Old 10-17-2016, 06:53 PM   #1
2014 Interstate Ext. Coach
melrose , Massachusetts
Magnum
Magnum shows red light no comm message. Tvs don't power and outlet behind drivers seat no power. What do I do ???
jennian is offline   Reply With Quote
Old 10-17-2016, 09:31 PM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
If the outlet behind the driver's seat is a GFCI, then try resetting it.
Old 10-17-2016, 09:41 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Check you battery voltage. You might have voltage that is below the operational threshold for the MMS-1012, which is one symptom of a 'no comm' error.
If you do have low battery voltage, you will need to but an external battery charger on them to raise the voltage above 11.5 for the inverter to start it's charging cycle. You also might try driving around for a while, as your BIM (battery isolation manager) should also connect the both battery banks and provide charge to your house batteries from the alternator.
Old 10-18-2016, 08:25 PM   #4
AtlantaCpl's Avatar
2013 Interstate Coach
Atlanta , Georgia
There are two electronic breakers on the back of the magnum you may also check if the other suggestions don't work. Mine tripped when my wife plugged in a hot pot while I was driving and didn't see what she was up to.
It is difficult to describe them, but they feel like raised buttons, and to reset them is just a light touch. No click or toggle or anything like that.
Brian
AtlantaCpl is offline   Reply With Quote
Old 10-18-2016, 10:28 PM   #5
lewster's Avatar
Brian
Those are rocker-style breakers and are only on the 120VAC input/output and should have np breaking on the 'no-comm' issue, as that is directly related to the 12VDC side of the inverter.
It is always worth a look though..........
Old 10-19-2016, 07:23 PM   #6
Njg
Njg's Avatar
2016 Interstate Lounge Ext
Columbia , Missouri
Solenoid is out!
Njg is offline   Reply With Quote
Old 10-20-2016, 02:12 PM   #7
fixed it
thanks all for your help. it was caused by the solenoid that we had installed to isolate the inverter when parked so as not to draw down batteries. fix was tapping it with a hammer to free it up to engage. may only be a temporary fix. i heard a number of these solenoid have failed so i will check with my dealer.
Old 10-20-2016, 03:14 PM   #8
Njg
Njg's Avatar
Columbia , Missouri
Replace with a higher rated solenoid or remove.
Old 10-20-2016, 03:51 PM   #9
UKDUDE's Avatar
Sedona , Arizona
Lew removed my SB-164 solenoid and installed a proper cut-off switch. It's perfect for my needs with just one minor disadvantage: I have to reprogram the Kenwood after using it.
prices of Magnum MS2812 2800W Inverter with 125 Amp Charger carl2591 Batteries, Univolts, Converters & Inverters 42 01-28-2014 04:26 AM
Magnum Energy inverter - chargers Jammer Batteries, Univolts, Converters & Inverters 5 03-22-2011 11:11 PM
Do I Need to Replace These Magnum Shocks? kennytheecat Shocks 3 04-01-2009 03:40 PM
Just wondering - towing with Magnum? tsprc Tow Vehicles 52 12-05-2008 05:37 PM
Dodge Magnum R/T sieve Member Introductions 16 08-04-2007 09:22 PM
