Old 06-27-2015, 06:58 PM   #1
2015 Interstate Ext. Coach
Tulsa , Oklahoma
Mounting Camco Olympian 5500 grill
Help on this one...this grill has rail you mount to side if coach (small, chrome channel rail). The bracket holding grill slides in it and has foot brace on side of coach.
Question...I have to attach channel to coach. What is safe place to do that? Any ideas? Thanks
Bobsprinter is offline   Reply With Quote
Old 06-27-2015, 07:51 PM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Take a look in this thread. May give you some ideas:
http://www.airforums.com/forums/f240...ns-136565.html
www.nesa.org
Air No. 6427
Old 06-27-2015, 08:35 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I can't help you with mounting on an Interstate, but where did you get a "chrome" rail. Mine is white powder coat and I want a silver one to put on my trailer.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 06-28-2015, 05:10 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The passenger side rear door should be a good place. That keeps the grill out from under your awning. You could use the grill with the door closed or open 90 degrees. If you want to bolt the rail to the door it's easy to remove the inside panels on the door as well.
Old 06-28-2015, 02:44 PM   #5
2005 22' Interstate
san clemente , California
Absolutely agree with Protagonist. It's the safest, smartest, easiest access and you have room to backup the bolts with a bar on inside of door and hidden by the inside panels.
unifreck is offline   Reply With Quote
Old 06-28-2015, 04:06 PM   #6
I should have said that about the backer bar. Through-bolted, locknuts, and when you drill the holes for the bolts, don't forget to paint the cut edges of the holes to prevent corrosion!
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-28-2015, 09:09 PM   #7
Tulsa , Oklahoma
Nthanks for advice!
As usual, mr protagonist, your advice is terrific. That's what I'll do.
BTW, I haven't opened box yet and I read strip was chrome, but I don't know that for a fact yet.
TMS 5500 lb Trailer ELECTRIC Power Dolly RV Mover Boat drkschoi Hitches, Couplers & Balls 2 07-03-2013 09:46 PM
Camco RV Stove Top Cover White Universal Fit clicknathan Interior Restoration Forum 0 02-08-2013 05:24 PM
Is Camco 59003 / TPA ACR6 regulator adjustable? DKB_SATX LP Gas, Piping, Tanks & Regulators 0 09-03-2011 11:35 AM
Camco Camper Drain Trap? brattwurzt Plumbing - Systems & Fixtures 1 08-20-2011 11:17 AM
Camco Tornado Tank Rinsers beaubayou Waste Systems, Tanks & Totes 3 03-23-2008 01:53 PM
