Old 04-22-2016, 01:06 PM   #15
Jeff
jkinglet's Avatar
2013 Interstate Coach
Seattle , Washington
Images: 37
Originally Posted by Protagonist View Post
Switch should be off. Last thing you need is for the motor to start turning on its own while you still have the screwdriver attached to it. That's a good way to get hurt.
Hose valve should be open. Trying to cycle the pump into a closed-off hose means you're working against whatever pressure builds up in the hose.
Tiato did it exactly right.
Thanks both for the heads up. Made no difference but I did get a long screw driver out of the deal. Checked the fuses again with a flashlight. From the factory (i've never touched the fuses in this scenario) the fuse for the pump and the fuse for the hose rewind were reversed. Acccording to the panel slot id supposed to be 20 amp for the pump and 15 amp for the hose rewind (protag, seperate on my AI btw). Apparently the pump got jammed a little and blew the 15 amp fuse. Pulled the 20 amp and put it in the pump slot and put a new 15 amp in the hose rewind slot. Purrs like a kitten (albeit, with a slight intestinal problem). 2nd time i've found a wrong fuse in a slot. Thanks again for the troubleshooting help. Always better than a dealer service visit.
jkinglet is offline   Reply With Quote
Old 04-22-2016, 01:17 PM   #16
Flemington , New Jersey
Great news. Its frustrating to discover after the fact that it was a fuse and to make matters worse the wrong amperage to boot. Sometimes its hard to see whether or not the fuse is blown when looking at the panel.
At any rate, sooner or later you will need that screwdriver. Better to have the right tool and not use it than not having it at all.
Mario
2013 Interstate
2014 Little Guy 5x10 Silver Shadow
Tiato is offline   Reply With Quote
Old 04-22-2016, 01:48 PM   #17
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
My memory might be faulty on that score. Or else it's just another undocumented change from one model year to the next. Between the two, I'm more inclined to go with faulty memory.
Either way, glad you found the problem.
I carry a pocket flashlight in the glove box, and when I need to check a fuse, I pull the fuse, and put the light behind the fuse to back-light it. Makes it easier to see if the fuse is blown.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-22-2016, 10:20 PM   #18
Jeff
jkinglet's Avatar
Images: 37
Great idea. Isn't a red warning light supposed to glow if the fuse is blown? Forgot how many new blade fuses I had accumulated over the years in my "AI electrical box." Nice to have a fresh 15 at the ready. Thanks again for the advice on making sure the switch is off before putting my new large screw driver to the pump. I could see myself launched across the storage area by how fast it spins. Whew!
Old 03-13-2017, 10:27 AM   #19
Brucet45410's Avatar
2014 Interstate Coach
Norfolk , Virginia
Macerator is a PITA
If there is one piece of equipment that gives me the biggest headaches in my 2014 AI...it is the Macerator. I was wondering if anybody has found a better solution to the macerator/pump that comes as standard equipment on the AI. Mine seems to blow a fuse every time I use it. I have taken to buy a box of 20 Amp fuses. It is very frustrating.
Wherever you go, there you are!
Brucet45410 is offline   Reply With Quote
Old 03-13-2017, 10:39 AM   #20
I have heard of other non-Airstream Sprinter-based rigs being built with a conventional gravity bypass to the macerator, such that when it fails, the owner can move efficiently to Plan B, which is a conventional stinky slinky discharge. I may be thinking of Great West Vans, which essentially went bankrupt in 2015.
However I have not heard of anyone retrofitting a macerator-only rig to include both options. That would be an interesting project, indeed.
Old 03-13-2017, 11:58 AM   #21
2011 Interstate Coach
Muskogee , Oklahoma
I did this a couple of years ago. See http://www.airforums.com/forums/f240...-92862-39.html
GM
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 03-13-2017, 12:26 PM   #22
I'll be danged - look at that. Post #544 (it didn't come through cleanly on the link above).
Old 03-21-2017, 04:26 PM   #23
Boxster1971's Avatar
Fulton , Maryland
Thanks for getting this discussed again. I almost forgot about it and want to make this mod when it warms up here. I'm attaching a seage system diagram from the Airstream aprts book that may help some visualize the location that GM installed the T-fitting. It went in place of the flex hose shown between items 2 and 4 in the attached diagram.
- - Mike
Macerator and Holding Tank Sensors SmokelessJoe Waste Systems, Tanks & Totes 1 01-04-2006 08:47 PM
Portable Macerator Use TomW Waste Systems, Tanks & Totes 5 05-03-2005 07:51 PM
Valve before or after macerator pump? malconium Waste Systems, Tanks & Totes 7 07-29-2004 04:20 PM
Macerator....do I need it? Rog0525 Waste Systems, Tanks & Totes 5 04-04-2004 08:39 PM
Macerator pump uncleneal Waste Systems, Tanks & Totes 4 03-12-2004 09:40 AM
