07-30-2014, 07:03 PM
#41
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Originally Posted by zigzagguzzi
Is new always an upgrade? Think about it! Jim
Given that Airstream Interstates have only been around for 10 years now (first produced in 2004), by your standards they're all new!
But in any event, I think the last time an Interstate came with a slinky and manually-operated dump valves was 2007, so macerator pumps and electrically-operated valves aren't exactly new by the standards of an Interstate owner.
07-30-2014, 10:11 PM
#42
2011 Airstream Interstate
2011 Interstate Coach
Energy
I took off my auto drain motors and the black tank drained like a champ. It must be my circuit board. I will open them manually until I can get it fixed. Thx for all the help and patience.
07-31-2014, 08:04 PM
#43
Overland Park
, Kansas
Care to share how you reached them?
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
07-31-2014, 11:18 PM
#44
Energy
I pulled the AI on to cement, since it was too tight to bring both of my arms up the secure both sides of the bolts, I was on one side with a ratchet and my wife had the other side with an Allen wrench .
07-31-2014, 11:26 PM
#45
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
I wonder why the engineers didn't provide a means of making an emergency dump in case of failure?
Gravity never fails.
08-01-2014, 12:08 AM
#46
2024 Interstate 19
Fulton
, Maryland
Good question!
- - Mike
2013 AS Interstate on 2012 MB Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
08-01-2014, 03:15 AM
#47
From All Over
So, what emergency alternative would you install in case of a valve failure? Another valve?
The only place in the whole system that gravity is taken OUT of the equation is at the macerator pump. For getting wastewater TO the pump, you ARE using gravity.
08-01-2014, 07:49 AM
#48
1972 31' Sovereign
Benton
, Arkansas
Manual Override on Electric Dump Valves
Yea another valve plumbed in where gravity would work sounds like a smart move to me.
The OP seems to have gotten the tank(s) to drain via gravity if I read things right.
An emergency valve right here might have been a good idea.
08-01-2014, 08:24 AM
#49
From All Over
I think maybe you missed the point of my admittedly snarky comment. The existing drain valves already drain the tanks by gravity; nothing new has to be done to drain the tanks by gravity, so I still fail to understand why the whole "gravity" thing started on this thread.
The only problem is that the valves are electrically operated, not manually, and there's no good way to operate them manually after the motor quits working except to crawl underneath.
The only practical engineering fix would be to get rid of the electric motors and go with push-pull cables leading from T-handles to the valves the way they used to do in the old days. Then there are no motors to quit and you're always operating the drain valves manually. But then you're still faced with the dilemma, what do you do if the push-pull cable breaks?
08-01-2014, 08:42 AM
#50
1972 31' Sovereign
Benton
, Arkansas
My point is,,,,
What happens if the brakes in your car fail?
Why is your vehicle equipped with an emergency brake?
I think maybe that there should be a emergency method of discharging waste that does not involve disassembly.
I know that anything I would ever build would have such a provision.
08-01-2014, 09:10 AM
#51
From All Over
I wouldn't. Not being able to dump the holding tanks is not a matter if, "If this doesn't work we're all going to die!" Unlike brakes, which are a matter of life and death and therefore require a backup. There is such a thing as over-engineering.
If I worked for Airstream, what I would do is realign the valves so that they're easier to reach— they don't have to work vertically with the stem on top; a sluice valve can work just as well by sliding sideways or diagonally or even sliding down to open— and make it easier to disconnect the motors from the valves, perhaps by just pulling a cotter pin on the valve's operating stem. Then after the motor is disconnected from the stem the person who pulled the pin could insert a tool (Phillips screwdriver?) into a hole on the stem to provide a handle for prying the valve open. After the problem was solved, the user would just have to reconnect the valve with the motor and reinsert the cotter pin, and hey presto the job would be finished.
08-01-2014, 09:17 AM
#52
1972 31' Sovereign
Benton
, Arkansas
Having to get poop on me in an effort to drain my poop tank on my driveway is kind of an emergency...
My point is that he engineers should have provided a practical means of dealing with the payload for when the valves fail to open as designed.
I don't know if it is true, but I have read that the dump valves are more reliable when the stems point up because garbage is not so prone to collect in the slides.
08-01-2014, 09:24 AM
#53
2005 22' Interstate
Pittsburgh
, Pennsylvania
The best practice solution to this problem involves manual valves located close to the edge of the vehicle plus the following (readily available) fitting:
This permits a macerator to be permanently connected to the rear of the fitting while preserving the ability to do a gravity flush using the front-facing bayonet fitting and a slinky.
Electric valves are a needless complexity that tend to be used to make up for poorly-thought-out pipe layout.
08-01-2014, 10:50 AM
#54
1972 31' Sovereign
Benton
, Arkansas
Frankly there is little doubt in my mind that much of the design work done by OEM 's of all kinds is to get the customer into the dealers service department.
Am I bad for thinking this way and resenting it?
08-01-2014, 08:45 PM
#55
Overland Park
, Kansas
Actually motor vehicles are equipped w/ a parking brake, not an emergency brake. If you doubt this, just try stopping by only using your parking brake.
raddocc didn't get poop all over him by opening the valve(s) manually. The open valve just allowed the tank contents to get to the macerator pump.
08-01-2014, 09:00 PM
#56
1972 31' Sovereign
Benton
, Arkansas
Might be true, I might have misread but it seemed to me as if the op removed the valves....
If that is the case I don't know how the poop would have been stopped...
Frankly I am too lazy to read back through right now.
If for one reason or another , if an e brake or parking brake is all you have a person might be glad to have it.
An e-brake/ parking brake may on occasion serve a dual purpose, and in most every case a properly functioning parking brake is capable of locking a vehicles back wheels.
08-01-2014, 09:05 PM
#57
1972 31' Sovereign
Benton
, Arkansas
I stand corrected...
I mustered the energy to read back over the thread, I was wrong about the valves having to be removed and the poop bath that I assumed.
My apologies.
08-02-2014, 01:25 PM
#58
Overland Park
, Kansas
I agree that the parking brake will lock the wheels at rest. But it won't if they're turning.
08-02-2014, 03:05 PM
#59
1972 31' Sovereign
Benton
, Arkansas
I think that a properly operating parking brake will lock the wheels on most any car made in the last 40 years.
When I was younger and not so smart I used to use the parking brake to lock the rear tires to induce a spin.....
