Old 03-18-2016, 12:33 PM   #15
2015 23' Flying Cloud
Livermore , California
Question on OEM AS lug nuts for a 2015 FC 23 5 bolt/14" wheels. Assume they still just have covers over the lug nut?
Recommendations on best ones to replace the OEM ones with?
cactusjk is offline   Reply With Quote
Old 03-18-2016, 12:48 PM   #16
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Yes, the FC23 uses same lug nut as the six hole trailers. Size is 1/2-20 and Gorillas or McGards do the job. The Gorillas actually come in a 24 nut package so you get some spares if you are using them on the 5 hole wheels. Pat
Note the Gorillas use a spline socket. You may not like that. Your call.
Old 03-18-2016, 01:42 PM   #17
Great info. Will swap out the OEMs. Thanks!
Old 03-19-2016, 06:47 PM   #18
What size socket is needed for the McGards?
Old 03-20-2016, 05:44 PM   #19
Looks like it is 3/4"
Old 05-13-2016, 02:00 PM   #20
Dalwyn's Avatar
2015 Interstate Grand Tour
Southaven , Mississippi
I have lost 4 lug nut covers on my Interstate 2015, can anyone tell me where to get replacements?
Dalwyn
Dalwyn is offline   Reply With Quote
Old 05-13-2016, 03:31 PM   #21
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
Found mine on Amazon, but just checked and "currently out of stock". They were listed for Mercedes Sprinter...."Alcoa" lug nut covers. You may be able to locate that way
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 05-13-2016, 03:49 PM   #22
Boxster1971's Avatar
Fulton , Maryland
Most of those Amazon listings I looked at called them a Winnebago part. They are actually an Alcoa wheel accessory. Check this document from Alcoa for latest info. The lug nut covers are part number 000120
http://www.alcoa.com/alcoawheels/cat..._SellSheet.pdf
They should be available from any distributor that sells Alcoa wheels. But I'm having trouble finding them online as everything points to Amazon, who dominate the simple search world.
Go to this site to find an Alcoa distributor in your area
http://www.alcoa.com/alcoawheels/nor...or/default.asp
I recall someone located and inexpensive source, beside Alcoa, some time back, but I'm having trouble finding it. I'll keep looking because I'll probably need some one of these days.
- - Mike
Old 05-13-2016, 03:55 PM   #23
toskeysam's Avatar
Yep. The one I bought was listed for Winnebago, Pleasure Way and Roadtrek. Exact appearance match and snapped into place very tightly.
FMCA # 436814
Old 05-13-2016, 04:20 PM   #24
Fulton , Maryland
Here is one of the sources for the lug nut covers I was looing for. It was over on the Sprinter-Source Forum, under the LTV Unity area.
http://www.sprinter-source.com/forum...99&postcount=9
Here is text:
"Re: Alcoa Wheels -- Tool ? Lug Nut Cover
After much research, was referred by ALCOA to Haltec Corp. in Salem, Ohio for the lug nut covers. Should you need to order them (000120 style) they cost about $20.00 for six plus $14.00 shipping. They DBA: Independent Operator Direct LLC., P.O. Box 170, Winona, OH 44493 & phone # is 888-699-7031. This will hopefully save someone time futilly searching the net."
I looked at the Haltec Corp web site but couldn't find them. These thins are commonly called hug-a-lug covers.
Hope this helps,
- - Mike
Old 05-13-2016, 08:19 PM   #25
Dalwyn's Avatar
Thanks everyone, appreciate the info.
Dalwyn
Old 05-31-2016, 07:24 AM   #26
Dalwyn's Avatar
Originally Posted by ROBERT CROSS View Post
Pro,
Give Mcgard a call, they may be able to help if you have style, size & pitch.
Can anyone tell me how I determine style, size and pitch for my 2015 Interstate Grand Tour? I want to replace my covers with the chrome plated steel lug nuts. Just don't know how to determine what to purchase.
Dalwyn
Old 03-07-2017, 06:38 PM   #27
Greenville , South Carolina
I found these stainless steel lug nut covers on Amazon
I found these stainless steel lug nut covers on Amazon. They look just like the originals ...maybe better! Fit nice and tight!
$3.49 each plus postage http://www.amazon.com/dp/B01C0QG0V4
$29.49 for five, plus postage - http://www.amazon.com/dp/B01C0QT1OW
poptop4u is offline   Reply With Quote
Old 03-07-2017, 07:34 PM   #28
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
x2
Not Mcgards'....on-off every Winter for 11 Seasons, not a mark on them.
That's what I put on my wheels. A little pricey but solid and no signs of rust after many torques.
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
