Enjoying our new to us 2013 ext. Had both TV's on while generator was running. Turned off generator and lost power to front tv. Can't even see where it is plugged in. Is power up under ceiling? Did I blow tv , outlet or a fuse?
TV's ar A/C. Did you turn invertor on? You need a source of A/C. Power by either generator, plugged into shore power or an invertor
Thanks for the advise. Inverter on and connected to shore power. Only front tv has no power. I thought TV's and plug behind drivers side where 12 volt as well. Im thinking I blew a 12 volt fuse possibly under drivers seat but I don't know which one
Thanks for the advise. Inverter on and connected to shore power. Only front tv has no power. I thought TV's and plug behind drivers side were 12 volt as well. Im thinking I blew a 12 volt fuse possibly under drivers seat but I don't know which one
Check GFI outlet behind drivers seat next to second row passenger seat. Ours has popped out a couple times and you loose the inverter outlets.
Second thing that happened to us is the cord going into back of tv got loose as it is difficult to get to and we had to use pliers to push it back in.
Are your getting power lights in upper console above can area?
Bingo, unplugged tv and checked power getting power in cord and plugged it back in (what a bitch to do) and problem solved. Thanks for all the help. Just a reminder to check the simpliest most obvious things first.
2014 Interstate Ext. Coach
Boca Raton
