Old 07-25-2015, 10:33 AM   #15
2011 Interstate Coach
Muskogee , Oklahoma
On my 2011, they just ran it with the cables from the antenna and awnings with the cable entry plate. The power comes from the proprietary small box in the front-over the drivers window compartment.
I don't think there is any other entry point for those with the Pioneer camera. However, I'm not sure what they do with the newer models. They may well indeed have an entry point as well and may be wired completely differently, and you could well be right.
Originally Posted by Protagonist View Post
It's glued on, but there should still be an entry hole underneath it. The camera has to get power from somewhere, and signal has to get from the camera to the monitor.
That's not likely to be the source of the leak, though. I only mentioned it for the sake of completeness.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 07-25-2015, 10:36 AM   #16
2013 Interstate Coach
Raymond , Iowa
In follow-up to what Lewster said about the AC gasket: I watched JC try to find a repair a leak in my AI. As part of this they removed the inside plastic cover (two screws are hidden behind the slide-out filters at the front). Instead of simply tightening the screws he backed them out several inches and applied sikaflex to the threads then tightened them down. Apparently they have a tendency to loosen with vibration. Then he proceeded to fix the problem - which was at the vinyl cover where the awning, antenna, and rear camera wires entered the coach. Good luck.
Now I am in process of figuring out where the sliding door window leaks - to try to help guarantee that JC fixes in in one visit and not the two it took to get the aforementioned vinyl cover leak fixed.
Titus is offline   Reply With Quote
Old 07-25-2015, 10:56 AM   #17
K.C. , Missouri
Speaking of these sealants, I wonder if Lewster would comment on Dicor self leveling ? If I'm not mistaken, it is polyurethane based.
gmw photos is offline   Reply With Quote
Old 07-25-2015, 11:11 AM   #18
ben322's Avatar
2009 Interstate
Bethesda , Maryland
+1 on Sikaflex 221. Also check the black flex wiring cover for the awning/antenna/camera wiring. The split cover which makes it easy to install can also be a source of leaks.
2009 Airstream Interstate
ben322 is offline   Reply With Quote
Old 07-25-2015, 11:55 AM   #19
Boxster1971's Avatar
Fulton , Maryland
Lew is AdSeal now being used on new Airstream trailers? If so perhaps they are also using it on the new Interstates and that is causing this rash of new leak complaints.
Just a thought.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Old 07-25-2015, 03:20 PM   #20
lewster's Avatar
Naples, FL , Hood River, OR
Just a thought.
- - Mike
I would not doubt that it is one of the issues with the increase in leaking. That, along with improper surface prep ( read less time spent to do job properly) and a push thru attitude from management and you have the present results.
From what I've seen of AdSeal, it doesn't hold a candle to SikaFlex 221 !!!
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 07-25-2015, 06:17 PM   #21
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Originally Posted by Babybella View Post
Thank you. That was most helpful. Your guess about the air conditioner makes sense. Yes, my repair guy just added more caulk and made an unsightly mess of it. I'm trying someone else for the next attempt at repair who has some supposed leak testing method. And thanks for the welcome. Those other commenters were not very kind.
BB
Which dealer did you purchase from? Have you taken it back to them for repairs?
Ron_CA is offline   Reply With Quote
Old 07-25-2015, 06:54 PM   #22
lewster's Avatar
I don't use Dicor either! It has a very high level of VOCs (volatile organic chemicals) and WILL exhibit cracking in as little as a year, depending on exposure to the elements.
If you're looking for a self-levelling sealant, use either SikaFlex 715 or Alpha Sealants Auto-leveling 1021. The latter is very difficult to find at the retail level, but is now being used by many of the high-end motor coach manufacturers. It is a very high solids compound, which translates into a very thick, durable covering once cured.
And since these both are very LOW VOC sealants, they require an extended cure time....usually a week for full cure, but typically skin over in a couple of hours. Once fully cured, they are extremely durable, will not crack during prolonged weather exposure, and are extremely tenacious in adhering to the bonded surfaces.
In fact, Airstream should be using Alpha Sealants 1021 rather than AdSeal, as it comes in 55 gallon barrels and is especially well suited for volume application in a manufacturing environment.
YOU LISTENING, AIRSTREAM??????????
Old 07-25-2015, 07:12 PM   #23
K.C. , Missouri
Thanks Lew ^^^^^ I will seek out one of those two brands.
Old 07-26-2015, 10:46 AM   #24
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
The repair guy should be the dealer, if not, that may be causing more problems. If still under warranty, I would go to the dealer and insist that every attached item on the roof be removed, gaskets replaced with OEM items, and caulking, if the original factory, be replaced by OEM spec product.
Tom
Tom
AIR 71620
WBCCI 5809 Reg 5 Unit 041
2008 Classic 30'
2013 F150 Ecoboost
tvketchum is offline   Reply With Quote
Old 07-27-2015, 05:49 AM   #25
Kevin245's Avatar
This thread is now open after some housekeeping. Let's keep the vitriolic content at bay moving forward please.
On Behalf of the Site Team
Eleanor Roosevelt
Old 08-05-2015, 10:06 AM   #26
Tigard , Oregon
Raining in our Interstate. Yours Too?
I posted this thread title regarding our 2015 Interstate Grand Tour that has been in the shop going on 4 times for continuous leaks since purchase. Please check that thread for additional information.
"The more you think you know...........The more close minded you will be"
Oldforester is offline   Reply With Quote
Old 08-20-2015, 07:36 AM   #27
2012 Interstate Coach
Elk River , Minnesota
We had a leak in our 'new to us' AI this spring. It drove me crazy as it never leaked when we were driving or parked facing up hill. But it leaked like crazy when we were parked and facing down hill!
I finally figured out the windshield was poorly sealed along the top edge. All the water running off the roof toward the front of the van was coming in thru the windshield.
I ended up having a glass company pull the window and re-seal the entire window. Problem solved.
MN CakeEater is offline   Reply With Quote
Old 08-20-2015, 08:29 AM   #28
Tulsa , Oklahoma
2016 Grand Tour in rain
Have had lots of hard rains by now. Zero leaks.
Bobsprinter is offline   Reply With Quote
Question: Black Interstate or Silver Interstate? Bambino1 Sprinter and B-van Forum 25 03-02-2015 11:45 PM
Interstate :: 2013 Airstream Interstate AtlantaCpl Airstream Registry Discussions 1 09-07-2013 07:12 AM
Mercedes Interstate 22' 3500 :: 2013 Airstream Interstate Suru Airstream Registry Discussions 0 05-05-2013 09:23 AM
'64 Bambi Leaking windows- new owners Sue Mommi Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 05-26-2011 12:30 PM
