Old 10-03-2013, 10:07 AM   #15
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I bought a portable combo jumper box and compressor at Sams Club last year.Works great for winterizing my Airstream for blowing out the lines,plus the 12 volt jump start feature is handy to have.Wont leave the house without it......$59.00
Old 10-03-2013, 02:47 PM   #16
Interstate1's Avatar
2014 Interstate Ext. Coach
Rochester , Michigan
I really like the 8pc. Portable Air Compressor by Craftsman... I'm going to pull the trigger and get it. Thanks for your help!
Interstate1 is offline   Reply With Quote
Old 10-04-2013, 06:04 AM   #17
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Originally Posted by PharmGeek View Post
cwf...yeah, I may consider a jump pack ......which one do you have?
Howdy!
I have a Schumacher. It is similar to this
http://mobile.walmart.com/m/phoenix;...04?type=search
I hope you can see it on the website. It is a sealed battery, charges on household 120v extension cord. It has status lights. All I need for running compressor. Obviously it won't run as long as a car or deep cycle battery, but I just haul it around vehicles.
Another option for air volume is a portable tank. You full with compressor then just carry it around. With adapters you can run air tools briefly if needed.
So it is compromises. Just life.
One friend installed a heavy duty compressor and tank on his truck. Just add hoses if proper length and off you go! Cost prohibitive. But he was runnin Mudder tires and woul let air out for better off road traction. When re entering hard road surface he would air up. This way while he was playing off-road the tank was being recharged. Again, compromises.
I like idea if having "another power source". Good for jump starts, filling kiddie pool toys, has built in work light, etc. you can use around house too.
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-09-2013, 08:23 AM   #18
nesoutlook's Avatar
2013 Interstate Coach
Boca Raton , Florida
Originally Posted by Protagonist View Post
I use a Craftsman 1.5-gallon compressor that I bought at K-mart. Less, than $100. About 25 pounds. Convenient cannister shape that you can carry easily in one hand. Produces up to 150psi, with a built-in adjustable regulator.
I just bought the Craftman 1.5 gallon compressor. Fantastic. Thanks Protagonist
nesoutlook is offline   Reply With Quote
