Old 03-27-2014, 01:10 PM   #15
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Originally Posted by kduplain View Post
Cons:
-we are having trouble getting air flow and temperature to maintain comfortably
I installed a 9" fan at each end of the galley counter for our recent Florida trip to alleviate the problem w/ temperature in the rear of the coach. My seven passengers said it helped. When time permits, will relocate to the underneath side of the cabinet above the galley.
Old 03-27-2014, 02:02 PM   #16
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Cons:
Try cranking open the extreme rear windows on each side a little to allow conditioned air from up front to pass through the entire coach and escape at the rear.
Peter
Old 03-27-2014, 09:33 PM   #17
Clayton , Missouri
Batteries in coach when parked and completely turned off last about 12 days. Coach is parked inside garage with no electric. Called AS and they told me it should last 4 weeks, no way. Boondocking with and running frig, lights and pumps my guess is 3 days. Although have not let it run completley out.
The water valves to empty tanks are behind drawer under mircowave and next to rear sofa, stuffed way down in that hole. Not improssible but not as easy as a side mount plug on the the class c I was used to.
kduplain is offline   Reply With Quote
Old 03-27-2014, 09:38 PM   #18
Clayton , Missouri
Seats
My seats are good. Couple of pulls of the knobs and seats are all facing each other. The second row captains chairs do not recline much. Still find it works with TV position but could be better. We really like the way the front 4 chairs make a comfortable seating area for family games or meals.
Old 03-27-2014, 10:25 PM   #19
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Boondocking with frig, lights and water pump will only last one day in my experience. That's why I added more solar.
Those water valves don't empty the tanks, they just drain the hot and cold water lines when winterizing. Everything is tight on these B-vans compared to a Class C.
- - Mike
Boxster1971 is online now   Reply With Quote
Old 03-27-2014, 11:21 PM   #20
Lazy scouter
Nealrap's Avatar
Plano , Texas
When boondockong, can you fire up the generator for a few hours to recharge again?
Nealrap is offline   Reply With Quote
Old 03-28-2014, 07:52 AM   #21
Sedona , Arizona
Really depends on what you consider "recharge" means. A few hours will not bring the battery(s) back up to 100% charge. Not even close. Obviously, you will be putting some amps back in and using up propane. A better strategy is conservation and solar.
I'm surprised a previous poster said he expects only 1 day's worth of juice from his batteries while boondocking. I can go 3 or more. I worry about holding tanks before I worry about electricity.
Disclaimer:I don't own an Airstream yet. My experience is with a Class C.
eric1514 is offline   Reply With Quote
Old 03-28-2014, 08:02 AM   #22
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If the chassis battery is not too far gone, the BIM will cross-connect the main and chassis systems, so that the generator will indeed charge the chassis battery. However, the BIM relay will prevent the two systems from connecting if either battery bank is too far gone, to keep from depleting the other, so if you wait too long to fire up the engine, the generator may NOT charge the chassis battery. In such a case, you may have to jump-start the engine. Which is easy on late-model Interstates with the "boost" switch, that manually overrides the BIM and lets you jump-start the engine from the house batteries. My 2012 doesn't have a Boost switch, so when I had to jump-start mine, I had to do it the old-fashioned way.
Using the Boost feature is not good for the house batteries, but it's a lot better than being stranded because the engine won't start.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-02-2014, 04:01 PM   #23
Trying to Retire
MILATV's Avatar
Decatur , Illinois
14,000 miles, 60+ nights on the road.
CONS:
I got a full zero hours on battery this trip. Looks like they're toast. 10.1v when engine cut off.
Rear seat belts are pain, curbside plastic guard on seat keeps popping out.
Agree with airflow improved with curbside rearmost window I don't open driver side rear due to water heater and generator exhaust.
Table mounted in forward position is a pain, can't get from front to back.
PROS:
- Can parallel park in Chicago.
- Wife can co-drive (multiple 28 hr drives straight thru)
- 18.5 MPG at 75 MPH
- drives like a minivan
- rides like Mercedes (with shock upgrade)
- climbed all hills east to west w/o load
AMAZING office on the road with upgrades (Bluetooth printer, wifi extender, RAM Mount laptop shelf).
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 04-02-2014, 06:38 PM   #24
73shark's Avatar
Either the shocks are the best in the universe or you haven't ridden in the rear seats.
If the former is true, would like to know what shocks you put on. Mine rides like an empty gravel truck when going over sharp perturbations like train tracks or pot holes. The kids like the ride in back tho.
Old 04-02-2014, 06:41 PM   #25
BikerBill
Poconos of Pa , Pennsylvania
Our 2013 chassis doesn't ride THAT bad. But then we are almost at maximum weight with all that I have found room for to carry.
Bikerbill is offline   Reply With Quote
Old 04-02-2014, 09:12 PM   #26
Fulton , Maryland
They ride like a Mercedes truck.
- - Mike
Old 04-02-2014, 09:35 PM   #27
Trying to Retire
MILATV's Avatar
Decatur , Illinois
I'm usually packed for 7-14 days + have a motorcycle on a rear carrier so I'm packed heavy; but - Ok - I get to ride in the front left seat most of the time (. . . driver) but yes - the rear seat would be a fun place for kids on a rough road.
BTW: I found 55 lbs air rides better than 60 lbs and no real difference in fuel (18.5 pretty steady).
Mike
Old 04-02-2014, 09:37 PM   #28
Lazy scouter
Nealrap's Avatar
Plano , Texas
Making switch to 2014.5 - some ??
I am only getting 16mpg on my 2014.5 pretty empty.
How do you get better mileage? I drive about 65-70mph
Battery Switch Inside "On" or "Off"? Cannonball Batteries, Univolts, Converters & Inverters 15 12-08-2016 08:57 PM
I want my water pump switch to light up... Friday Electrical - Systems, Generators, Batteries & Solar 18 09-18-2011 11:03 PM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 01:17 PM
3 way switch just went kaput...replacing? MonaxLisa Lights - Interior & Exterior 24 01-20-2011 05:51 PM
Battery switch behind the sofa LawChick Batteries, Univolts, Converters & Inverters 9 01-13-2011 09:52 PM
