Old 03-19-2019, 04:07 PM   #1
2018 Tommy Bahama Interstate
Tucson , Arizona
New Lithium & Solar Upgrade
Just got back from a trip up north to AM Solar. I took the AI up to have them install 600 aH of lithium, 3000W inverter and add another 100W Zamp solar panel plus inumerable goodies that go along. Bank account is definitely lighter but they sure did a fantastic installation.
I told them my goals and basically we squeezed in the maximum that would fit without blocking the little flip down door / passageway (that's the cat's favorite hidey hole) and without taking up any of the rear storage. Other than that, under the seat was fair game.
I had to pay a little extra to have the inverter mounted on the water heater housing vs along side the batteries.
Interesting note, they did a quick test of the efficiency of the new 100W solar panel they installed vs the three factory ones. At the specific time of day the factory solar was producing 10-12 amps but the single Zamp panel they put on was producing 8 amps.
I recorded the full orientation they gave me of the system. It was pretty likely I would forget something, with all the new cutoffs and relays added. It has a lot more gory detail and much longer that I will share if anyone is interested.
I awkwardly made a short summary video to show you all the new system: https://youtu.be/j6hNHle_OYo
ChrisCow is offline   Reply With Quote
Old 03-20-2019, 10:13 AM   #2
2011 Interstate Coach
Muskogee , Oklahoma
Thanks for sharing. Looks like they did a great job.
Interesting to see they used the same solar panel brackets to support the battery together with their tie down straps.
I don't have the extended Interstate, so I have a bit less room. I wish the Victron Inverter/charger didn't take up so much space-space I don't have. I am not sure how they mounted it sideways as it is designed to hang from a bracket in the vertical position.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 03-20-2019, 10:21 AM   #3
Muskogee , Oklahoma
Could you upload the orientation video?
Old 03-20-2019, 10:27 AM   #4
Tucson , Arizona
Here is the orientation video: https://youtu.be/XOHXli1iG2s
It is unedited so your mileage may vary
Old 03-20-2019, 10:36 AM   #5
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
Very nice video demonstrating running the air conditioner on battery power, showing the Victron displays with and without A/C running. This is the kind of information I find very useful and hope you will share in my Solar Show & Tell thread over in the Solar Power Forum. http://www.airforums.com/forums/f448/
Maybe you can describe your new system in the Solar Show & Tell thread and provide a link back to this thread for others to watch your videos?
Thanks for sharing the amazing results of your installation.
2017 Flying Cloud 25FB (Miles) 234 nights 31,732 miles
400W Solar, 230AH 6V Batteries, PD4655 Converter, Champion DualFuel Generator, ProPride 1400# Hitch, 16" Michelin's
2019 F250, 6.7 Power Stroke, 4x4, 1.5" Leveled (Sully)
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is online now   Reply With Quote
Old 03-20-2019, 11:37 AM   #6
Tucson , Arizona
Solar Install Drone Shot
Here is a drone shot of the solar. I apologize for the wiggly video -- it was quite windy and I've only flown this thing a few times.
Old 03-21-2019, 02:16 PM   #7
Muskogee , Oklahoma
Very interesting how they did it.
I would ask them, however, what will protect the alternator from drawing too much current if the battery bank is fully discharged? The Victron ct-li won't. Maybe that's not a concern but I'd sure like to know why it would not be in their opinion because what I've read from others who have a lot more knowledge and experience than me, it certainly could be.
I also always have heard never to mix panels unless they have the same exact voltage characteristics, and I was surprised they didn't use an identical flex panel to keep them all the same. Maybe they do, but that would be very coincidental.
Both are something I would want to know if I had them do the install like yours.
Old 03-22-2019, 06:20 PM   #8
Libertyville , Illinois
Thanks for posting the orientation video. Itís very good to see how they located everything
Schmitte is offline   Reply With Quote
Old 03-22-2019, 10:32 PM   #9
2017 Interstate Lounge Ext
Plano , Texas
Good stuff. Really cool to see the AC running off battery. Will be interested to learn more about how long you can run that and also running it while driving? That is a goal of mine because these things get hot in the south.
Did you remove the 2 AGMs underneath the van?
Tobbun is offline   Reply With Quote
Old 03-24-2019, 10:05 AM   #10
Tucson , Arizona
Originally Posted by Tobbun View Post
Will be interested to learn more about how long you can run that and also running it while driving? Did you remove the 2 AGMs underneath the van?
I expect to be able to run the A/C for at least 3-4 hours cumulatively but Iíll come back to this thread in the future after I get some time with it and post an update. Iíve heard from others that they run the A/C while driving, even the generator!
Yes we removed the 2 AGMs underneath and they also gave me a medium sized box of other factory installed parts they removed, including the inverter.
Old 04-21-2019, 01:35 PM   #11
Burlington , Massachusetts
Battery solar upgrade New England
We have a 2016 AI Grand. Exploring an upgrade to batteries and solar as described in several threads here and looking for reliable service providers in the New England area. Would appreciate any suggestions or experience. Original Lifeline house battery is dead.
sirving is offline   Reply With Quote
Old 04-21-2019, 03:47 PM   #12
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The Victron multi's are quite happy vertical on a wall, flat on a floor or horizontal against a wall. They work slightly better if you don't mount them vertically and pull off the (now un-needed) cap plate.
Guidance on Lithium Ion & Solar ghaag Electrical - Systems, Generators, Batteries & Solar 39 10-31-2018 07:37 AM
My Lithium/Solar Upgrade is Complete ghaag Electrical - Systems, Generators, Batteries & Solar 52 10-30-2018 07:48 AM
Frankís lithium battery and inverter upgrade fran&frank Batteries, Univolts, Converters & Inverters 85 09-04-2018 09:51 PM
1000amp hour lithium + 600 watts solar upgrade report with photos russellt Electrical - Systems, Generators, Batteries & Solar 4 03-22-2018 12:43 AM
600w of Solar and 400 amp lithium charlesk Generators & Solar Power 11 10-07-2016 01:35 PM
