Old 10-27-2014, 06:57 PM   #15
gambita's Avatar
2015 Interstate Ext. Coach
Framingham , Massachusetts
I found in home depot a rubber o ring 1 inch in diameter that can fit and i think can make it seal air tight.
gambita is offline   Reply With Quote
Old 10-28-2014, 05:29 AM   #16
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I took Boxster's advice and ordered a new hose fitting and adapters from Clean Dump, which is the OEM source that Jackson Center uses (the Clean Dump rep told me so over the phone). Apparently Clean Dump provides all of the adapters to Airstream with each discharge hose kit, but somewhere between Jackson Center and the dealer sometimes they go missing.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 11:01 AM
Need to find A/C wiring on 22 ft Argosy Argosy man Electrical - Systems, Generators, Batteries & Solar 9 09-04-2007 01:50 PM
Need to find a source for "wall cloth" PJM Upholstery, Blinds, Walls & Interior Finishes 6 07-01-2007 12:34 PM
one problem solved..now need to find new burner! JohnGalt48 Water Heaters, Filters & Pumps 8 06-24-2007 02:48 PM
Need to find adaptor to go from this outlet on my generator to shore power line in AS wacnstac Generators & Solar Power 11 04-27-2006 11:49 AM
