Old 08-18-2013, 11:39 AM   #1
LB , California
Manual Override on Electric Dump Valves
We are camping and need help with our 2013 Interstate. The 15 amp fuse for the black valve is blown, and blows again when replaced (when replaced , the black tank light goes on and as soon as button touched, blows again)
We are not sure why it keeps blowing, but at this point we need to dump our gray water tank at minimum manually.
1-does anyone know why the fuse would blow (I was fiddling w inverter settings earlier - but did not think I changed anything)
2- We want to manually open the gray water valve, but we cannot find it under the vehicle. We have reviewed the Airstream manual, but it is not very helpful on this issue. Please let me know where I should be looking for the override screw on the gray water valve, and any other help or advice you can offer. I crawled around under there, but I am an unexperienced mechanic so some big help is needed!! Thank you!
Supercatspjs is offline   Reply With Quote
Old 08-18-2013, 11:51 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Never had that fuse blow, but I did blow the fuse for the macerator pump once, and the fuse for the hose reel, twice, all on my first-ever camping trip in my Interstate. Not sure what would cause your dump valve fuse to blow. Aside from the fact that you say it's a 15amp fuse, and my manual calls for a black 20amp fuse on circuit 7, which powers the dump valves. See page H-15 of the Interstate owners manual.
But as far as finding the manual override is concerned, if you trace the 3" hose from the macerator pump inlet back to the gray tank, it should be right close to the tank. There is a circular disk with a screw in the center on each side of the valve. Turn the screw to open or close the valve. See page G-16 of your manual.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-18-2013, 11:59 AM   #3
LB , California
Thank you! Going in again
Yes-saw that 20 called for in manual and tried it and blew too -weird. Ok going under again to see if can open again! Wish me luck!
Old 08-18-2013, 01:46 PM   #4
LB , California
Great news! black button not lit anymore and gray button works - turned macerator screw to see if jammed up and causing fuse to blow - turned a bunch, replaced fuse and then it all worked! Yeah! never found bypass for grey...I think there is a giant metal box covering all the equipment and can't tell tanks apart -ugh- what color is each tank....?? Thank you! I knew you would know what to do and so lucky you were online!!
Old 08-18-2013, 02:31 PM   #5
Well done both of you. This is why I joined this forum.
SenseiDave is offline   Reply With Quote
Old 08-18-2013, 05:03 PM   #6
Black tank is inside the bathroom under the toilet, above floor level.
Fresh tank is directly below the fill valve on the side of the vehicle, between the side of the vehicle and the frame.
Propane tank is to the rear near the generator.
Process of elimination means the other two tanks under there must be the gray tank and the diesel tank, which should be easy to tell apart.
I could tell you which is which by crawling under mine and looking, but until my head heals where the biopsy was done on my scalp, I'm not rubbing my head against the pavement by crawling under my Interstate. Sorry about that.
WBCCI #1105
TAC LA-4
Old 08-18-2013, 08:52 PM   #7
LB , California
Thank you! And heal soon!
Old 08-19-2013, 07:29 PM   #8
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
The gray tank is curbside and has a heater pad attached to it.
Old 07-22-2014, 05:22 PM   #9
2011 Airstream Interstate
Energy , Illinois
Fuses to electric dump valves
Thanks, I have had the same problem, I will give it a try.
raddocc is offline   Reply With Quote
Old 07-22-2014, 07:05 PM   #10
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
I don't think there is any by-pass. You oars aware that only one tank valve will operate at a time. Do the black first, use the macerator to pump it out and then close the black and then open the great and a gain use the macerator to pump it out. Unfortunately Airstream does not have any other way of dumping the tanks that I am aware of. And you cannot gravity out even the grey water with the grey tank open and the hose open into a dump. You have to have the macerator operational. My soon-to-be-built Roadtrek also has valves and a macerator but my valves are manual and there is no electric hose reel. My hose just slides back into a rather big, flat tray which is mounted directly under the larger fuel tank. And it does have a plug underneath whereby one can "dump" the tank contents without going thru the macerator. But it is not a "pretty sight" doing that over some form of sewer drain. But it can be one in an emergency.
Bikerbill is offline   Reply With Quote
Old 07-24-2014, 09:05 PM   #11
Energy , Illinois
That didn't work for me, I think I have a short in circuit 7. Every time I put a new 20 amp fuse in, it blows as soon as I turn the power back on.
Old 07-24-2014, 10:17 PM   #12
Energy , Illinois
Does anyone know where I can find a schematic for circuit 7? I can't find the exterior sewer light. Thanks
Old 07-24-2014, 11:54 PM   #13
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Don't think there is an exterior sewer light?
Before you install another fuse you have to free up your jammed Macerator pump. There is a rubber plug on the end of pump motor. Remove this plug and you will see a slotted screw head which you can turn with a screwdriver. Turn this to free up the jammed pump and then it should run with a new fuse installed.
- - Mike
Old 07-25-2014, 05:41 AM   #14
There isn't a sewer light. I use a magnetic-mount waterproof light intended for use with above-ground pools, that I can stick to the side of the Interstate whenever I need extra light.
Amazon.com : Good Times Battery Operated Waterproof Magnetic Lights, 2-Pack : Swimming Pool Above Ground Lights : Patio, Lawn & Garden
Not only good for a sewer light on the street side, but also makes a great supplement to that wimpy porch light on the curb side that is so much dimmer than even a home night-light. Comes with a pushbutton remote control. The one I bought actually comes in a two-pack, with both of them working off the same remote so I set one aside without batteries in it as a spare and just use one.
WBCCI #1105
TAC LA-4
