Old 03-08-2015, 03:08 PM   #1
X New Yorker
X New Yorker's Avatar
2013 Interstate Coach
Springfield , Massachusetts
Leveling Blocks? Why?
Hi Folks. Newbie question - I have heard that I need to have these and that when I park (overnight or camping), I should use these to make sure that the RV is level. Can somebody tell me why because I have no problem being a little tilted, but l'm hearing that my 2013 Interstate may be a tad more sensitive? If I really need these, what are the best and how many do I need of them? Thanks.
X New Yorker is offline   Reply With Quote
Old 03-08-2015, 03:09 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The frig needs to be level to work properly.
MICHAEL
Old 03-08-2015, 03:26 PM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
If you have an adsorption type of refrigerator, it needs to be level when operating or it may get damaged. That is the type of fridge installed in the trailers. I believe that the the Interstates use a 12v/120v fridge that has a small "residential style" compressor. That type of unit may not be quite as sensitive to being level as the adsorption type.
Bob Martel
WBCCI# 5766
Old 03-08-2015, 03:59 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I've been a little "tilted" all my life....SFSG
It was a bigger concern with our 63 Safari, it did need to be level....the Classic not so much.
Just be sure fore & aft is good and that you don't roll out of bed.
Trial & error will tell you.
Old 03-08-2015, 04:08 PM   #5
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
The fridge doesn't need to be level since its a compressor type in the Interstate. I have a plastic bag of 10 blocks but rarely use them. More for personal comfort and the food not spilling off the table. And I don't want to sleep with my head lower than my feet.
Old 03-08-2015, 04:24 PM   #6
X New Yorker
I think I may be OK as UKDUDE and I have similar fridges. Is the fridge the only concern (and not rolling out of the bed)? Thank you all!
Old 03-08-2015, 04:40 PM   #7
Lily&Me's Avatar
Normal , Illinois
8 years with the Interstate, never had leveling blocks and never needed them.
Nor have we ever had problems with the frig not working if we found ourselves not 100%, either way.
Unless you have a really awful site....and sometimes you get those .....a bit of manuevering generally gets the job done satisfactorily.
One of the many advantages of being small.
Maggie
Old 03-08-2015, 04:44 PM   #8
terryV's Avatar
2002 31' Classic
Monroe , Iowa
Somewhere in the late '80s (maybe even earlier) they sterted making fridges that weren't nearly so sensitive to off level. Everyone used to carry 2X6 or 2X8 boards for leveling back then. The plastic "lego" blocks are lighter and don't hold moisture.
Now, if your doors don't swing open on their own, you can cook without stuff running out of the pan, and you don't fall out of bed when you roll over, you're probably OK.
The leveling blocks come in handy when you are more un-level than you like, and you can also use them as chocks to keep the trailer from rolling downhill. You can also put them under the stabilizing jacks if you are over mud or sand to keep them from sinking.
I carry two sets of 10 with me. I don't use them very often, but when I do need them, they are worth the price.
terryV is offline   Reply With Quote
Old 03-08-2015, 05:30 PM   #9
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I have leveling blocks, and have used them on more than one occasion. If the van isn't quite level I usually don't bother, but I have stayed at campgrounds where the slope of the ground was enough to be uncomfortable.
For side-to-side leveling if the driver's side is slightly low I leave it alone because that improves drainage on my shower and galley sink, but if the driver's side is high then water ponds in the sink and shower.
For fore-and-aft leveling my rule is, if the sliding side door is somewhere between fully open and fully closed, and the slope is enough that it tries to slide the rest of the way open or closed on its own due to gravity, then I need to level it.
The Nova Kool fridge is completely unaffected by whether it's level; that's only for ammonia-cycle propane-fired fridges, not all-electric ones.
Most campgrounds I've stayed at in the past three years have been level enough not to need leveling block, but I do use the leveling blocks often enough to make it worth carrying them around. By the way, if you have to block up a rear tire you have to block both rear tires on that corner.
Leveling is the one and only time I envy trailer owners, who can use their tongue jack and stabilizers for fore-and-aft leveling, and only need blocks for side-to-side leveling.
As for what's best, the "lego block" style gives you a wider range of adjustment than most and includes wheel chocks to keep you from driving right off the blocks again if you goose the accelerator too much getting onto them. Plus they stack in a cube that fits behind the rear sofa when you're not using them. At Eisenhower State Park in Texas, I needed four sets of blocks to level my van, one set under each rear tire. The park was full up and I didn't have to option of moving to a site that was more level; that's one reason the site was still available in the first place, I think.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-09-2015, 06:55 AM   #10
Originally Posted by Lily&Me View Post
Nor have we ever had problems with the frig not working if we found ourselves not 100%, either way....
Maggie
I've course I've heard this many, many times about the older absorption fridges, but the problem is, I've never heard anyone say HOW un-level it has to be before a fridge problem is created. It's on my list of things to determine conclusively but I have not yet. Anyone have any thoughts on that?
Old 03-09-2015, 07:09 AM   #11
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
For the absorption fridges, anything less than a half-bubble off plumb is usually good enough. If you're comfortable, they're comfortable. If you roll out of bed in the middle of the night, and your coffee cup slides off the table, you should probably do some leveling.
Old 03-09-2015, 07:11 AM   #12
Gainesville , Florida
If you can get up in the middles of the night in darkness from a sound sleep and you don't fall to one side or the other, you are probably level enough. Yuk, Yuk! Peace, jim
Old 03-09-2015, 11:30 AM   #13
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
You don't need leveling blocks often, but occasionally you come across that old ghetto campground that was built in the 50's or 60's and all the pads are un-level to the point you will roll outta bed- that trailer will have a severe lean to the north- condensation will not drain properly from the a/c or refrigerator-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-09-2015, 11:34 AM   #14
m.hony's Avatar
2013 30' Classic
99.9% of the time you won't need 'em, but on site #1 George Payne Cossar State Park-
Or site #26 Trace State Park-
I don't think you ever need them at a Corps of Engineers park-
TAC #MS-10
Airforums #70955
What to use as leveling blocks flint Jacks, Stabilizers, Lifting and Leveling 34 06-25-2012 08:49 AM
Alternative to leveling blocks tschat Jacks, Stabilizers, Lifting and Leveling 18 06-30-2011 08:54 AM
"Lego" leveling blocks--bad experience! Kistler Jacks, Stabilizers, Lifting and Leveling 9 08-28-2003 06:42 AM
