Old 05-19-2015, 06:18 AM   #1
2015 Interstate Ext. Coach
Tulsa , Oklahoma
Leveling Sprinter
Probably silly question. Can do it with planks I guess. But...is there a better way, plastic wedges or whatever?
Bobsprinter is offline   Reply With Quote
Old 05-19-2015, 06:41 AM   #2
1994 34' Limited
Round Rock , Texas
Depending on how much your looking to spend, there are automatic leveling solutions for the sprinter chassis. My mom had a Revo, and had a system fitted to her coach. Push of a button, and the coach leveled out...Wasn't cheap, but it was effective. She didn't have to try and carry around leveling blocks or 2x4s to try and level out the coach. Plus, no crawling under the RV to get them in the right places to work.
txtwin is offline   Reply With Quote
Old 05-19-2015, 06:46 AM   #3
2013 Interstate Coach
Flemington , New Jersey
Leveling Sprinter
I carry 12 of these plus a bubble level in the interstate. So far I have only used them once at Gouldings campground in Monument Valley.
Never know when you might need them but they also work quite well for creating some extra crawl space when you have to do something under the coach. Work also well if you need to manipulate the angle to drain the water tank fully.
Name:	ImageUploadedByAirstream Forums1432039329.464239.jpg
Mario
2013 Interstate
2014 Little Guy 5x10 Silver Shadow
Tiato is offline   Reply With Quote
Old 05-19-2015, 06:55 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I don't need leveling often enough to pay over three grand to have automatic levelers mounted. I'd have to give up about a year's worth of camping trips just to pay for the levelers!
Those yellow lego blocks work for me just fine, when coupled with the interlocking chocks to match:
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-19-2015, 07:01 PM   #5
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
We've used these for our trailer and I don't see why they wouldn't work for a Class B motorhome.
3604 - Camper Leveler
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is online now   Reply With Quote
Old 05-19-2015, 07:18 PM   #6
Attachment 238825
Not sure I'd trust them on a Sprinter van. Consider this scenario: You're in a campsite where the back end of the van is low. You have four of these funky curved levelers, so you put one under each rear wheel and drive up onto them. Then you lock the parking brake, and get out to put the wedges under to lock the curved pieces into position. Only problem is, the parking brake (and placing the transmission in Park) doesn't lock the front wheels— which weren't chocked yet because you were driving up onto the levelers— so the van rolls off the curved pieces and crushes your hand when you try to insert the wedges. Recipe for disaster unless you have at least one rear corner at ground level.
On a trailer, you only have to put leveling blocks under one side, and front-to-back leveling is handled by the tongue jack. On a van, the only leveling you have is by means of whatever blocks you put under the tires, which you may have to do on up to three corners. I want to put blocks under mine that I'm sure will not move around after I've driven up onto them. These won't do the trick.
WBCCI #1105
TAC LA-4
Old 05-19-2015, 08:03 PM   #7
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Not sure how the RV is going to roll off the levelers under the rear duals and crush your hand when it's in Park and the parking brake has been set. Slide off maybe.
But I agree that this type of leveler is better suited for trailers.
Old 05-19-2015, 08:44 PM   #8
The levelers nvestysly suggested are curved. If the parking brake only locks the wheels against the levelers and not against the ground, that does not prevent the levelers themselves from rocking— until you stick the wedges under them with your hand… or maybe your foot if you kick the wedges into place.
You're welcome to try those levelers yourself, and I'll be very interested in knowing how they work. But I'm not going to try them on my Interstate; I'm a pessimist when it comes to safety.
WBCCI #1105
TAC LA-4
Old 05-19-2015, 09:41 PM   #9
mandolindave's Avatar
Brass Akwards
I can not believe some of the crazy scary ramps and blocks and wedges and chocks that peoples use to level their RVs.
WHY ARE PEOPLE TRYING TO LEVEL THEIR RVs?????????????
Why don't they level the ground ? ( rhetorical ) ( Think about it )
Hint…level your blocks before you drive up on to them.
mandolindave is offline   Reply With Quote
Old 05-19-2015, 10:32 PM   #10
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
I only ever use the interlocking lego-type blocks on the front wheels. I make sure the front of the AI is never higher than the rear, since we could never sleep with our heads lower than our feet!
So its just a matter of how many levels of blocks for each front wheel to get it more or less level side-to side, and only very approximately level front to back.
Old 05-20-2015, 05:11 AM   #11
Gainesville , Florida
I've seen this done, dig a hole to lower one side, not allowed most anywhere. . Jim
Old 05-20-2015, 05:22 AM   #12
Leveling Sprinter
I've seen some crazy leveling set ups. Guess mostly because of rigs with gas absorption refrigerators.
Mario
2013 Interstate
Old 10-08-2015, 01:16 PM   #13
This is one of those purchases I held off on making until I was sure it would serve a purpose. And that it does. Given that our Interstate model has full-height foot door access in the back, I've discovered that it's much more efficient to load it through the rear end. Which requires me to back into our driveway rather that going in nose-first. Which requires that I have levelers to shallow up the transition from the street to the driveway (I tried to get by without them, but I scraped when fully loaded).
And given that I made the purchase for that purpose, I might as well now level the Interstate while it sits in the driveway, too. No more refrigerator slamming shut on my skull as I'm trying to pack it. Well worth the money.
I bought the Valterra stackers because I was impatient and that's what they had on the shelf at Holiday World.
InterBlog is online now   Reply With Quote
Old 10-09-2015, 10:09 AM   #14
Muskogee , Oklahoma
These are great for the dual axles in the back:
Amazon.com: Camco 44525 Brown FasTen Leveling Block with T-Handle, 4x2 (Pack of 10): Automotive
They also work in the front.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Site for Sprinter & Sprinter-based RV Enthusiasts Zach Woods Sprinter and B-van Forum 0 09-25-2006 04:08 AM
Leveling a trailer APB On The Road... 29 07-11-2003 10:02 AM
leveling concerns jwaldin Jacks, Stabilizers, Lifting and Leveling 8 02-24-2003 02:34 PM
Load Leveling Hitch Fine Adjustment Road Ruler Hitches, Couplers & Balls 1 02-23-2003 11:32 AM
