Old 08-09-2016, 05:46 PM   #1
2013 Interstate Coach
Poland , Ohio
New 2013 interstate ext owner help with fuses
My tvs stopped working and had to do some investigating. Thought it was a fuse , turned out to be a tripped gfi receptacle. Please help me understand the fuses the manual is little help. I found fuses under the drivers seat as well as the under the lounge. Not sure what is what.
Docevil is offline   Reply With Quote
Old 08-09-2016, 06:57 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Fuses are for 12vDC circuits. Breakers are for 120vAC circuits.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Old 08-09-2016, 08:45 PM   #3
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I'll bet it was the outlet under to streetside 2nd row seat. Had the same thing happen. Didn't expect a separate GFCI outlet when there was a GFCI breaker under the lounge. Just another little surprise from Jackson Center.
Also some of the outlets are only on the generator/shore power circuit.
Old 08-09-2016, 10:02 PM   #4
Boxster1971's Avatar
Fulton , Maryland
Originally Posted by 73shark View Post
.... Also some of the outlets are only on the generator/shore power circuit.
On my Interstate only a few outlets are powered by the inverter, but all are powered by generator/shore power.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Old 08-09-2016, 10:39 PM   #5
73shark's Avatar
On mine , the two TV outlets and the GFCI outlet under the 2nd row seat were on both the inverter and gen/shore power. The one over the galley and the one near the floor, curbside by the lounge were only powered by gen/shore power.
Never checked to see which ones were on the GFCI ckt breaker but suspect it was the two on gen/shore power.
Old 08-10-2016, 05:12 AM   #6
Poland , Ohio
73 shark, that was it not sure what caused it to trip. At least got to know my rig a little better. The fuse under the lounge seem to be labeled, but those under the front seat are not. Do the little red lights light up if a fuse is blown and what is the black switch or lever next to the fuse do?
Old 08-10-2016, 10:28 AM   #7
73shark's Avatar
Can't help on the switch/lever anymore but I printed out the page w/ the fuse location/description and tucked it in w/ the fuses under the seat and glued to the door under the lounge.
Fuses, what fuses? safariuser Electrical - Systems, Generators, Batteries & Solar 8 04-06-2015 05:52 AM
New 2013 airstream interstate ext touring coach class b mercedes chassis diesel eBay Watch Airstreams on eBay 0 01-26-2014 12:00 PM
New 2013 airstream interstate ext touring coach class b mercedes chassis diesel eBay Watch Airstreams on eBay 0 01-12-2014 08:50 PM
New 2013 airstream interstate ext touring coach class b mercedes chassis diesel eBay Watch Airstreams on eBay 0 12-23-2013 07:10 PM
2013 Airstream Interstate EXT, Mercedes Turbo Diesel Sprinter Motorhome, NEW eBay Watch Airstreams on eBay 0 11-25-2013 06:30 PM
