Old 11-14-2015, 02:24 PM   #1
Houston , Texas
LPG Aux Quick Connect
Is the Aux LPG connect under the 2016 AI GT regulated or not? I can not find any reference in owner's material. Thanks for the help.
Mcrider is offline   Reply With Quote
Old 11-14-2015, 02:27 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Yes. It is a low-pressure connection.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-14-2015, 04:42 PM   #3
Welcome to Air Forums, and to the small greater Houston AI community (if it could be called that). My husband and I are DIYers in League City.
Old 11-14-2015, 08:02 PM   #4
Houston , Texas
Thanks for the clarity. Any suggestions out there for a nice camping grill that is unregulated. Seems all the ones I have found have a regulator.
Old 11-14-2015, 09:38 PM   #5
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I've been using the Camco Olympian for several years with good results. It's available from many sources:
http://www.walmart.com/ip/Camco-Olym...Grill/29764622
http://www.amazon.com/Camco-57305-Ol.../dp/B0014JN68O
http://www.campingworld.com/shopping...le-grill/37764
https://www.etrailer.com/tv-mdemo-ca...-cam57305.aspx
http://www.homedepot.com/p/Camco-Oly...7305/205518983
http://www.cabelas.com/product/Camco...ls/1337172.uts
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 11-15-2015, 02:25 PM   #6
HoffmanP's Avatar
2014 27' FB International
Prospect , Virginia
Just get a long unregulated hose with a quick connect on it to replace the line on whatever grill you like.
Paul Hoffman
2014 27FB International (WBCCI # 5327)
VA Plate: SOJOUNR
2013 Ford F-150 XLT Super Cab (Silver)
VA Plate: TRL DUST
HoffmanP is offline   Reply With Quote
Old 11-15-2015, 09:12 PM   #7
Fulton , Maryland
Yes you can do that but you have to remove more than the line. You must also remove the regulator included on any grill designed to use high pressure propane.
Quick connect extra propane fitting Rich of SCal LP Gas, Piping, Tanks & Regulators 21 08-21-2016 12:10 PM
LP Quick Connect for Gas Grill Mod-Streamer LP Gas, Piping, Tanks & Regulators 13 06-10-2015 04:20 PM
Propane quick-connect callmedave LP Gas, Piping, Tanks & Regulators 31 03-10-2015 11:53 AM
Quick Connect - water inlet? Kevin245 Fresh Water Systems 10 05-13-2009 04:26 PM
A new kind of quick connect 12V outlet Westfalia Electrical - Systems, Generators, Batteries & Solar 3 09-04-2005 06:26 PM
