Old 07-12-2015, 05:35 PM   #15
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I sanitize the tank as prescribed but I take along a portable water distiller for drinking water.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 07-21-2015, 08:51 PM   #16
2015 Interstate Ext. Coach
Manassas , Virginia
You can buy test kits on Amazon for evaluating the purity of RV fresh water. The kit contains test tubes filled with a red nutrient solution. Put 1ml of RV water in the test tube and wait a few days. If the nutrient solution turns yellow, you have colliform or eccoli or some other bacteria in the water. Using this process you will know when the water is ok. Also, if you shock your fresh water system (including water lines), make sure all the chlorine is gone before testing otherwise you may get false negatives because residual chlorine is still strong enough to kill the bacteria.
curmugeon is offline   Reply With Quote
City Water Hooked Up Making Fresh Water Tank Leak/Overflow??? Wgbarrbevco Fresh Water Systems 18 11-24-2017 03:45 AM
Sanitizing Fresh Water, Making a Bomb? HeadWest Fresh Water Systems 11 06-25-2013 11:07 AM
Help!!! Fresh water tank/ black tank meredith Fresh Water Systems 6 09-01-2011 11:51 PM
Using a fresh water tank as a grey tank? Mike&Ali Waste Systems, Tanks & Totes 14 09-16-2010 10:50 AM
Making sure the power's on Stefrobrts Batteries, Univolts, Converters & Inverters 25 05-17-2008 11:35 PM
