Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 03-16-2015, 02:11 PM   #21
Glamper1's Avatar
I Google the images for folding cots
Maybe deconstructing the legs and joining 2 together could work.
My goal is as big of a bed as possible
Glamper1 is offline   Reply With Quote
Old 03-16-2015, 04:45 PM   #22
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Originally Posted by Glamper1 View Post
I would be sleeping up front
I need space
Thanks for the ideas!
So this is for you and/or your ten year old.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
Old 03-16-2015, 06:33 PM   #23
Glamper1's Avatar
The queen and the princess in the back
Me in the front
Old 03-16-2015, 08:55 PM   #24
bennu36's Avatar
2012 Interstate Coach
Portland , Oregon
We made a bed for our 4 year old grand son by lowering the fron seat on to the second row seat about as seen in the pictures that Jerhofer posted. We then "filled" in with foam. The pieces we used are 5 inch thick and about 20" by 18.5" work pretty good we are planing on covering then and maybe adding some straps to keep them in place.
bennu36 is offline   Reply With Quote
Old 03-21-2015, 07:13 PM   #25
Glamper1's Avatar
Coming along
Holes for tie downs that connect to cargo van's fasteners (loops) behind drivers and passenger seats. Stores uprighr against rear double doors.
Cut table post to lower table for center support.
Will glue carpet down then ready for air mattress or a foam pad
Old 03-22-2015, 06:28 PM   #26
2014 Interstate Ext. Coach
Basking Ridge , New Jersey
It worked out well..
Just yesterday I took our Interstate on our first overnight sojourn. We were "camping" out in front of a friend's house (after a 4.5 hour 220 mile drive). It was just me and my 2 daughters and so I let them have the big bed space in back and I tried Jerhofer's arrangement of the drivers seat reclined to horizontal, but I removed the headrest and butted it up to the front of the 2nd row captains chair. I had pulled the 2nd row chair all the way forward and reclined against the cabinet behind it.
I hope you can picture it but it was sort of like a domestic first class seat on 737 but with a full foot rest (the drivers seat). I slept fairly well, had no back stiffness, and only stirred when the furnace kicked on. It was in the low thirties, so I had set it at 60 just to keep the chill off.
The girls were okay in the back, with their sleeping bags and pillows from home (and stuffed animals for the younger one). Though since we were on a slight grade towards the curb, the sleeping bags slid alot. Does anyone know if you can jam on a queen or full fitted sheet, to stop the slipness factor of the ultra leather?
SCARLET BISON
Silver 2014.5 Interstate EXT
scarletbison is offline   Reply With Quote
Old 03-22-2015, 06:57 PM   #27
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I keep my extra mattress under the big bed mattress, just slide it right under.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 03-22-2015, 07:50 PM   #28
Figment of My Imagination
Protagonist's Avatar
That sure won't work on an Interstate, because the big mattress is a sofa!
Old 03-22-2015, 08:20 PM   #29
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
My first night in the Interstate was on a slight slope......spent a lot of time climbing back from cabinet. A 2" memory foam mattress stopped the slide and helped the comfort factor.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 03-24-2015, 03:11 PM   #30
Glamper1's Avatar
Name:	ImageUploadedByAirstream Forums1427231442.860645.jpg
Done
Waiting for folding foam mattress to arrive
Replaced piano hinge with leather
Old 03-24-2015, 03:14 PM   #31
Glamper1's Avatar
Name:	ImageUploadedByAirstream Forums1427231697.289428.jpg
Old 03-25-2015, 12:01 AM   #32
Nice work! Hope I don't have to build one soon.
LB_3 is offline   Reply With Quote
Old 04-12-2015, 05:01 PM   #33
Glamper1's Avatar
Version 2 light weight and folds up
Version 2 is strong and tested
Version 2 is more comfy but not real world tested yet
REI folding cot with end legs taken off
Tie downs for 2ndary support
ID:	236152   Click image for larger version
Old 04-23-2015, 06:04 PM   #34
AtlantaCpl's Avatar
Atlanta , Georgia
I almost have a solution here. With the seats turned toward each other as the photo at the top of the thread shows, a portable bunk solution like http://www.amazon.com/Disc-O-Bed-Cam.../dp/B00BGU41G2 would solve the problem. There is also a kid version called kid o bunk.
The problem is the bottom bunk is only 11 inches from the floor. We need at least 2 feet to clear the seats and have the lower bunk rest above the seats - as the bunk is about 10 inches wider than the between-the-seat area if that makes sense.
I'm thinking of contacting the manufacturer to see if they can provide an extension for the legs, or alternatively make something home made out of 6x6 blocks.
Brian
AtlantaCpl is offline   Reply With Quote
Lets figure this out together Glamper1 Airstream Motorhome Forums 1 03-20-2015 03:52 PM
trying to figure out the health insurance maze rec Full-Timing 20 02-12-2008 03:27 PM
Help me figure out what this is Lumatic General Interior Topics 3 10-22-2007 07:50 PM
How can I figure out the towing capacity of my 300TE? davida Tow Vehicles 5 06-05-2006 05:07 AM
Any newbie worth his/her salt should be able to figure this out for her/himself... Dave Jenkins Our Community 4 07-26-2003 05:41 AM
