Old 09-01-2014, 12:16 PM   #1
Bty
Anchorage , Alaska
Need help: first time Interstate user
It is my first time to drive and use my 2014 1/2 interstate unfortunately i did not have anytime to read manual or any orientation from dealer so having hard time now it is all my fault anyway
Indicator shows my grey tank is almost full how can i drain it? Just turn on macerator switch and hose on open position?
Bty is offline   Reply With Quote
Old 09-01-2014, 12:30 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Welcome to the AirForums!
To empty the gray tank, open both compartments on the driver's side around the middle of the vehicle. The higher compartment contains the valve and pump controls. The lower one contains the macerator pump's discharge hose.
Unreel the hose. All of it, even if the dump station or sewer hookup is closer.
Open the valve on the end of the hose.
Since you have to dump the gray tank anyway, dump the black tank as well, and do it before the gray tank. To do this, open the black tank valve by pressing on the switch in the other compartment. Hold the switch until you hear the whining noise stop; that tells you the valve is fully open. You should hear a bit of gurgling as well, as fluids run down to the macerator pump.
Turn on the macerator pump, and watch the fluids travel through the hose. The hose is partially clear for a reason, so you can see when the pump has run dry. As soon as the pump runs dry, shut off the pump. Close the black valve.
Now repeat for the gray tank.
When retracting the hose once you're done, be very careful. One hand on the hose to guide it back onto the reel, one hand on the reel switch. Only retract the hose a bit at a time, and if it seems like it's going to jam, don't force it. Unreel a bit of hose and try again.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-01-2014, 12:33 PM   #3
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Welcome to the forum and to the small contingent of Interstate owners in Alaska.
This would be a good time to start reading your manual. You should find step by step instructions for draining the tanks in section G of the Airstream manual. Notice the part that says to drain the black tank first then the gray tank.
Good luck!
Wayne
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 09-01-2014, 12:44 PM   #4
Bty
Anchorage , Alaska
Thank you so much i am in homer AK now i hope somebody in AK can teach me all things I need to learn hahaha
Old 09-01-2014, 03:19 PM   #5
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
There is certainly a lot to learn! I have 4+ years and 28K miles with mine and I learn something new every time I take it on a trip.
If you see yourself heading to Anchorage, PM me on here ahead of time and maybe we can connect.
Wayne S.
- wayne
AIR #44779
TAC AK-1 !!
Old 09-01-2014, 03:23 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Seriously, start with you manual and the packet of material that Airstream included. It will at least get you pointed in the right direction.
MICHAEL
Old 09-01-2014, 04:20 PM   #7
Bty
Anchorage , Alaska
On the way back to anchorage now
Old 09-04-2014, 02:14 PM   #8
AWCHIEF's Avatar
Images: 33
Bty, got around to actually reading the supplied manual and other material supplied with your Airstream?
MICHAEL
Old 09-04-2014, 06:39 PM   #9
Bty
Anchorage , Alaska
Sorry not really
Old 09-05-2014, 04:20 AM   #10
Lily&Me's Avatar
Normal , Illinois
You want to do that, Bty.
You learn a lot by doing, sometimes with the manual, step-by-step.
There won't always be someone available here to walk you thru something.
Maggie
Old 09-05-2014, 07:00 AM   #11
AWCHIEF's Avatar
Images: 33
I must say I am a bit baffled why someone would not take advantage of the resource supplied by Airstream. If I was the suspicious type I would suspect something was a little fishy here.
MICHAEL
Old 09-05-2014, 01:57 PM   #12
Lily&Me's Avatar
Normal , Illinois
I had that thought, too, Michael.
Hard to imagine a dealer letting a new owner leave without the orientation, or a new owner picking up and leaving with such an expensive item with no idea how to use it.
However......stranger things have happened.
Maggie
Old 09-10-2014, 05:08 PM   #13
Jeff
jkinglet's Avatar
2013 Interstate Coach
Seattle , Washington
Images: 37
Welcome. One tip about the macerator hose. On warranty the AS dealer suggested cutting about a foot off the end of the hose so it fit better when retracted. Because of the the extra length from the factory the hose kinked and cracked where the metal clamp held the drain nozzle. Not all of the hose fit on the spool so I originally was forced to tightly bend it upon retraction so it fit in the compartment. Fits snug now without the extra pressure on the clamp attachment.
jkinglet is offline   Reply With Quote
Old 09-10-2014, 11:08 PM   #14
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Funny. Had mine a year and just cut 6" off because it cracked from folding it to fit. Maybe I'll take 5-6" more off so it fits better.
Mike
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Long Time RVer, first time Airstream(er) Lucas S Member Introductions 4 03-19-2014 03:39 PM
Frisco, TX - Long time lurker, first time poster johnfmiller Member Introductions 11 06-08-2011 07:50 AM
First Time and Full Time! JRoss3030 Member Introductions 9 03-20-2010 11:28 PM
new airstream user, first time tripping Nomadness Our Community 6 10-20-2009 05:46 PM
first-time poster.....long-time reader ("lurker") happyfella Member Introductions 3 08-21-2006 08:55 PM
