Old 10-26-2014, 02:30 PM   #1
kaylorsan's Avatar
2012 Interstate Coach
Los Gatos , California
More counter space
It is sometimes a little crowded when preparing meals in the Interstate. To make more space, I added a pullout shelf under my wardrobe. It's on drawer sliders and locks into place when closed. It's about 17 x 17 inches and adds a surprising amount of additional work space. Click image for larger version
Name:	ImageUploadedByAirstream Forums1414355202.281242.jpg
ID:	225150Click image for larger version
Name:	ImageUploadedByAirstream Forums1414355237.145769.jpg
ID:	225151Click image for larger version
Name:	ImageUploadedByAirstream Forums1414355322.255159.jpg
2012 Interstate EXT
kaylorsan is offline   Reply With Quote
Old 10-26-2014, 02:44 PM   #2
Lily&Me's Avatar
Normal , Illinois
That's pretty cool!
Are you for hire? People are going to want to know.
Maggie
Lily&Me is online now   Reply With Quote
Old 10-26-2014, 03:23 PM   #3
batman's Avatar
1964 22' Safari
modesto , California
Great idea. Good job on the install, it looks sweet.
batman is offline   Reply With Quote
Old 10-26-2014, 03:35 PM   #4
2014 Interstate Coach
That's beautiful and a great idea. If you're willing to sell them, sign me up. Otherwise, can you share what kind of wood you used? Maybe I can get some more handy than me to build me one. Thanks for sharing.
migriffin is offline   Reply With Quote
Old 10-26-2014, 03:47 PM   #5
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Looks great and really enhances the space. I was thinking about something like it but again did not go be one thinking.
I turned the door so I can open it and reach inside even when the bed is up as well as put a mirror in the inside for the misses heir procedure in the morning.
PSchw is offline   Reply With Quote
Old 10-26-2014, 03:49 PM   #6
Figment of My Imagination
Protagonist's Avatar
I sure could use one of those! If you're accepting commissions, could you do a "light camel" version?
And one question… what kind of weight capacity does it have?
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-26-2014, 04:43 PM   #7
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
Good idea. Was standing in my unit today commenting on lack of prep space.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 10-26-2014, 05:10 PM   #8
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Great job! What kind of wood did you use for the exposed trim?
Ron_CA is offline   Reply With Quote
Old 10-26-2014, 09:38 PM   #9
Boxster1971's Avatar
Fulton , Maryland
Great job! I also added a pull-out drawer under my curbside wardrobe, but it's for a place to charge our mobile devices. Click image for larger version
Name:	ImageUploadedByAirstream Forums1414380913.781966.jpg
For the countertop extension I made this from a sheet of stainless steel and plywood. The edge trim is solid oak with black wood stain and three coats of poly. Click image for larger version
Name:	ImageUploadedByAirstream Forums1414381089.065373.jpg
ID:	225201Click image for larger version
Name:	ImageUploadedByAirstream Forums1414381099.767268.jpg
- - Mike
2013 AS Interstate on 2012 MB Sprinter
- - Mike
Boxster1971 is online now   Reply With Quote
Old 10-27-2014, 12:40 PM   #10
PSchw's Avatar
Livingston , Texas
Another great idea. Thanks.
I guess work will never stop.
Peter
Old 10-30-2014, 04:35 PM   #11
kaylorsan's Avatar
Thanks for the feedback everyone. Glad that you like it. Boxster, I like your setup also.
For those who have asked:
- I ordered a set of RV drawer slides (they have a detent to keep the shelf closed in the retracted position). I ordered from wwhardware.com ($28 KV 8400 RV Full Extension with Stay Close 18" with side mount hardware)
- I picked up a small piece of 3/4 inch (~24"x 20") finish grade 3/4" plywood and had it cut to approximately 16.5"x 17.5 inches (from what I can recall) $22
- I had an extra strip of 1 3/4 oak trim (I used that for the front and side face)
- Picked up a can of Onyx colored stain $5
My initial thought was that I would give it a shot and if it worked out well, I'd likely order a piece of the counter top material to use instead of the plywood. However, now that it is in, I'm going to stick with the wood.
I'm not sure of the max weight, but I've had a big pot of water and a few bottles of wine on it (35 lbs?) and it did just fine.
If I were to redo it, I'd add a bottom to it and use bottom mount slides (versus the side mount slides) and go with the 'soft touch' open/close slides to add a little extra 'cool factor' to it. It would take a little extra vertical space, but would also provide a 'lock' in the extended position as well as the retracted position.
2012 Interstate EXT
Old 10-31-2014, 09:00 AM   #12
Fulton , Maryland
Kaylorson - Thanks for the extra details a very nice project. I too have found that using black/ebony wood stain on oak or teak can come close to matching the Airstream onyx interior. FYI there is a Wilsonart laminate called Asian Night that is a perfect match to the Airstream laminate.
http://www.wilsonart.com/residential...sku=7949&btr=1
Also the countertop is a Corian solid surface product called Hazelnut.
http://www.dupont.com/products-and-s.../hazelnut.html
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 10-31-2014, 11:32 AM   #13
Denver , Colorado
Wow, very handy - both the feature and you. Nice work.
ukulele2010 is offline   Reply With Quote
Old 11-10-2014, 09:27 PM   #14
Glamper1's Avatar
Hi
I know this thread isn't about upholstery but I see that you have the light color
I believe it's called oyster. I have the same. Have you found a good cleaner that works well.
Same question for the walls of the unit that loo great but smudge easily.
Thank you
Ben
Glamper1 is offline   Reply With Quote
Lack of Counter Space – 19ft. Bambi Air88 Cabinets, Counter Tops & Furnishings 13 09-12-2014 08:19 AM
See more. Do more. Live more...? Mike91208 Airstream Lifestyle 2 01-26-2012 06:56 AM
Counter top space Gsnedike Cabinets, Counter Tops & Furnishings 2 08-22-2011 06:04 PM
more storage space joqin 1965 Caravel 4 06-24-2007 03:41 PM
Interior help desired - We need more sleeping space Curtis-79MH General Interior Topics 3 03-19-2002 06:08 PM
