Old 10-04-2015, 11:28 AM   #1
2014 Interstate Ext. Coach
Chattanooga , Tennessee
Lug nut covers
We do not have the lug nut covers for our Alcoa aluminum wheels on our 2014 AI (we are the second owner, we bought it that way). I don't know if they were stolen or damaged when the wheels were taken off by the prior owner, but all 24 are missing.
I have been having trouble locating lug nut covers for these wheels. Does anyone have any recommendations for where to purchase these lug nut covers at a reasonable price?
Alternatively, is there a way to replace the lug nuts with chrome or stainless lug nuts that would not rust and would be more theft resistant? Or would this be cost prohibitive? I just want the rusted lug nuts (and I'm not sure why they are already rusty, less than 2 years old) cosmetically covered.
BrianKrueger is offline   Reply With Quote
Old 10-04-2015, 11:46 AM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
Replacements are available very inexpensively from Amazon.
http://www.amazon.com/Excalibur-1954...rds=B00DTLVOXY
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 10-04-2015, 12:37 PM   #3
Lug nuts
- Bart
Are you sure these would fit the 2014 AI? It's on a Mercedes Sprinter chassis, so I would assume the lugs would be measured in mm instead of inches?
Are these actual lug nuts with a thread? If yes, I don't see any thread in the pic at Amazon. Or do they go on top of the existing lug nuts?
Also, I don't have the tools to switch out the lugs, any idea how much it might cost to have the lugs replaced at a local tire shop?
Old 10-04-2015, 12:48 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Probably because they're high-carbon steel for strength, and high-carbon steel tends to rust.
You'd do better to replace them with solid stainless or chrome-plated nuts instead of using covers. Covers are not airtight or watertight and so the lug nuts with covers will still rust; you just can't see the rust.
However, light surface rust doesn't affect their strength, only their appearance. As long as the threads don't rust and as long as there's no deep pitting anywhere on the nuts, they'll still hold your wheels on just fine.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-04-2015, 01:17 PM   #5
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
Got nice chrome replacements from Costco when I had the crappy tires replaced on both new trailers.
2015 30' FC Bunk, Dual A/C, Full Awning, RV550, Sleep Number, ProPride, Nokian Rotiiva AT 15" Tires
2015 Chevrolet 2500HD 4WD Duramax/Allison LTZ Crew Cab Short Bed, Huper Optik, Bull Dog Spray In, Roll-N-Lock, Full Amsoil, Denali SoundBomb, Yakima
2012FB is offline   Reply With Quote
Old 10-04-2015, 02:19 PM   #6
Maniacal Engineer
barts's Avatar
Sorry, I missed that this was a Sprinter-based Airstream. I don't know what sort of lugs these use, but the link was to nuts, which go over the studs coming out of the hub. I'd guess these are likely to be 14 mm x 1.5 mm, but you'll need to verify that. Chrome-plated nuts to fit your sprinter chassis are no doubt easily available.
- Bart
Bart Smaalders
Menlo Park, CA
Old 10-04-2015, 04:58 PM   #7
Lug size
- Bart
The lugs measure approximately 19mm across, but I don't know if that means these nuts would fit (at 3/4", pretty much the same as 19mm)?
Old 10-04-2015, 05:52 PM   #8
The size of lug wrench that will fit the new nuts is the least important measurement of all. Much more important are thread diameter, thread pitch, and whether the seats are flat or 60 angled. You can always find a new lug wrench, if necessary, to fit whatever nuts you end up using, but only lug nuts with the right threads and seats will hold the wheel on.
Unfortunately I don't know off the top of my head what the right dimensions are.
WBCCI #1105
TAC LA-4
Old 10-04-2015, 06:41 PM   #9
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
There was a thread here or on the Sprinter forum discussing the replacement of the OEM lug nuts w/ aftermarket chrome ones. Can't remember since I've never had mine off whether the Alcoa wheels are lug-centric or hub-centric which is what you'll need to know to determine if you need 60* ones flat ones.
Old 10-04-2015, 10:04 PM   #10
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Go to this thread for details on getting the correct lug nut covers for your Alcoa wheels.
http://www.airforums.com/forums/f240/lug-nut-covers-131013.html
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 10-05-2015, 10:20 AM   #11
Related issue is the possibility of locking lugs. I've done prelim research for our T1N and I've located the OEM MB part, but they don't seem to have been offered by anyone (MB or aftermarket) in a lockable version analogous to what's on my daily driver. My husband doesn't think it's a concern because it would be too difficult for anyone to strip wheels off a 9,000-lb Interstate, but I had wheels stolen off my daily driver before the locking versions became available, and it's not a good situation, obviously.
Old 10-06-2015, 08:04 PM   #12
Jeff64's Avatar
Springfield , Missouri
The post below is from an earlier thread. They've been on the AI for over a year now and still look new.
After searching for weeks for a suitable lug nut for the Sprinter I believe I've finally found them. I ordered an acorn style nut with a washer designed to fit it. The lug nuts are Gorilla brand heat treated and the washers are Gorilla brand as well. I found the at a company called Brandsport in Eugene Oregon. I dealt with Eric there who was very helpful in working with me to come up with a solution. The lug nut part # is GRLA-91148HT The washer part no. is GRLA-77916 Eric's email address is eric@brandsport.com No more dealing with those caps falling off. I found one the other day in my driveway that had been run over
Jeff64 is offline   Reply With Quote
Old 10-15-2015, 11:45 AM   #13
Flemington , New Jersey
Here's a link to Alcoa replacements including the center cap. Rear kit is at bottom of linked page.
http://www.southwestwheel.com/store/...&SEName=021120
Mario
2013 Interstate
2014 Little Guy 5x10 Silver Shadow
Tiato is offline   Reply With Quote
Old 10-16-2015, 04:52 AM   #14
Lug nut covers will not work on Mercedes version
Although it states on that page: "Lug nut covers will not work on Mercedes version." This would only work for the Dodge Sprinter van.
Lug nut covers russ240 Sprinter and B-van Forum 27 03-07-2017 07:34 PM
Lug Nut Covers Rain Sprinter and B-van Forum 13 12-06-2016 05:12 PM
Lug Nut Covers - To cheap to stay on! dadstoy General Motorhome Topics 15 08-24-2015 04:43 AM
Lug nut covers? SebasSF Classic Motorhomes 25 02-22-2015 04:57 PM
Wheel / Lug nut covers bkahler Classic Motorhomes 3 04-13-2008 12:10 PM
