Old 10-23-2014, 05:59 AM   #1
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Need to Find…
An adapter that will allow for a gas-tight seal between my macerator pump discharge and a standard 4" sewer connection. The so-called "sponge" ring (actually as hard as a hockey puck) provided by the dealer would fit the sewer connection, but wouldn't fit the macerator discharge hose. I'd prefer a screw-on fitting that mates to the threaded plastic ring on around the end fitting on the hose, if anyone knows where I could get one.
My post-retirement travel plans include a couple of parks with full hookups that require a gas-tight sewer connection seal to control odors.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-23-2014, 07:14 AM   #2
Kwils25's Avatar
2014 Interstate Ext. Coach
Taylor Ridge , Illinois
Check with your Airstream dealer. My 2014 came equipped with two different adapters (one is 4") and the rubber ring.
Retirement is awesome, you will really enjoy it.
Kwils25 is offline   Reply With Quote
Old 10-23-2014, 01:16 PM   #3
UKDUDE's Avatar
Sedona , Arizona
If you haven't found anything yet I think the supplied reel and attachments come from Shoreline Reels:
Shoreline Reels® | Technology Research Corporation
I don't see the adapters on their website, but try calling them.
Old 10-23-2014, 01:24 PM   #4
They only make the reels, not the hose or fittings. But thanks.
As a side issue, after looking at their spec sheet, I think I see why retracting the hose is always such a finicky process. The spec sheet says it holds 20 feet of 3/4" hose, but my Interstate has 20 feet of 1" hose. In other words, too much hose for the reel. Hmmmm…
WBCCI #1105
TAC LA-4
Old 10-23-2014, 02:08 PM   #5
UKDUDE's Avatar
Sedona , Arizona
Try this company:
CLEAN DUMP Macerator Systems and RV Accessories
Old 10-23-2014, 03:36 PM   #6
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Protag the "Drip Proof Shut Off Valve" on this web site is what came with my Interstate.
If you also have one it could be modified to be gas tight.
Hope this helps,
- - Mike
- - Mike
Old 10-23-2014, 04:29 PM   #7
Originally Posted by Boxster1971 View Post
Protag the "Drip Proof Shut Off Valve" on this web site is what came with my Interstate. Attachment 224976
Hope this helps,
- - Mike
Mine came with a similar but not identical nozzle, and no sewer cap adapter. Hence the problem. But that one looks like it will work; I'll order one tomorrow.
WBCCI #1105
TAC LA-4
Old 10-23-2014, 06:04 PM   #8
gambita's Avatar
2015 Interstate Ext. Coach
Framingham , Massachusetts
I had same problemClick image for larger version
Name:	ImageUploadedByAirstream Forums1414108912.652168.jpg
The set up was not tight enough and there was leak . I have to put ducttape.
gambita is offline   Reply With Quote
Old 10-23-2014, 06:24 PM   #9
2005 22' Interstate
Pittsburgh , Pennsylvania
These are nice:
Sani-Con Nozzle W/Cap Thetford 70400
Formerly: 2005 Airstream Interstate (2500 T1N)
Now: 2014 Great West Vans Legend SE (3500 NCV3)
avanti is offline   Reply With Quote
Old 10-23-2014, 06:42 PM   #10
Fulton , Maryland
If you need connection to be gas tight it might be best to use a union joint after the shut-off valve and before the large diameter pipe end cap adapter. Then you could make the connection to large diameter end cap a solid glued joint. Something like this would work.
Name:	ImageUploadedByAirstream Forums1414111204.692210.jpg
http://www.zoro.com/i/G5287292
Hope this is useful.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 10-23-2014, 07:02 PM   #11
1999 30' Excella 1000
small town , Maryland
Would a dishwasher adapter work?
streaminwild is offline   Reply With Quote
Old 10-25-2014, 06:20 PM   #12
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Forgive my ignorance; but you still need to go run the pump to empty right?
I stayed in FL for a week at a park like this and was afraid to use the city water connection in fear of over filling my grey tank (easy to take a nice long shower when you don't have to ration water). I refill fresh tank when I empty Black & Grey.
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 10-25-2014, 09:37 PM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Protag..
I have one that has several sizes of pipe threaded on the end.. it sorta tapers. I can get a picture but can't recall the maker... it screws in to every site I have encountered or it will fit as it has an extension on the end of it.. A pic may help.. I actually found it at a KOA campground store...yes, I am surprised too. Do you want me to get you a picture for you? PM please.
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-25-2014, 10:59 PM   #14
Yes, I still need to run the macerator pump to empty the tanks. The only difference is that the hose must screw into the sewer connection, or have one of those donut thingies to seal the sewer connection while the hose is in place. At parks where the campsites are close together, one person's sewer connection is often very close to another person's awning and picnic table, and no one wants to smell sewer gas from their neighbor's open sewer hookup.
WBCCI #1105
TAC LA-4
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 11:01 AM
Need to find A/C wiring on 22 ft Argosy Argosy man Electrical - Systems, Generators, Batteries & Solar 9 09-04-2007 01:50 PM
Need to find a source for "wall cloth" PJM Upholstery, Blinds, Walls & Interior Finishes 6 07-01-2007 12:34 PM
one problem solved..now need to find new burner! JohnGalt48 Water Heaters, Filters & Pumps 8 06-24-2007 02:48 PM
Need to find adaptor to go from this outlet on my generator to shore power line in AS wacnstac Generators & Solar Power 11 04-27-2006 11:49 AM
