Old 06-20-2015, 10:04 AM   #1
2009 22' Interstate
Lake City , Michigan
mystery In Dash Message
Indash messages: My 2008 Freightliner / 2009 Airstream Interstate "Operating system with steering wheel buttons" has a message that says, "AUX-LAMP ACTIVE" No one can tell me what it means let alone correct it and remove it from the messages! The dealer said their computers aren't getting any reading when they plug in. The only service I have had recently is the rear backup camera was replaced and a Wilson cell phone booster antenna was installed. HELP!Click image for larger version
Name:	ImageUploadedByAirstream Forums1434812359.916563.jpg
jpkski is offline   Reply With Quote
Old 06-20-2015, 10:39 AM   #2
Gainesville , Florida
Can't remember but does your third brake light have a switch under it for a cargo light? Been too many years!
avionstream is online now   Reply With Quote
Old 06-20-2015, 11:33 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
"Proch-type, sliding door light" may not be turned off. There should be a switch, or has been on several I have been in and around, that turns the light on. The light itself may be the step light.
Old 06-20-2015, 12:00 PM   #4
2009 22' Interstate
Mystery message: Avionstream & Overlander63 Thank you for your suggestions. No switches or lamps around the third brake light. The entire step / awning wiring was replaced last year after numerous problems. The assembly is all electronic now. No more switch. no more problems! Thanks again. Still open to suggestions.
Old 06-21-2015, 03:59 PM   #5
2015 Interstate Ext. Coach
Chicago , Illinois
Hi, I just had a similar problem with my 2015 Interstate where my indicator showed my tail lamps and parking lamps being out right after I had an alarm installed. I took it back to the installer who solved the problem by installing diodes on each wire for each lamp. He said that normally only one is needed but Mercedes installs are different. Hope this helps
buz118 is offline   Reply With Quote
Old 06-23-2015, 08:40 AM   #6
2009 22' Interstate
Buzz118; Thank you. I'll let the dealer and installer know. So far no one has been able to figure it out.
Old 06-23-2015, 12:04 PM   #7
2009 22' Interstate
Thanks for everyone's input. The problem turned out to be a clipped light switch wire when they were feeding the antenna wire through the firewall. No one knew or figured out how or why the message popped up on the dashboard message. Once the light switch wire was fixed the message disappeared.
Dash Repair Questions JW84345 Airstream Motorhome Forums 15 07-15-2012 09:59 PM
AS280 - Mystery Button on Dash dalefox Classic Motorhomes 42 03-15-2011 06:24 PM
Mystery light on 1982 280 Excella Dash jisom12 Classic Motorhomes 9 09-14-2008 03:33 PM
Dash A/C PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 32 08-10-2003 05:39 PM
1982 dash alfalsetto Airstream Motorhome Forums 0 10-31-2002 10:32 PM
