Old 10-19-2016, 02:34 PM   #1
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Magnum DCLD Pigtail Adapter
Earlier this year we discussed using the Magnum DC Load Disconnect (DCLD) Pigtail Adapter to eliminate the unwanted parasitic drain caused by the Inverter/Charger. The thought was it would be better than the Airstream SB-164 solenoid used to disconnect the Inverter/Charger.
I bought a Magnum DCLD Pigtail Adapter a few months back and finally had a chance to check it out today. What I found was disappointing. I did not see any measureable difference in the parasitic drain with the DCLD installed. My current measuring meters only display to 0.1 resolution, so I can only conclude that the change is less that 0.1A.
The DCLD only disabled the Inverter ON/OFF switch on the remote control panel. The other functions on the remote control panel were still working normally including the back lighting, charger functions and the Battery Monitor Kit (BMK) I have installed.
Bottom line - I'm not installing the DCLD. I had planned to power the DCLD with a separate switch to enable the inverter when needed. It's just not worth the effort for the marginal benefit.
Old 10-19-2016, 03:20 PM   #2
Bellevue , Washington
Ah, good to know. Thanks for reporting. I never re-ordered mine and now have a different inverter.
amirm is offline   Reply With Quote
1974 Sovereign 12 volt battery pigtail Shamock Batteries, Univolts, Converters & Inverters 3 06-24-2011 05:08 PM
New Pigtail locks up my Sovereign brakes mello mike Electrical - Systems, Generators, Batteries & Solar 15 08-14-2009 10:46 AM
It all worked before I redid the pigtail 72BamaStream Electrical - Systems, Generators, Batteries & Solar 5 01-20-2009 08:17 AM
73 Safari - Need Electrical Pigtail Between Vehicles kadyacres Electrical - Systems, Generators, Batteries & Solar 5 07-05-2004 01:10 PM
'72 Trade Wind Pigtail Schematic igor Brakes & Brake Controllers 3 07-14-2002 03:15 AM
