Old 06-12-2019, 01:56 PM   #1
Bristol , Vermont
Mice in 2006 Interstate walls
Can anyone provide any information on where mice may be getting into my 2006 Interstate Motorhome walls? We believe they are getting into the walls then getting into the camper. But we haven't been able to figure out where they're getting in. We removed a panel and have found droppings in the insulation. We believe we're plugged any other place to keep them out.
Any information on experience you've had would be appreciated.
Is there some strange place someone has had experience discovering as a mouse potential entry point?
Donna Foxxx is offline   Reply With Quote
Old 06-12-2019, 03:34 PM   #2
2012 Avenue Coach
Corpus Christi , Texas
Wow. That's a disappointing problem to have.
I do not have your model, but due to generator and engine exhaust fumes, there should be no openings to inside of your van. That being said, factory holes drilled for water pipes, drain pipes, an electrical holes could have lost their spray foam sealant and left a small opening (which is all they need to enter).
If an inspection crawling from below has not revealed an entry point, then I suggest a night inspection using flashlights. One person inside with as many panels as you can remove for access. And someone below, both with powerful flashlights and as many peripheral lights off as possible (darker the better). Taking turns shining the lights toward each other may reveal a flash of light through an opening that was not visible during the day.
Good luck.
rowiebowie is offline   Reply With Quote
Old 06-13-2019, 05:50 AM   #3
Mice are a common problem, almost inevitable in some circumstances unless measures are taken against them.
I advise putting the Interstate up on ramps, getting down on a creeper, and scooting around under there to check the chassis penetrations.
I'll place my bet on it being the gray water drain pipe for the galley sink as the culprit. Stuff the gap between the chassis and the pipe with copper wool. And any other gaps you find.
Here's a pic of my home-made ramps (made out of fence scraps taken from trash piles) and creeper. The creeper is sold for about $30 on Harbor Freight (their website down today, or I would link it). You can do this inspection without a creeper, but it's a real pain to be working in such a tight space without one.
Old 06-13-2019, 11:36 AM   #4
Tincampers's Avatar
Sneedville , Tennessee
Creeper on sale for $20 right now!
https://www.harborfreight.com/40-in-...fQ%3D%3D%0D%0A
Tincampers is offline   Reply With Quote
Old 06-13-2019, 01:39 PM   #5
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
TINCAMPERS - Thanks for this timely sale announcment. I just happened to be in the area of HF today.
Alex AVI is offline   Reply With Quote
Old 06-13-2019, 02:55 PM   #6
Tincampers's Avatar
You are very welcome. I was near an HF earlier today but didn't know about that sale item.
Old 06-15-2019, 06:10 PM   #7
Here's a pic of the black tank drain line with copper wool stuffed into the hole (view looking upward under the chassis; the copper is dulled by corrosion). This hole was made too large for its purpose, but Airstream decided to run a wire bundle out of it as well, necessitating extra width and making it a bit messy to seal. I should probably put some foam over the copper wool, to keep out moisture.
Old 06-17-2019, 08:34 AM   #8
Bristol , Vermont
Thanks! This is one of the first places we found that we figured they would be getting in. We stuffed it with steel wool. I'm thinking we should have used copper wool to avoid a rust problem! We made ramps but only two so we only lift either the front or the back at a time. I like the fact you made four and can roll around the entire bottom! Have you found any places in the engine compartment where they get in?
Old 06-17-2019, 08:37 AM   #9
Bristol , Vermont
Naughty Mice
Old 06-17-2019, 08:39 AM   #10
Bristol , Vermont
I'm learning that this is an all too common problem! Thanks for your suggestion
Old 06-17-2019, 02:24 PM   #11
The engine compartment is completely open. I'm a bit nervous about chewables because newer vehicles sometimes have plastics that attract rodents, and I just put in a new engine (gulp).
Here's another owner's image from another forum, for instance:
Old 06-17-2019, 02:52 PM   #12
2015 Interstate Ext. Coach
Thousand Oaks , California
Bounce dryer sheets zip tied to cables in the engine compartment and safely out of the way of moving parts has kept the animals away for us. Refresh them every couple of months.
Ryoungca is offline   Reply With Quote
Old 06-17-2019, 06:48 PM   #13
Sebastopol , California
Honda Rat Tape. Yes it is a real Honda product with it's own part number. I used it after the rats chewed the ignition wires, overnight, under the hood of my wife's Lexus. Apparently the wires are coated with a soy based product instead of plastic.
Sebtown is online now   Reply With Quote
Old Yesterday, 04:31 AM   #14
And it worked for you? Because there are a lot of reviews on Amazon in which people claim that rodents gobbled up that, too.
To Rip Off Walls Or Not To Rip Off Walls... belikethefox Upholstery, Blinds, Walls & Interior Finishes 3 03-20-2015 01:31 PM
Mice, Mice, Mice Jake General Interior Topics 21 12-01-2009 12:09 PM
Mice in older airstreams? David Henderson 1965 - 1969 Overlander 33 09-01-2008 01:41 PM
mice wallybyam Off Topic Forum 2 01-29-2003 11:29 AM
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 10:01 PM
