12-04-2018, 09:44 PM
2015 Interstate Ext. Coach
Saint Louis
, Missouri
Low pressure propane grills
The Interstate has an external low pressure outlet quick connect for a propane grill. I would like to know what specific grills people are using and recommend. It's easy to find a high pressure grill but I'm having some difficulty with low pressure ones. The Weber 200 has been used on other RV blogs. I would really like a more compact grill than that.
12-04-2018, 09:58 PM
2018 Interstate Lounge Ext
LV
, Nevada
CHARLIEOSCAR - You should look into Torjik CONVERTA•Q and Torjik CONVERTA•C. These are adapters to allow usage of Weber Q & Coleman Roadtrip LXE , both portable grills. Works, easy, last long time. May work on other grills too, but with choices between Weber & Coleman, how many more choices does one need?
http://torjik.com
12-05-2018, 12:32 AM
2002 30' Classic S/O
Fleming Island
Camco makes a stainless steel low pressure grill. A rail mount is available. I have used one for four years.
https://www.amazon.com/Camco-Olympia...88445278&psc=1
Al
12-05-2018, 04:56 AM
2014 Interstate Coach
Centre County
, Pennsylvania
We use the o-grill 3000, http://www.pro-iroda.com/ogrillorder.asp.
It’s worked well for us. It was the smallest grill we could find at the time (about 3 years ago).
It does have a regulator, which you will need to remove. We found a YouTube video helpful for that. We put a quick connect fitting on it for ease of use.
12-05-2018, 07:15 AM
2018 27' Tommy Bahama
Marana
Originally Posted by Al and Missy
How is the rail mount installed and secured on the AS? Very interested in doing the same.
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
12-05-2018, 09:47 AM
2014 Interstate Ext. Coach
fairfax station
, va
O-yeah?
I really like the O-grill.
The AI is problematic because interior stowage results in grill stink and makes your B-Van smell like a rib shack.
We needed a grill small enough to fit in our StowAway carrier with all of the rest of our outdoor gear* and the O fit the bill.
I got all ready to do the low pressure LP mods and quick connect and then realized that using the little Coleman bottle was convenient, didn't take any room, was available everywhere and is relatively cheap. So I have temporarily abandoned the project.
I also am not limited to placing the grill close to the van.
* chairs, folding table, hoses, electrical cords, tool box, door mat/rug....oh yeah and 2- 1 pound lp bottles
12-05-2018, 09:50 AM
2015 Interstate Grand Tour
Lake Oswego
, Oregon
I also use the Olympia grill but on a foldable table, connected to the Interstate. The iron diffuser grate works pretty well at spreading out the heat. The Low setting is pretty darn high and is all I use unless I'm torching off the debris.
Here's an Amazon link to the one I bought and it has the mounting rails included https://amzn.to/2StgDDS
I let it cool down and air out with the lid open and, after putting it back in its bag and storing it under the sofa, my nose-sensitive wife and I have never smelled any residual odors.
12-05-2018, 10:35 AM
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
Any portable grill will work. May need some adapters, but any will work.
12-05-2018, 11:52 AM
Fleming Island
There is a horizontal "rib" that runs the length of the trailer at that height. The rail does not come with the grill, but is only $3 or so. It was white powder coat. I stripped it and clear coated it. It is mounted to the rib with sheet metal screws. When the grill is off, the rail is hardly noticeable.
Al
12-05-2018, 11:56 AM
Fleming Island
There is an adjustment under the knob. You can pull the knob and turn the gas flow down. At its lowest point that will stay lit in a mild breeze it is still pretty high but not as high as the way it came.
The "mount" came with mine but did not include the rail that bolts to the trailer. Mine did not have the folding legs. The mount doubled as a stand.
Al
12-05-2018, 01:02 PM
Airstream owner 30 years
Bev Hills
Grill
Just take off the high pressure regulator and attach it directly to the Airstream. It wii work perfectly
KLK
12-05-2018, 04:26 PM
2018 30' Flying Cloud
New Hudson
, Michigan
You can't go wrong with any of the Weber Q series, there are Youtube videos on how to remove the built-in regulators, I had the Q1000, but upgraded to the Q2200 for more grill space, great even heating. If your looking to go smaller, I'd really recommend considering just getting a gas griddle, I carry the Blackstone 17" which works great for the three of us for weekend trips, get the adapter and it hooks right up to the trailer.
12-05-2018, 05:13 PM
2018 27' Globetrotter
Apollo Beach
I just bought a Weber Q1200 and the fittings needed to replace its low-pressure regulator with a 3/8" male flare fitting.
The grill and fittings were in stock at my local Lowe's Home Improvement Store.
Weber Q 1200 https://www.lowes.com/pd/Weber-Q-120...Grill/50330263
1/4-IN FIP x 1/8-IN FIP https://www.lowes.com/pd/B-K-1-4-in-...ing/1000505585
3/8-IN FLR x 1/4-IN MIP https://www.lowes.com/pd/B-K-3-8-in-...ing/1000506249
You can connect the modified grill to the Airstream quick-disconnect port with this unregulated hose: https://www.amazon.com/DOZYANT-Conne...oding=UTF8&me=
You can connect the modified grill to a standard 20# propane tank with this regulated hose: https://www.lowes.com/pd/Char-Broil-...-Hose/50330337
This link shows the low-pressure regulator I removed from the Weber Q1200 and the two fittings I added to it. http://www.airforums.com/forums/f42/...ml#post2186916
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
12-05-2018, 06:52 PM
2016 27' International
Sherwood Park
, Alberta
I have been using the Q1000 connected directly to the trailer for years. As has been already said, you just need to remove the regulator from the BBQ, add a couple of fittings and the quick connect hose and you are good to go. Any hardware or BBQ retailer will have the fittings and hose. I have a 20' hose and a separate stand for the BBQ, as I do not want that heat anywhere near the trailer skin.
12-05-2018, 09:00 PM
Saint Louis
, Missouri
Do you feel like the 20 ft hose is overkill? I was thinking about getting 20 but am always weight and storage conscious so leaning towards the 12.
12-06-2018, 05:18 AM
2020 23' Globetrotter
Savoy
Magma RV with 10 foot hose.
12-06-2018, 07:23 AM
Lake Oswego
, Oregon
The Olympian comes with I think a 4' hose and I bought a 10' thinking that would be used each time. As it turns out, I almost never use the 10' and go with the shorty. I have a portable 32x32 table for the BBQ. The short hose is long enough for me to have no worries about heating the side of the van.
12-06-2018, 08:15 AM
2022 25' Flying Cloud
NCR
, Ontario
there are many utube videos showing all the parts and adapters needed.
i did this for my weber grill on the as 22FB sports
it works well.
You basically remove the high pressure to low pressure regulators on the BBQ as the AS already has low pressure supply. then the adapter are to get the correct fittings
The hard part is where to store to BBQ. It does not fit between the tank and body on my 22FB. we keep it wrapped in the TV
12-06-2018, 10:01 AM
Sherwood Park
, Alberta
Yes, I would say so. It does allow me the option to place the BBQ closer to the trailer door if I wish, but I think 10-12 would be sufficient.
