Old 06-07-2014, 12:05 AM   #1
Jeff64's Avatar
2014 Interstate Ext. Coach
Springfield , Missouri
Lug Nuts
Has anyone been able to locate an actual chrome lug nut for the Sprinter to replace these cheesy aluminum caps?
Jeff64 is offline   Reply With Quote
Old 06-07-2014, 05:18 AM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Jeff,
Don't know the size or type on your rig but these guys have a pretty good selection.
Gorilla Automotive Products - Lug Nuts, Wheel Locks, Auto Security, Wheel Accessories
Discount Tire sold them to me with my new 16's
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 06-07-2014, 06:09 AM   #3
dznf0g's Avatar
Oswego , Illinois
Try McGard
Cone Seat
-Rich-
Old 06-07-2014, 06:43 AM   #4
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Lug Nuts
I really like the McGards, amazon has them in packs of 4. Needed 6 packs to replace all mine. One unexpected benefit; most others require 13/16 socket and require a thin wall spark plug socket to install/remove in wheels with deep recesses. The McGards use a 3/4 socket that easily fits inside my wheels. This applies to 1/2x20 cone seat acorns that fit mine. Other models may be different.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 06-07-2014, 07:40 AM   #5
GCinSC2's Avatar
Guys it looks like Jeff is looking for nuts for a Sprinter, right?
Jeff needs to identify size and style?
S/OS #001
Old 06-07-2014, 09:17 AM   #6
ben322's Avatar
2009 Interstate
Bethesda , Maryland
The Sprinter uses a flat seat so conical or radius lug nuts will not work. It's like the miniature version of 18-wheeler lugs but I haven't seen any decent replacements. I have seen the Gorilla washers that would adapt either a 60 or 45 degree conical seat but I don't have a lot of confidence the conical seat won't fracture over the long term with Sprinter lugs at about 150ftlbs.
2009 Airstream Interstate
ben322 is offline   Reply With Quote
Old 06-07-2014, 09:19 AM   #7
r carl's Avatar
Lin , Ne
JC Whitney?
Old 06-07-2014, 09:29 AM   #8
dznf0g's Avatar
Oswego , Illinois
I believe mcgard makes flat ones too, but OP needs to find specs. They are highest quality I've found.
Sent from my XT907 using Airstream Forums mobile app
-Rich-
Old 06-07-2014, 09:50 AM   #9
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Yes he has a Sprinter. This is the Sprinter and B-van forum.
I've never seen chrome lug nuts for a 3500 Sprinter and I've looked many times. The correct lug nuts look like this:
Lug nut for 2007-2014 Sprinter 3500 Steel Wheel - new original part
... or this
Dorman® AutoGrade™ 611-295 - Wheel Nut | O'Reilly Auto Parts
Specs:
  • Wheel Nut M14-1.5 Flanged Flat Face - 19mm Hex, 15.5mm Length
  • Hex Size: 19mm
  • Thread Size: M14X1.50
  • Seat Style: Flange
  • Style: Flanged Flat Face
  • Thread Handing: Right Hand Thread
The Interstate has Alcoa Forged Aluminum Wheels and the lug nut covers on mine are chromed steel.
- - Mike
Boxster1971 is online now   Reply With Quote
Old 06-07-2014, 11:29 AM   #10
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I believe mine are st-st.
Only problem I've had is the depressions that are used to make them a press-fit weren't deep enuf so had to add some tape on a couple of the flats on the lug nuts. The PO had lost two in 4K mi. Got the dealer to replace under warranty.
Old 06-07-2014, 11:41 AM   #11
Fulton , Maryland
You are correct -- they are probably stainless steel.
- - Mike
Old 06-07-2014, 12:58 PM   #12
73shark's Avatar
These say they're for Sprinter steel wheels. Will they still work on the Alcoa wheels?
Old 06-07-2014, 01:14 PM   #13
Fulton , Maryland
Yes -- 3500 Sprinter steel wheels and Alcoa aluminum wheels use same lug nuts. It's not like the lug bolts on the 2500 that are different lengths for steel and aluminum.
- - Mike
Old 06-07-2014, 01:35 PM   #14
73shark's Avatar
Thanks, good to know.
Nuts on lug nuts Steel rim spare tire!y Griff Wheels, Hubs & Bearings 4 02-13-2014 08:51 AM
lug nuts or lug bolts Mbirdshooter Wheels, Hubs & Bearings 3 07-20-2010 02:00 PM
Lug nuts vs. lug bolts dorfgog Wheels, Hubs & Bearings 9 04-19-2010 09:41 PM
Rusty chromed lug nuts nickcrowhurst Wheels, Hubs & Bearings 14 08-02-2004 06:52 AM
lug nuts bambi david h Axles 2 02-10-2003 08:59 AM
