Old 10-12-2014, 10:20 AM   #1
bennu36's Avatar
2012 Interstate Coach
Portland , Oregon
Microwave or faucet
So the kitchen faucet as gotten kind of loosey goosey. I can sort of get a hand in there if I take the plastic cup off the door directly under the sink. But to get any kind of tool on the nut it would be easier I think if I got the microwave out. Any one know how to do that ? I think it would envolve first aking off the surounding bezzel but I cant seem to figure that out.
bennu36 is offline   Reply With Quote
Old 10-12-2014, 10:44 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are referring to the nuts that hold the faucet to the counter top you need a basin wrench to reach them. A couple of bucks for the Chinese one at the big box store. As comes in handy on many hot water heater drains that ae hidden behind the gas pipe.
2004 Excursion 4x4
Old 10-12-2014, 11:08 AM   #3
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
The screws to remove the microwave bezel are hidden by little plastic caps that can be popped out using a thin instrument.
If the basin wrench doesn't work, you might check to see if the sink can be removed to get access to the faucet.
Old 10-12-2014, 12:43 PM   #4
Figment of My Imagination
Protagonist's Avatar
That would certainly do it, if there's enough slack in the lines. After all, since the faucet is attached to the sink…
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-12-2014, 12:48 PM   #5
HowieE's Avatar
Images: 12
If you end up removing the sink you can disconnect the supply tubes to the faucet easily before lifting the sink out.
but if you are small and can fit the wrench will do it.
2004 Excursion 4x4
Old 10-12-2014, 05:37 PM   #6
Jeff64's Avatar
2014 Interstate Ext. Coach
Springfield , Missouri
The bezel you're referring to is attached to the microwave with two metal straps. No need to try and remove it, just remove the screws around the front of the microwave/bezel, the whole thing will slide right out and give you great access to the sink.
Jeff64 is offline   Reply With Quote
microwave compared to a convection microwave. Happycampers Airstream Motorhome Forums 6 02-23-2016 10:58 PM
Anybody replace their microwave to convection microwave in a 16 sport scamp 2005 and newer - Bambi all models 0 07-10-2014 04:34 AM
Faucet replacement/upgrades Silvertwinkie Sinks, Showers & Toilets 4 03-13-2003 07:19 AM
Another faucet question--no hot water... heyskipper Sinks, Showers & Toilets 3 03-13-2003 06:06 AM
Kitchen Faucet Repair niftypkg Sinks, Showers & Toilets 13 09-27-2002 05:02 PM
