Old 05-20-2016, 10:14 AM   #1
kfrere's Avatar
2008 31' Classic
Lenoir City , Tennessee
Lock on screen door?
I'd like to leave my outer door open at night with the sliding screen door closed but can't figure out how to add a lock to the screen door. Has anyone attempted to do this? Any success?
Kelly & Matt
WBCCI - #4335
2005 Diesel Excursion
2008 31' Custom Classic "Moonshine"
2016 Interstate "BugOut"
kfrere is offline   Reply With Quote
Old 05-20-2016, 10:24 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A screen door can be cut easily with a pocketknife, so a lock on it is pointless. You could even tear out the screen material just by leaning hard against it, no tools required. A lock would provide a false sense of security.
You'd be better off just using the tip-out windows to get fresh air, but leaving the tip-out window on the sliding door closed, because again someone could simply punch out the screen, reach in, and unlock the door.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-20-2016, 10:43 AM   #3
2016 Interstate Lounge Ext
Heathrow , Florida
Around here the bears, or raccoons for that matter, are not polite enough to attempt sliding the doors.
Harleydeal is offline   Reply With Quote
Old 05-20-2016, 12:48 PM   #4
I sleep with the doors open as often as not. A lock won't do ya on a screen door, but a well-trained dog will get that job done better than any physical device ever could. Ours won't leave through an open door, and the hell that she raises is enough to scare the life out of pretty much anything that walks, crawls, or slithers upon the earth.
Old 05-20-2016, 02:22 PM   #5
Paddledipper's Avatar
1977 27' Overlander
1996 34' Excella
Florida Panhandle , Florida
I'm following this because we'd like a lock on our screen door that will keep our dog inside. Right now if she scratches at it, it pops open. We tried the simple hook and eye, but that also pops open with any pressure placed on the door.
The Evans' Family
Florida Panhandle
1977 Overlander / 27' ~ The Attitude Adjuster
1997 Airstream Excella / 34' ~ The Sane Asylum
Paddledipper is offline   Reply With Quote
Old 05-21-2016, 03:45 AM   #6
kfrere's Avatar
2008 31' Classic
I appreciate the concern for my safety by pointing out the obvious vulnerability of the screen, I really do, but there are other reasons for wanting to put a lock on a screen door. If anyone has a suggestion how to best accomplish this I'd love to hear it.
Kelly & Matt
WBCCI - #4335
Old 05-21-2016, 04:45 AM   #7
In that case, how about the same thing that people do to improve the security of sliding glass doors in their homes? At a convenient point of overlap between the fixed and moveable screen frames, drill partway through both from inside, and insert a locking pin.
WBCCI #1105
TAC LA-4
Old 05-21-2016, 08:41 AM   #8
kfrere's Avatar
2008 31' Classic
Unfortunately there is no overlap. The screen sits flush with the frame cushioned by a fuzzy foam material.
Kelly & Matt
WBCCI - #4335
Old 05-21-2016, 08:47 AM   #9
Then maybe a ratchet lock for a display case might fit.
WBCCI #1105
TAC LA-4
Old 05-21-2016, 10:14 AM   #10
HowieE's Avatar
Princeton , New Jersey
Images: 12
I mounted a standard window sash lock about 10 in above the slide opening as a child proof so the grand kids could not crawl out the screen door. It also serves as a lock as we leave our outer door open 99% of the time. Easy to reach from either side but not obvious to passers by.
2004 Excursion 4x4
Old 05-21-2016, 02:23 PM   #11
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
We also have our screen door open most times, including with the heat or with the AC. I installed riv-nuts in the screen door to receive turn clips to hold the plexiglass panels in the door. This allows light during those times of heat and AC. At the same time I lock the screen door with my interior dead bolt lock. The bolt protrudes just enough to catch the edge of the screen door. It is not used for security at all, just for securing the dog inside.
ID:	262916   Click image for larger version
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 05-22-2016, 06:02 AM   #12
2007 25' Safari
Attleboro , Massachusetts
Interesting...I have the same issue. My dog could get out so easy. I have a grate that's meant for home screen doors and I lean it against the door from the inside but it's really awkward and always in the way. The screen is so flimsy it seems to me that just keeping the door closed isn't much help.
romeb is offline   Reply With Quote
Old 05-22-2016, 06:12 AM   #13
Long Island , New York
Could you Interstate owners post a photo or two of your setup? Solutions for a trailer screen door are kind of irrelevant here IMO. [see forum name above -- Sprinter and B-van Forum]
OTRA15 is online now   Reply With Quote
Old 05-26-2016, 10:00 AM   #14
2004 22' Interstate
Redding , California
reminds me of the old "screen door on a sub" joke!!
jet1 is offline   Reply With Quote
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 10:19 AM
Door lock and screen hatch for '53 Clipper silver wren Exterior Storage Compartments & Access Doors 0 05-20-2010 06:37 PM
Hehr Standard...To screen or not to screen soldiermedic Windows & Screens 10 04-23-2009 11:45 AM
Fixing screen door screen wacnstac Windows & Screens 8 04-09-2007 10:35 PM
lock of screen door on 16 foot-Bambi gloriajoan 1997 - 2004 Bambi 10 10-16-2006 03:30 PM
