Old 12-05-2018, 09:00 PM   #15
2015 Interstate Ext. Coach
Saint Louis , Missouri
Originally Posted by thewarden View Post
I have been using the Q1000 connected directly to the trailer for years. As has been already said, you just need to remove the regulator from the BBQ, add a couple of fittings and the quick connect hose and you are good to go. Any hardware or BBQ retailer will have the fittings and hose. I have a 20' hose and a separate stand for the BBQ, as I do not want that heat anywhere near the trailer skin.
Do you feel like the 20 ft hose is overkill? I was thinking about getting 20 but am always weight and storage conscious so leaning towards the 12.
CharlieOscar is offline   Reply With Quote
Old 12-05-2018, 09:02 PM   #16
Cusinart CGG 306
So I picked this one up on Amazon Black Friday deal for close to $100. I think if I can convert it to the low pressure I will keep it. If not I'm liking the Camco.
Cuisinart CGG-306 Chef's Style Stainless Tabletop Grill https://www.amazon.com/dp/B00F3BHB80/ref=cm_sw_r_cp_apa_Y4jcCb1FJCPQV
Old 12-06-2018, 05:18 AM   #17
2018 23' Flying Cloud
Savoy , Texas
Magma RV with 10 foot hose.
SpinWhite is offline   Reply With Quote
Old 12-06-2018, 07:23 AM   #18
2015 Interstate Grand Tour
Lake Oswego , Oregon
The Olympian comes with I think a 4' hose and I bought a 10' thinking that would be used each time. As it turns out, I almost never use the 10' and go with the shorty. I have a portable 32x32 table for the BBQ. The short hose is long enough for me to have no worries about heating the side of the van.
Tronadora is offline   Reply With Quote
Old 12-06-2018, 08:15 AM   #19
waninae39's Avatar
2017 22' Sport
NCR , Ontario
there are many utube videos showing all the parts and adapters needed.
i did this for my weber grill on the as 22FB sports
it works well.
You basically remove the high pressure to low pressure regulators on the BBQ as the AS already has low pressure supply. then the adapter are to get the correct fittings
The hard part is where to store to BBQ. It does not fit between the tank and body on my 22FB. we keep it wrapped in the TV
waninae39 is offline   Reply With Quote
Old 12-06-2018, 10:01 AM   #20
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Yes, I would say so. It does allow me the option to place the BBQ closer to the trailer door if I wish, but I think 10-12 would be sufficient.
thewarden is offline   Reply With Quote
Old 12-12-2018, 10:43 AM   #21
Dallashayes's Avatar
2018 22' Sport
Felton , Delaware
We are using the Weber Q series... Here's my post on the quick connect parts. http://www.airforums.com/forums/f142...ts-189483.html
Dallashayes is offline   Reply With Quote
Old 12-12-2018, 08:02 PM   #22
Calgary , California
We've been using a Weber Q1200 on the road for the past couple of months. It's a great little grill that more than suffices for my wife and I. Using the Coleman propane bottles generates more heat, but connecting directly to the trainer's external connection works just fine. Instead of 8 minutes to cook a steak on the big Weber at home, it takes 10-12 minutes on the Q1200. This is a reasonable inconvenience for the reward of nicely cooked meats on the road. We also have the 1/2 griddle option that is great for cooking breakfast outdoors, or cooking whatever else would tend to leave a lingering aroma inside our AS. We do wash the grills/griddle after every use, which is a bit of work, but worth it.
rdsyl is offline   Reply With Quote
Old 12-12-2018, 09:42 PM   #23
2018 23' International
Crescent City , California
Magma Marine stainless steel Kettle. Works great and designed for low pressure.
Gun2Head is offline   Reply With Quote
Old 12-13-2018, 05:29 PM   #24
2018 30' Flying Cloud
New Hudson , Michigan
Hose lengths
I carry two 12' gas hoses, primarily only use 1 for the grill, sometimes two depending if I'm using a park picnic table or my weber stand, but have two on board because I link them together for our propane fire-pit that we take along.
ekbruster is offline   Reply With Quote
Old 01-02-2019, 06:19 AM   #25
UPDATE: So I got the low pressure hose, took off the old hose that had the high pressure regulator attached. The flow of gas was insufficient to allow the flame to stay on for very long and would completely shut off if I tried to use the second burner. So this grill is not going to work. I'm going to change to one of the other grills mentioned in this thread.
Low Gas Pressure: Low stove flame, hot water heater won’t ignite. tjwoods1 LP Gas, Piping, Tanks & Regulators 16 10-19-2018 02:56 PM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Propane grills for low pressure connection lakeviewerie LP Gas, Piping, Tanks & Regulators 9 11-18-2012 06:22 AM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
