Originally Posted by guskmg
Good info. Has any one tried to upgrade the Kenwood/Garmen maps. I can't get their site downloaded updates to go in my Kenwood if I use my Apple computer. Do I need to use a Windows computer? The only commercial company I have asked is CarToys as they are Kenwood dealers. They did not know how to do it. Does anybody know others?
guskmg
Last time I updated the maps was a little over a year ago. You have to insert a thumb drive into the USB port of the Garmin and download the installed edition info. Then you plug the thumb drive into the computer and access the Garmin webpage. Download the map update to the same thumb drive. Then back to the van to plug the thumb drive back into the USB port, and you should be able to install the update.
Trying to plug a computer directly into the Garmin won't work. The computer treats the Garmin as a peripheral. The Garmin doesn't like being peripheral to a computer. The Garmin has to think
it's in charge, and that's why you've got to use the thumb drive, so it's peripheral to the Garmin.
In that regard it's completely different from the portable Garmins that update by plugging them directly into a computer.
On Edit— Unlike UKDUDE, my Kenwood/Garmin will not update firmware or maps with an SD Card (I've tried). It requires a USB thumb drive. Maybe that's because mine is a DNX7160 and his is a newer model?
