Old 08-31-2013, 03:49 PM   #1
AtlantaCpl's Avatar
2013 Interstate Coach
Atlanta , Georgia
Moving Propane switch in an Extended model
Hello, I found Gerald's excellent guide for moving the propane switch but mine is an extended and I have a wardrobe closet between the instrument panel and the bathroom. I was curious if anyone else has fished the 10 gauge wire back there and if it is difficult?
I'm almost tempted to relocate the inside switch to the rear wheel well and just remove the cup older to flip it from the inside. It's only a few feet straight up from the current location outside. But it would look cleaner in the instrument panel. Getting lazy so thought I would see what others with an extended had done.
Brian
AtlantaCpl is offline   Reply With Quote
Old 08-31-2013, 10:00 PM   #2
2011 Interstate Coach
Muskogee , Oklahoma
The wardrobe is also in my model between the instrument panel and shower. Just remove the screws from the top materials and pushing it down and out of the way so you an thread it to the corner of the shower.
Gerald
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 08-31-2013, 11:45 PM   #3
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
I'm taking a slightly different approach. As delivered to me, my Interstate had two banks of three switches mounted just inside the sliding door (on the forward side of the shower/lav module) and one of the switch positions was blank. So I purchased another matching rocker switch to mount in the blank position; this one will be used for the propane shut off. I will be doing the wiring in a couple of weeks when I travel from AK to OR to do some Interstate projects.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 09-01-2013, 04:41 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Scratching the itch of curiosity, which switch do you not have? On mine, the six switches, left to right as you look at them, are:
1 - Exterior light
2 - Step lock (wired backwards, up = off)
3 - Tank heaters (switch is lighted red when on)
4 - Courtesy lights (step light and floor-level night light by the LPG detector)
5 - Bathroom light
6 - Main interior lights
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-01-2013, 05:41 AM   #5
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
I'm missing #2. I rigged a simple non-elegant mechanical defeat on the plunger switch that detects door open/closed. I have it defeated almost all the time to save wear & tear on the motor & mechanism. Reasoning; I'm only 72 and I might need the step when I get old
- wayne
AIR #44779
TAC AK-1 !!
Old 09-01-2013, 08:53 AM   #6
73shark's Avatar
Overland Park , Kansas
Brian
Why 10 gauge wire? I think the propane valve only draws about 1 amp.
Old 09-01-2013, 10:18 AM   #7
Slightly less. Usage is 18 amps in 24 hours, or thereabouts.
WBCCI #1105
TAC LA-4
Old 09-01-2013, 10:31 AM   #8
73shark's Avatar
3/4 amp rounds to 1 amp.
Old 09-01-2013, 10:44 AM   #9
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Re. the wire size question; 16 ga would be more than ample. 10 ga is a serious overkill!
- wayne
AIR #44779
TAC AK-1 !!
Old 09-01-2013, 10:48 AM   #10
73shark's Avatar
My point exactly.
Old 09-02-2013, 01:51 PM   #11
AtlantaCpl's Avatar
Atlanta , Georgia
I was just going from the instructions in the guide where it says to use 10 gauge. Good to know I can get away with 16 gauge since that will be cheaper and much easier to work with.
Thanks for pointing this out everyone.
Brian
Old 09-02-2013, 01:59 PM   #12
David M's Avatar
Orange County , California
Brian
I used 10 ga as instructed. Besides, it was easier to push down behind the shower
David
David M is offline   Reply With Quote
Old 09-02-2013, 03:41 PM   #13
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Brian
What instructions? In what guide? I thought we we just talking about adding a switch?
- wayne
AIR #44779
TAC AK-1 !!
Old 09-02-2013, 03:58 PM   #14
73shark's Avatar
One of the forum members posted some instructions on how he did it over on the Yahoo version of this forum. Its complete with pictures and narrative.
