Old 12-18-2017, 01:22 PM   #1
lamato's Avatar
2013 Interstate Coach
Sacramento , California
Macerator
Hi, experts!!
We have a 2013 extended, and our macerator is leaking. The model number on the macerator is: Flojet 18550300C.
This particular model number doesn't come up online on eBay or Amazon.
Does anyone know if Flojet model number 18550000A will work as a replacement?
Thanks in advance for any help.
Laura and Vince
lamato is offline   Reply With Quote
Old 12-18-2017, 02:25 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by lamato View Post
Hi, experts!!
Laura and Vince
Same pump. Absolutely identical. Xylem Flow Control is the parent company for both Flojet and Jabsco. The "C" suffix indicates a pump sold by Xylem. The "A" suffix indicates a pump sold by Flojet.
https://www.amazon.com/Flojet-185500...X48683CHCMAGFC
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-18-2017, 04:02 PM   #3
Boxster1971's Avatar
Fulton , Maryland
Hi, experts!!
Laura and Vince
As Protag pointed out it is the same pump, but you probably don't need to replace it if you plan a DIY repair. I have the very same Interstate model and while recently working on my sewage plumbing system I discovered the macerator pump had two broken brass studs holding it together. I found you can get replacement parts for this pump from many sources on-line.
These older macerator pumps had brass bolts holding it together. A few years ago they upgraded to these stainless steel bolts.
https://www.amazon.com/Jabsco-Older-18590-Macerator-Pumps/dp/B00UKC9Y5K
When you disassemble the pump the paper gasket with likely be damaged and must be replaced. Here is the gasket parts you will need.
https://www.amazon.com/GASKET-2-PER-KIT-C-Misc/dp/B000N9P800
If you want to also replace the guts fo the pump this kit will do the trick and includes the gaskets.
https://www.amazon.com/Jabsco-18598-1000-Service-Macerator-18590/dp/B0000AY7W8
So rather than spend $150+ on a new pump you can repair it for as little as $31.
Iíve attached the basic tech data on the pump with an exploded parts diagram.
There is also this excellent video on YouTube on repairing the pump
Good Luck,
- - Mike
Macerator and Holding Tank Sensors SmokelessJoe Waste Systems, Tanks & Totes 1 01-04-2006 09:47 PM
Portable Macerator Use TomW Waste Systems, Tanks & Totes 5 05-03-2005 08:51 PM
Valve before or after macerator pump? malconium Waste Systems, Tanks & Totes 7 07-29-2004 05:20 PM
Macerator....do I need it? Rog0525 Waste Systems, Tanks & Totes 5 04-04-2004 09:39 PM
Macerator pump uncleneal Waste Systems, Tanks & Totes 4 03-12-2004 10:40 AM
