Old 09-10-2016, 04:34 PM   #1
Camarillo , California
LP pressure at convenience quick connect
Can anyone tell me the LP pressure at the quick disconnect port? I may want to use an external appliance which does not have a local regulator. I don't have a convenient way to measure so please reply if known.
Thanks!
jacobo1 is offline   Reply With Quote
Old 09-10-2016, 04:42 PM   #2
1979 23' Safari
Wayland , New York
It's going to be after the regulator on the AS so it'll be about 12"water.
Old 09-10-2016, 04:42 PM   #3
dznf0g's Avatar
Oswego , Illinois
It should be at 11 inches dynamic and about 13 - 14 static pressure, just like the rest of the system.
-Rich-
Old 09-10-2016, 05:06 PM   #4
Thank you!
Old 09-11-2016, 02:14 PM   #5
1996 25' Excella
Tillsonburg , Ontario
I think it depends on where the port is located. I'm used to seeing an extra connection at the Bottle which is high pressure and my BBQ has the regulator. Not everything runs at 11" WC pressure. If th OP can see the hose(s) run from the bottles to the regulator without a branched connection to the convenience port than it may well be low pressure.
JCW
JCWDCW is offline   Reply With Quote
Old 09-11-2016, 04:40 PM   #6
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
JCW
We are talking about the quick disconnect on the Interstate vans. They are definitely low pressure after the regulator as is everything else in the LP system of the Interstates.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 09-11-2016, 04:53 PM   #7
Boxite's Avatar
2008 22' Sport
If it's downstream of the main regulator it should be at 11-inches of water-column, equal to about 1/2 psi. (.5 psi)
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Boxite is online now   Reply With Quote
LP Quick Connect for Gas Grill Mod-Streamer LP Gas, Piping, Tanks & Regulators 13 06-10-2015 05:20 PM
what is the comfort convenience package boondockdad Dollars & Cents 28 05-16-2015 09:12 AM
Down with crap, up with convenience! (BAL stabilizers) DKB_SATX General Repair Forum 13 05-21-2012 06:29 AM
Quick Connect - water inlet? Kevin245 Fresh Water Systems 10 05-13-2009 05:26 PM
A new kind of quick connect 12V outlet Westfalia Electrical - Systems, Generators, Batteries & Solar 3 09-04-2005 07:26 PM
