Old 03-21-2016, 11:54 PM   #15
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Longer screws.
Hi, my bathroom door was coming loose. Airstream used 1/2" screws to hold the piano hinge onto a half inch piece of wood that was brad nailed to the bathroom wall. I used 1 1/4" Kreg screws that went though the piano hinge, though the 1/2" piece of wood, and close to 3/4" into the wall. In some places, I have found that Airstream uses screws that are too short and will eventually strip out. [Longer screws is the answer]
Also I had a bathroom corner wall that was coming loose. It was also held together with brads or air-nails. I used six screws and plastic screw caps/covers. My fixes have never come loose again.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-22-2016, 09:39 AM   #16
Johnco's Avatar
2006 19' Safari
Anaheim , California
I replaced all of the "repeat offenders" with brass inserts, problems solved. Check them out here: www.ezlok.com
Can be purchased at Rockler.
Johnco is offline   Reply With Quote
Screws and Aluminum and Rust ttbikes Ribs, Skins & Rivets 19 05-25-2015 07:38 PM
Loose door hinge screws ILOVESALLY Full-Timing, Winter Living & Workamping 8 05-04-2015 08:38 PM
Rams heads came loose in roof locker blickcd Cabinets, Counter Tops & Furnishings 5 04-14-2013 06:23 AM
2009 Loose Cabinet Screws tmarquis Cabinets, Counter Tops & Furnishings 18 04-11-2011 04:08 PM
HELP! hinge screws loose TinZilla Doors & Locks 7 11-16-2007 10:12 AM
