Old 07-12-2019, 12:16 AM   #1
Mansderm161's Avatar
NORTH MYRTLE BEACH , South Carolina
Macerator pump blowing fuse
Black and gray tank valve motors work. Hose real works, but can't turn on macerator. It blows 20 fuse immediately. History...macerator fell off last year on way to Jackson center. They replaced it and remounted it. Was in Jackson center this past May for small drip leak while using macerator. They said they "resealed everything". Got home and still small drip while dumping. The drip did not smell, it looked like water. Now the fuse blows as soon as I flip the switch for the macerator. Was prepping for international rally in Virginia but can't go with this problem. Last year my gray valve pump quit and when we removed the pump housing it was full of water which corroded the motor. I'm wondering if water got into macerator and did same. Any suggestions. I called Airstream, but went to voicemail. I don't think I can get a replacement in time for rally. I have to depend on 4 motors to dump which seems like a disaster always waiting to happen.
Mansderm161 is offline   Reply With Quote
Old 07-12-2019, 04:29 AM   #2
Auburn , Georgia
Maybe it is as simple as a stuck blade in the macerator. It can be manually turned with a screwdriver. Here is a link with some good info on your problem.
I see you had no problem crawling under before so this should be an easy check.
http://www.airforums.com/forums/f240...es-170131.html
GETRIDAONE is offline   Reply With Quote
Old 07-12-2019, 06:53 AM   #3
2015 Interstate Grand Tour
Lake Oswego , Oregon
I think Getridaone nailed it for you. Happened to me too and was an easy fix. Had to use a large flat blade screwdriver and rotate both directions to get it freed up.
You brought up dripping while dumping and we may have the same problem. I have a drip quite often (but not always) when just parked while I have fluid in my grey tank. Pretty sure I've got a leaky grey dump valve which then allows the plumbing before the macerator to fill up halfway. I say halfway because there are two weep holes in sides of the big pipe you can see while crouched beside the van. Not sure if these are for air to get in and assist with the dumping process, of if they are there to indicate a leak like I have. I'm leery of getting tossed out of a campground for active leaking of my sewer system, even though it's grey water (no smell on my finger).
Does anyone have experience fixing this? In anticipation of a future failure of one of the dump valve motors, I purchased one of these: https://amzn.to/2xInVLP
but you only get the motor box and not the blade / gate mechanism. I think our dump valve / blade / gate is a little different from this photo anyway. Not sure if removing & cleaning what I have will solve the problem, or if it needs to be replaced. Does anyone know where to find the full mechanism?
If I'm going to pay to have servicing done on this mess, I may as well replace both motors, the gate valves, the macerator (have one) and maybe have them do the manual dump bypass that some here have done. I've tackled a lot of projects myself but I think this one is beyond my ability, especially being on the road full time.
Tronadora is offline   Reply With Quote
Old 07-12-2019, 07:06 AM   #4
2013 Interstate Coach
Indianola , Iowa
When I purchased my 2013 AI a little over a month ago, my issue started with blow fuses, then the pump died completely. Hopefully the screwdriver works for you. When I got mine off, there was an o-ring and a bunch of what looked like fabric, but may have been some kind of bladder material hanging out of the end where the blades are. Prior owner had it for 2 years and reported having blown fuse issues when I purchased it, but said it worked for him the few times he needed to use it after replacing the fuse. Given its age, mine had outlived its useful life by the time I took delivery. Good luck with yours. I think Airstream's "re-sealing" process involves a bunch of silicone, which IMHO shouldn't be the OEM installation process when there are obvious better materials and methods available.
nateallen80 is offline   Reply With Quote
Old 07-12-2019, 09:07 AM   #5
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
I replaced the 20A macerator fuse with a slow-blow 20A fuse. Never have blown one since. If I don't hear the motor start, I have time to get my finger off the switch before the fuse will blow.
It took some time to search the net for slow-blow fuses, but it is worth it for peace of mind. I think I had to buy 10 fuses.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 07-12-2019, 10:05 AM   #6
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Question
John, is this a blade fuse? Do not have the AI at home... would like to order it.
Like this one?
https://www.electricalhub.com/littel...RoCk5IQAvD_BwE
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 07-12-2019, 11:03 AM   #7
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi Mansderm161,*
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 07-12-2019, 11:05 AM   #8
If you were here, I'd give you a big hug. It crossed my mind, but it burned the fuse as soon as it turned on so I was thinking short somewhere. Plus I've had a small drip when dumping so I thought water got into housing. At your suggestion, I turned the screw and VOILA! Back in business. Thanks soooooooo much. So I am going to head to international rally and see if Virginia airstream can fix the drip while I'm there....plan B is back to Jackson in August. They still have not even returned my call. If you are at the rally....please look me up. Thanks again. This forum is full of wonderful people!
Old 07-12-2019, 11:22 AM   #9
Contributing Member
Pahaska's Avatar
Like this one?
That looks like those I have. Hard to distinguish by eye from the original fuses.
John W. Irwin
WBCCI #9632
Old 07-12-2019, 12:39 PM   #10
Lily&Me's Avatar
Normal , Illinois
Problem solved!
Yeeaaayyy!!!
Have a great trip.
Maggie
Old 07-12-2019, 12:55 PM   #11
wachuko's Avatar
Orlando , Florida
Thumbs up
If you were here, I'd give you a big hug. It crossed my mind, but it burned the fuse as soon as it turned on so I was thinking short somewhere. Plus I've had a small drip when dumping so I thought water got into housing. At your suggestion, I turned the screw and VOILA! Back in business. Thanks soooooooo much...
Woohooo!!! Great news!
Safe travels!
Wachuko
WBCCI #26769
Old 07-13-2019, 06:17 AM   #12
Auburn , Georgia
I am glad you got the problem fixed and are off to the rally next week. I have a septic tank so I am able to clean my tanks out at home. I fill the black tank with water and drive the two miles to the park with about ten speed bumps in the parking lot. It is amazing how much toliet paper comes out when you think it is clean. Dried paper in the macerator is probably the cause.
Macerator pump fuse blown. Prairie Sprinter and B-van Forum 19 07-21-2018 05:17 PM
Macerator blowing 20 amp fuses amirm Sprinter and B-van Forum 20 07-26-2017 08:59 AM
Macerator Pump hose Reel Blowing fuses WBS248 Waste Systems, Tanks & Totes 2 11-25-2016 11:18 PM
Blowing water pump fuse perryg114 Fresh Water Systems 3 10-04-2011 08:36 PM
Brake Light fuse keeps blowing BW_LandYacht36MH Land Yacht/Legacy Motorhomes 3 08-25-2005 12:25 PM
