Originally Posted by sillyRVmom
My husband and I are differing on batteries and placement. He says the walk through with the dealer specifically said there is a battery under the hood that you see when you open the hood. It is used for backup emergency chassis use only. There is another battery under the drivers feet that you access through the floorboard. This is the main battery that starts the sprinter and makes the lights turn, runs the fridge, etc in the actual house portion. That is all.
I am trying to convince him there is a third battery that controls the house. From reading, it is under the back side seat.
Who is correct?
If you have a battery under the hood that sits on a tray on driver's side you actually have four batteries. The one under the hood is a Mercedes optional Auxiliary
12V battery that only powers the
12V outlet on the inside corner on the driver's seat base. The outlet is under the ultra-leather cover on the seat base. The main starter battery is in a space right under the driver's feet that can only be reached by removing the floor covering and removing the metal cover over the battery. For house power your 2015 LoungeEXT model has two
12V batteries in a metal box under the rear lounge seat on the passenger (curb) side. I'm attaching a diagram of the Lounge model battery box from the 2015 Interstate
parts book available on the Airstream web page under service/manuals tab.
https://www.airstream.com/service/manuals/
- - Mike
2013 Lounge EXT on 2012 Sprinter
