07-21-2017, 02:45 PM
2020 27' Globetrotter
Taylor Ridge
More on the Subject of Bio Diesel
As a resident of Illinois, I'm very sensitive to the scarcity of gas stations that sell straight diesel fuel. I just stumbled upon the commentary at the attached link. The OP cites a communication from Mercedes to owners of their diesel vehicles. If it's accurate, it's good to know.
http://www.cleanmpg.com/community/in...threads/50136/
07-21-2017, 05:34 PM
Bellevue
Thanks. That is a shorter version of a bulletin Mercedes had put out which another kind member post it here recently. Don't remember the original thread but I put a link to it at my forum: http://audiosciencereview.com/forum/...des-benz.1799/
Now I am going to go and check the engine oil level.
07-21-2017, 09:31 PM
Taylor Ridge
Thanks for sending the link
07-21-2017, 10:07 PM
1978 31' Excella 500
Genoa
, Nevada
Just wondering, is there a fuel additive that I could put in my tank to counter act the Bio problem, similar to the additive I use for cold weather anti gelling and lift pump lubrication?
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
07-22-2017, 04:37 AM
Mantua
, Ohio
Now that's a thought! Anybody know?
07-22-2017, 09:22 AM
Taylor Ridge
I'm not aware of any such product.
07-22-2017, 02:37 PM
2024 Interstate 19
Fulton
, Maryland
I wonder if the bio-diesel issues didn't also contribute to the Mercedes decision to drop diesel cars and SUVs from the USA market this year. Uncertain if they will bring them back. They also dropped the 4-cylinder diesel from 2017 Sprinters. Now the only Mercedes diesel available in USA is the 3.0L V-6 Turbo-Diesel in Sprinters like our Interstates.
http://www.motortrend.com/news/merce...sels-for-2017/
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
07-22-2017, 03:39 PM
Bellevue
Pretty amazing development. I suspect they are worried that there may be more cheats in their engine control than even they know! Good to hear Sprinter continues or I would be worried about long term parts availability.
07-22-2017, 06:00 PM
Anna Maria
I too live in Ill Chicago Metro Area and I have no problem finding straight diesel along any of the Interstates. In the Chicago area you will have trouble finding BIO diesel. I don't use it at all in my Ford 6.7 Diesel engine.
07-23-2017, 12:15 PM
2024 Interstate 19
Fulton
, Maryland
With the Illinois bio-diesel mandates I find it interesting that you think you are buying straight non-bio diesel. I contend that the supply chain is full of bio-diesel in those regions where it is mandated by the government so your chances of finding nonbiological diesel are slim.
- - Mike
07-23-2017, 01:56 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
It probably helps that the Chicago diesel supply chain owes as much to the Great Lakes as it does to rail, road, and pipeline. But that's just an educated guess, not a proved fact.
07-23-2017, 03:46 PM
Taylor Ridge
My local Casey's General Store has a decal on the diesel pump reading 'Non-Bio'. I'm still very skeptical knowing the incentives Illinois has put in place. I much prefer to fill up out of state.
07-23-2017, 07:46 PM
2013 Interstate Coach
Waterloo
, Iowa
I try not to get fuel in Illinois - I believe they have a biodiesel mandate (B5? B10?).
Biodiesel actually improves lubricity a bit - helping to offset the lower lubricity of ultra low sulfur fuel. So biodiesel is not all bad.
High pressure common rail fuel systems can tolerate some biodiesel -somewhere between 10 and 20%. Engine manufacturers would prefer B0 but most accept the reality of biodiesel incentives and (begrudgingly) allow up to B10 or B20 as long as the B100 feed stock meets ISO standards.
07-23-2017, 07:56 PM
From All Over
And remember, half a tank of B0 plus half a tank of B10 equals a full tank of B5. So if you always just fill up the top half of the tank instead of waiting for the "low fuel" warning to fill up the whole tank, you're less likely to end up with a concentration of biodiesel that will exceed the capabilities of the DEF system to treat.
That's an important point to keep in mind: The engine can handle higher percentages of bio in your diesel. The DEF system can't. Not without expensive replacement of sensors and possibly reprogramming of computer chip firmware, anyway.
07-23-2017, 08:20 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
The big 3 truck stops all have 5% to 20% bio-diesel . The big rigs engines are having lots of issues with bio-diesel. Many of the smaller diesel engine service shops along the interstates are making extremely good money getting a contaminated by bio-diesel engine operating again.
I avoid bio-diesel for both my 2012 Cummins and the two Mercedes with the 3.0L V6 turbo-diesels (2007 ML320 CDI and 2009 E320 Bluetec and both do NOT have DEF).
07-23-2017, 08:42 PM
2005 31' Classic
Gretna
, Nebraska
I have used biodiesel only one time.
It dropped mpg significantly. I avoid it.
07-23-2017, 09:06 PM
From All Over
That shouldn't happen. Not saying it didn't, just that it shouldn't. The energy density (BTUs per gallon) of B20 biodiesel is 99% of the energy density of straight B0 ultra-low-sulfur diesel (ULSD). You shouldn't see much difference in fuel economy, if any, for any bio percentage of B20 or less.
In fact, the energy density of B100 is still 93% of the energy density of B0 ULSD.
The equation is different for gasoline vs. ethanol. E10 has 97% of the energy density of E0 straight gasoline. E85 only has 73% of the energy density of straight gasoline. So increased percentages of ethanol should cause a huge hit in fuel economy.
07-23-2017, 11:12 PM
St Augustine
Our Jeep Liberty CRD runs great on B100. I wish I could find it more than rarely.
07-24-2017, 04:59 PM
2024 Interstate 19
Fulton
, Maryland
Good tip Protag. This is another reason I always drive on top half of my fuel tank.
But I respectfully disagree with your comment on bio-diesel impacting the DEF (Diesel Exhaust Fluid) system, aka AdBlue in Mercedes lingo. As far as I know there is no relationship between using bio-diesel and the DEF used in the SCR (Selective Catalytic Reduction) system.
http://www.dieselexhaustfluid-urea.com/scr-technology/
There certainily are other impacts from use of bio-diesel in a Mercedes diesel and they are summarized in this Brochure from Mercedes USA, which has been posted on this forum in the past.
https://www.mbusa.com/vcm/MB/Digital..._Brochure5.pdf
- - Mike
07-24-2017, 05:33 PM
2008 25' Classic
Full Time
It's crazy Mercedes doesn't rate their diesel engines for between B5 and B20 in this day and age. Too much a hassle trying to find straight diesel when towing. If GasBuddy showed stations with straight diesel it would be a nice feature. If you asked the station attendants what is in their diesel they don't have a clue. One week they get a shipment of B20 and the next B5. Crazy.
Basically, don't buy a diesel if it can't handle up to B20 so I guess that means anything built on a Sprinter or Mercedes chassis.
Kelvin
