Old 03-31-2014, 03:26 PM   #1
Missouri Valley , Iowa
Leveling jacks for the Interstate ?
We are interested in the Interstate EXT. In ads for some, I have seen leveling jacks mentioned as being included. Is this a typo error or can they be factory ordered ? I would expect an after market source is available if you want them. That brings me to the next question - what do most owners do ?
Dan
Farmer Dan is offline   Reply With Quote
Old 03-31-2014, 04:03 PM   #2
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Never heard of leveling jacks for an Interstate. I think most of us use leveling pads which interlock together like Lego, so you build them up in a ramp form to the height you need and drive onto them.
Peter
Old 03-31-2014, 05:05 PM   #3
2013 Interstate Coach
Flemington , New Jersey
Some sprinter based class C RV's have levelling jacks. I suppose they could be retrofited to an Interstate provided the areas required for mounting are free of undercarriage systems such as the generator, water tanks, etc.
My last RV had jacks and while convenient, it was ANOTHER system to stay on top off not to mention the reduction in carrying capacity.
Sprinter Automatic Leveling System
Mario
2013 Interstate
2014 Little Guy 5x10 Silver Shadow
Tiato is offline   Reply With Quote
Old 04-02-2014, 01:17 PM   #4
Trying to Retire
MILATV's Avatar
Decatur , Illinois
We used to get blown around some when parked on beach with high winds, so I was actually considering this. Once I upgraded the suspension to the Koni's we no longer have this problem. Have to watch how/were you park to try to get the van as level as possible, but I haven't had much problem in the year I've owned mine now (a little over 60 nights out in it).
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 04-02-2014, 01:32 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
What you want isn't leveling jacks— leveling should always be done by blocking the tires because they're the load-bearing members— and even an extended Interstate doesn't have overhangs long enough to really need leveling jacks to keep the ends from sagging.
What you're actually talking about is stabilizer jacks, to keep your Interstate from rocking. You could actually do something about this with what you have on board. Get out your tire-changing jack, and put it at the very rear, under the frame on one side where the receiver is attached. Jack it up until the van rises ever-so-slightly on its springs. Remove the jack handle, and you're done. If you try this, consider putting the jack on the passenger-side rear, since whether you do side entrance or rear entrance (for those with the twin-bed layout and an accessible rear door) so that as you stwp up the jack resists the van sagging under your added weight.
Before you try this, though, be warned; I haven't tried it myself because I haven't felt the need. If you try it, you do it at your own risk.
Or you can get a "univeral" stabilizer system from Camping World: Universal RV Stabilizer - Valterra 020106 - Stabilizing Jacks - Camping World and hook it up under your receiver. This has the advantage that it spans both frame rails, unlike the tire-changing jack that only engages one frame rail.
Cats and ultraleather Airstream upholstery don't mix!
Old 04-02-2014, 02:36 PM   #6
Trying to Retire
MILATV's Avatar
Decatur , Illinois
As usual you are correct PRO!
Stabilizers is what we considered.
If be working on my laptop and wife would be walking around so my mouse would slide, was just a pain.
But with upgrade shocks it works great no more rocking.
Mike
Old 04-09-2014, 09:46 AM   #7
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Kind of on the subject. Yesterday my electric jack kept shorting out. I think I found the problem but I could not figure out how to lower the jack by hand. I read the manual and did what they said but still could not see where or how to lower the jack. I was wondering how I was going to disconnect from the TV.
TinCan
graysailor is offline   Reply With Quote
Old 04-09-2014, 09:54 AM   #8
Not really on-topic, but here's a quick fix… Get out your tire-changing jack from your tow vehicle, and use that to lift the tongue off the ball. Make sure you chock the trailer tires first since it's possible for the trailer to fall off a portable jack if the trailer moves.
Once you've got the trailer loose from the tow vehicle, put a stack of timber blocks (or a jack stand, if you've got one) under the tongue at the right height so you can lower the tongue onto the blocks. Then you'll have a lot more room to work on the tongue jack without a truck bumper bumping you.
Old 04-09-2014, 11:07 AM   #9
lewster's Avatar
Naples, FL , Hood River, OR
Actually, there is a system of actual hydraulic levelling jacks. It is available from HWH, the leading US MANUFACTURER of hydraulic levelling systems and slide out mechanisms available here.
Their systems are quite robust and when properly installed, will level (not just stabilize) your coach automatically. These can be found on many Sprinter based Class C conversions like Winnebago and Itasca and should be available for the 3500 Sprinters.
Old 04-09-2014, 12:11 PM   #10
Lew,
Thanks for the update. I thought as many as are on the road, someone would make such a system. We did buy a used '14 EXT model and will fly to Ft. Myers, FL to pick it up tomorrow. We will probably stick with the leveling blocks method - at least until we see what problems, if any, we encounter.
Thanks, again !
Dan
'97 Safari 25' Leveling jacks 25Safari_97 Jacks, Stabilizers, Lifting and Leveling 3 07-12-2009 03:59 PM
**Leveling Jacks** Silvertwinky General Motorhome Topics 31 05-16-2008 04:53 PM
steps/leveling jacks??? swinginping Classic Motorhomes 4 03-11-2008 06:21 AM
Side to side leveling: can I use the stabilizer jacks? iAirstream Jacks, Stabilizers, Lifting and Leveling 4 08-17-2007 07:33 PM
Cable/sat hookup/leveling jacks Ga Pockets 1984-1988 Limited 10 01-14-2005 02:08 PM
