08-25-2013, 09:41 PM
2012 Interstate Coach
norman
, Oklahoma
Lug nut covers
The first time the front wheels came off the bus for balancing we quickly discovered that there are covers over the actual lug nuts. The cover takes a 21 mm (13/16") socket, the actual nut a 19mm. After the mechanic had hit all of them with the impact, most of the covers would not stay on any more. I wrapped all the lugs with a turn or two of electrical tape and then the covers all stayed on fine. Except I lost one over the course of 10k miles. Then the wheels came off again when the mechanic was putting on my Koni shocks. He hit them with the impact wearing a 21 mm socket (different tech this time so he did not know, and I did not think about the fact that the wheels would be coming off so I did not remove them myself or warn him). He put new tape on when he put it all back together ... but apparently did not go quite as thick as I had because I lost two more covers on the way home. That's when I realized they had had the wheels off and what had happened.
How is everyone else dealing with these silly things? If I could buy a finished looking lug nut that did not need a cover I'd be ordering up 20 of them in a heart beat (actually I'd order 22, always good to have a couple of spares).
Barring a coverless lug, anyone have a good mail order Alcoa supplier to replace the covers I am missing?
08-25-2013, 11:58 PM
2011 Interstate Coach
Overland Park
, Kansas
If you look at the lug nut covers closely, you'll notice that every other side has a dimple on the flat which is designed to reduce the size internally so that the cover will stay on the lug nuts. If you decide to replace them with finished lug nuts, you're actually need 24 as I believe since there are six per wheel.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
08-26-2013, 04:23 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Replace the lugs with these...if the covers are useless.
08-26-2013, 05:08 AM
Figment of My Imagination
From All Over
, More Than Anywhere Else
Nope. 20 is right, along with four locking lug nuts. Having your rims stolen because some crackhead wants to sell them for their aluminum value would suck big time.
Originally Posted by ROBERT CROSS
Amazon says they don't fit my 2011 Sprinter (2012 Interstate). Did Airstream replace the lugs when they replaced the stock Sprinter rims with the cast aluminum ones?
08-26-2013, 05:21 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Pro,
Give Mcgard a call, they may be able to help if you have style, size & pitch.
08-26-2013, 10:45 AM
2013 Interstate Coach
Orange County
Protag, if you or anyone else does call Mcgard, please post results here as I'm sure a lot of us would be interested. I know I am. Thanks
David
08-26-2013, 12:02 PM
2012 25' Flying Cloud
Battle Lake
I don't bother with "locking" lug nuts because the only person they slow down in wheel removal is me. You can buy a lug nut lock removal tool anywhere, and they work easily.
Check the second half of this short video.
doug
08-26-2013, 01:22 PM
norman
, Oklahoma
Yeah, I don't put any faith in wheel locks either. They only keep honest people from getting your wheels off, thieves can get around them in no time. Besides, there are plenty of easier targets out there than our 8k lbs plus RV's and the black market value of our wheels is marginal compared to many other more plentiful vehicles. Now if you have a suburban/yukon/escalade with 20" wheels on it, be careful where you park 'cause those will be gone in a heart beat.
The problem with any conventional lug like the ones Bob mentioned are that we need a shouldered lug for our sprinters.
I had noticed the dimples that Shark mentions, but once someone puts a 21mm socket on them and twists the lug off with the cover still on it those dimples are pretty much useless. Perhaps there is some special tool or technique to re-crimp the dimples? I'm all ears.
08-26-2013, 04:40 PM
Overland Park
, Kansas
Tighten a small piece of rod or pipe that will fit inside the cover in a vise. Put a couple of layers of electrical tape on top of the rod or pipe and then slip the lug nut cover over it. Now using a small pin punch, tap on the dimple with a hammer and the punch. Repeat for the other two dimples in the cover.
BTW, I agree with the others on the viability of the use of locking lug nuts. That's why I earlier recommended 24 vs 20 plus 4 locking lug nuts.
08-26-2013, 06:29 PM
2014 Interstate Ext. Coach
Boca Raton
I had the same problem with them becoming loose after a few removals and re-installs.
My mechanic showed me a little trick by just using a pair of pliers and crimping them slightly around those dimples.
They haven't come off since.
I do agree the should be chromed and not caps. But the chrome ones do rust the minute a lug wrench is put on them and 'breaks' the chrome seal.
08-26-2013, 11:18 PM
Corpus Christi
Gorilla brand chrome lug nuts are high quality, similar to McGard. Both are top shelf products.
So Long!
08-27-2013, 04:24 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
x2
Not Mcgards'....on-off every Winter for 11 Seasons, not a mark on them.
08-27-2013, 08:23 AM
Overland Park
, Kansas
x2
They look very nice.
08-28-2013, 10:17 AM
Overland Park
, Kansas
doug
Unless he using quill shafts w/ his impact wrench, he oughta be taken to the wood shed.
Like you said, locking lug nuts just keep the honest folks from stealing your wheels.
03-18-2016, 12:33 PM
2015 23' Flying Cloud
2023 Interstate 19
Scottsdale
Question on OEM AS lug nuts for a 2015 FC 23 5 bolt/14" wheels. Assume they still just have covers over the lug nut?
Recommendations on best ones to replace the OEM ones with?
03-18-2016, 12:48 PM
Walnut Creek
Yes, the FC23 uses same lug nut as the six hole trailers. Size is 1/2-20 and Gorillas or McGards do the job. The Gorillas actually come in a 24 nut package so you get some spares if you are using them on the 5 hole wheels. Pat
Note the Gorillas use a spline socket. You may not like that. Your call.
03-18-2016, 01:42 PM
2023 Interstate 19
Scottsdale
Great info. Will swap out the OEMs. Thanks!
03-19-2016, 06:47 PM
2023 Interstate 19
Scottsdale
What size socket is needed for the McGards?
03-20-2016, 05:44 PM
2023 Interstate 19
Scottsdale
Looks like it is 3/4"
05-13-2016, 02:00 PM
2015 Interstate Grand Tour
Southaven
, Mississippi
I have lost 4 lug nut covers on my Interstate 2015, can anyone tell me where to get replacements?
Dalwyn
