Old 06-22-2015, 11:51 AM   #1
2014 Interstate Ext. Coach
Miami Beach , Florida
Making sure Fresh Water Tank is 'fresh'?
We just emptied the fresh water tank on our Interstate. Before we fill it back up, is there a way to (a) make sure the actual tank is clean and/or (b) quickly make sure it is clean...so we can feel good about brushing our teeth, not having to boil everything, etc?
ATE123 is offline   Reply With Quote
Old 06-22-2015, 12:05 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I put fill mine, put some bleach in it for a few hours, drain, fill and flush again.
CRH is offline   Reply With Quote
Old 06-22-2015, 12:08 PM   #3
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
Here's a YouTube link that may be helpful.
Ron
2015 Sport 16'
Ron
Ron A is offline   Reply With Quote
Old 06-24-2015, 07:58 AM   #4
This general question has come up several times before in various threads, most recently I think as an issue in which someone's water filter sounded like it was clogged. I said I'd post a pic of our filter when I finally got one, which is now. This thing is *disgusting*. It literally looks like someone vomited in it. And it looks just like this every single time I remove it for inspection and cleaning.
Our fresh water tank has chronic problems that appear to have originated with the first 7 years of its life, during which we did not own the Interstate. There is a build-up of general scum in the tank and it has proven extremely difficult to remove. Even if the tank is bleached, some presumably-dead solid material still remains. That poses two problems: (1) it dislodges and clogs the filter as you see here, and (2) it serves as a substrate for future re-growth of micro-organisms.
Here is my current preferred tank management sequence:
--Fill the fresh water tank about half full
--Open the drain valve (which is woefully undersized in the 2007 Interstate, which is part of our problem)
--Drive around a bit with the valve open so that it will slosh and get as empty as possible (presumably carrying slime with it)
--If I have the time that day, repeat sequence with bleach and rinse. Else bleach later.
--When the tank is totally empty, unscrew the filter and scrub out the slime with a toothbrush
--Replace filter, and re-fill the tank for the trip
--Drain remaining contents of tank after trip and repeat as necessary. We have a new habit of driving 3 miles back to our storage locker with the valve open specifically to get the best drain possible before putting up the Interstate.
In response to the OP's original question, I don't ever consume water from our fresh water tank, and I won't until we get this issue under better control.
But even if an RV tank does NOT have such an obvious issue as we have, it concerns me because there is likely no chlorine residual remaining in that tank by the time someone puts that water in their mouth. I live in the deep south and zero chlorine residual is a no-no under any circumstances, fixed or mobile. Especially now in the summer when the ambient daytime temperature in our Interstate when parked is 105 degrees (I measured it yesterday) even with the shades drawn, windshield reflector in place, flaps open, and Fantastic running on coach battery. Bacteria can re-grow very rapidly under those conditions even if a tank was sterilized to start with.
I use a 10 liter military-grade polyethylene jerry can for potable water. It is wide-mouthed so it's easy to clean and dry between uses. I have a space under the counter beside the fresh water tank where the jerry can fits perfectly. This is the product I chose:
Scepter Water Cans - Scepter Military Water Cans - Scepter Watre Cans for sale, Scepter Military Fuel Cans, Military Water Cans, MWC, (MWC), Scepter 2.5 gallon water cans, Scepter 5 gallon water cans, Scepter 10 liter water cans, Scepter 20 liter wat
Old 06-24-2015, 11:14 AM   #5
Bee Cave , Texas
Newbie question. Where is the filter? I have a 72 Sovereign.
I had a leak in the fill pipe from the outdoor filler to the tank itself. I removed the hose (which was clear poly) and it was filled with black gunk, generally disgusting, that definitely drove home the point of never, under any circumstance, drink what comes out of the faucets. That stuff is for showering, washing dishes, and flushing the toilet. I won't even use it for boiling pasta in. We bring cases of bottled water.
BluesClues is offline   Reply With Quote
Old 06-24-2015, 11:31 AM   #6
AI owner since June 2013
Lake Mary , Florida
Where is the water filter in the system?
FlaBucki is offline   Reply With Quote
Old 06-24-2015, 01:22 PM   #7
1996 25' Excella
Tillsonburg , Ontario
We carry fresh water in a 5 gallon jug for coffee and drinking...never trusted the tank to be sanitary despite bleaching, and if the tank is really dirty you need a lot of bleach (one cups per 1/4 tank ) to get rid of slime, and drive around fro 10 -15 mins. We do use park water if it tastes OK, and 1/2 fill up if we are travelling so we have decent water, but still rely on city water in our jug for drinking
Chlorine residual in City Water is only about 1 ppm so any contamination in the tank will eat that up very quickly. When you get up to 5 ppm it tastes like swimming pool water...not very nice for drinking or cooking.
Math is a bit tricky, but 1/4 cup of bleach in 50 gallons of water is way more than enough to sanitize a clean tank. That will give about 20 -30 ppm chlorine which is 2 - 3 times the chlorine used to shock a swimming pool. Then it takes several rinses to get rid of the taste!
JCW
JCWDCW is offline   Reply With Quote
Old 06-24-2015, 01:40 PM   #8
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The EPA Primary Safe Drinking Water Standard calls for at least 1 ppm of chlorine in drinking water to ensure that no microorganisms can grow in the water, but no more than 4ppm. Over 4ppm residual chlorine is considered unsafe to drink or to use for sanitary purposes, regardless of whether you can stand the taste of it or not.
Cats and ultraleather Airstream upholstery don't mix!
Old 06-24-2015, 02:24 PM   #9
Good question and my bad for not taking a photo of where it is located on my rig. On most rigs, I would guess that it is probably quite near where the tank drain valve is located, some kind of nipple thing sticking up which is un-screwable. There will be a collection of guts and entrails (pipes / lines / connections) located near your water pump, which is likely next to the tank depending on what kind of vehicle you have. It'll be somewhere there. Don't unscrew it if there's water still in the tank because water will go everywhere.
We discovered it was there because it was so badly clogged and our water pump goes into major hammer mode when that happens. We kept hearing this pump noise that seemed abnormal, then we lost water pressure, and then another local Interstate owner warned us to check that first before assuming it was a pump problem.
Incidentally, to follow Protag's info, I think most people would be amazed at how well public water suppliers hit their residual chlorine targets. It sounds like such an impossibly narrow range - 1 ppm to 4 ppm. But they do it, in part because the technology exists and also because public water suppliers are among the most heavily regulated entities. Refineries and manufacturing plants and oil spills may show up more prominently in commercial news media environmental reporting, but water suppliers are where the real diligence is at. We would have a lot more citizens getting sick from e.coli and amoebic and other infections if this were not the case.
Old 06-24-2015, 08:59 PM   #10
Zil
Curtis Wright
Eyren Haven , South Jersey
The standard is 0.2 mg/L, (ppm) at the furthest part of the distribution system. We send water, 1/2 million gallons day, out of the plant at 0.6 ppm and get complaints of chlorine odors.
Zil is offline   Reply With Quote
Old 06-24-2015, 09:56 PM   #11
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My well water in the stock tank will grow moss in a short period of time, every so often I kill it with about 1/4 cup Clorox / 5 gallons of water, let it set for a while then rinse it out. I will never use my well water in the airstream ,only city water that has been chlorinated because of this problem...if It did happen I would over dose it with the cliorox several times with several rinses ......
Old 06-26-2015, 09:35 AM   #12
1996 25' Excella
Read my post #7. If I had your problem I would hit the tank with atleast a cup of bleach which will kill everything in sight. Then after soaking for 10-12 hours I would drain and try a wash with liquid laundry detergent..and drive around for 15 -20 minutes. That will scour the sticky residue. But now you will need to get rid of the soap which will take some time. A good flush or two with hard water will knock out most of the detergent, and you will need to do this until there is no more soap bubbles (or taste) but the tanks will be in a position for you to fill it with fresh water and keep the chlorine level where it will inhibit growth.
I didn't read where you use the tank regularly, or leave it sit fro days and weeks. If you boost the chlorine when you store it the growth should not come back...the downside is you need to flush the tank before using it the next outing.
I have both personal and industrial plant experience here. All the comments about residual chlorine are absolutely bang on... but they apply to a clean tank! You need to get to the "clean" part of the issue first
JCW
Old 06-26-2015, 10:03 AM   #13
Clear hoses are not ideal....
Originally Posted by BluesClues View Post
I had a leak in the fill pipe from the outdoor filler to the tank itself. I removed the hose (which was clear poly) and it was filled with black gunk, generally disgusting, .
Clear hoses allow light to pass through and this encourages the growth of some algae. I first experienced this in our sailing yacht many years ago. All our Airstream and yacht water pipes are now impervious to light.
A reference is on this page:
Potable Water Systems | Steve D'Antonio Marine Consulting
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 07-12-2015, 05:11 PM   #14
Following up on this question, here's an annotated pic showing the water filter location on our system. Other systems will no doubt look a bit different but the general arrangement is probably roughly consistent.
Additionally, the video that someone posted earlier showed the user introducing bleach using a winterizing kit. We don't have winter where we live, and I use the funnel method. I got a flexible silicone funnel at an outlet mall kitchen supply store for four bucks. It makes it easier than trying to pour into a rigid funnel at an angle. A plastic juice pitcher with a pour spout can be used with this so that bleach solution does not splash. And the funnel folds almost flat to save space.
City Water Hooked Up Making Fresh Water Tank Leak/Overflow??? Wgbarrbevco Fresh Water Systems 18 11-24-2017 03:45 AM
Sanitizing Fresh Water, Making a Bomb? HeadWest Fresh Water Systems 11 06-25-2013 11:07 AM
Help!!! Fresh water tank/ black tank meredith Fresh Water Systems 6 09-01-2011 11:51 PM
Using a fresh water tank as a grey tank? Mike&Ali Waste Systems, Tanks & Totes 14 09-16-2010 10:50 AM
Making sure the power's on Stefrobrts Batteries, Univolts, Converters & Inverters 25 05-17-2008 11:35 PM
