks for all responses..... My NEW co detector works great.
