Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 12-07-2019, 02:18 PM   #1
2013 Interstate Coach
Idaho Falls , Idaho
Lights above driver/passenger seat
Has anyone put lights above the driver’s and front passenger seats? If so, what did you use and where did you run the wire from?
We like to read sitting in those chairs and we don’t get enough light from the other ceiling lights.
I have tried finding a path from the other ceiling lights to the compartment above the seats but haven’t found a path in the ceiling.
Passin Thru is offline   Reply With Quote
Old 12-07-2019, 02:43 PM   #2
Indianola , Iowa
You probably could mount something with a magnet or a clip on solution that is battery based/rechargeable, and not worry about running wires. Amazon has a bunch of different clip or clamp on reading lights and work light options. There are even work/reading lights that sort of hang around your neck and point wherever you want them. To me, something like that would be useful for what you want and for other things.
nateallen80 is offline   Reply With Quote
Driver and front passenger step AirRiggie Airstream Motorhome Forums 0 06-12-2017 01:25 AM
1979 Excella Driver/Passenger windows RosiesGuy Windows & Screens 0 05-30-2015 07:45 PM
Swap Driver w/Passenger Seats in MH??? Michigander Land Yacht/Legacy Motorhomes 15 04-25-2011 05:52 AM
345 motorhome passenger and driver vinyl seals raveson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 08-11-2006 04:28 PM
Driver/passenger legroom/Argosy MH? pepepepe Airstream Motorhome Forums 4 01-01-2003 06:24 PM
